Hi
I have an Acer Nitro 5 AN515-44 with a processor AMD Ryzen 5 4600H and graphic cards GTX 1650 TI (4 Go) & AMD Radeon Vega 6.
When installing Ubuntu 20.04, at first i could’nt set luminosity of my laptop. I solved this problem by upgrading to the kernel 5.8.0-33 with command :
sudo apt install linux-generic-hwe-20.04-edge
Then i wanted to connect my lapto to my external monitor but it was not recognised at first. I finally solved my problem by adding Option “PrimaryGPU” “Yes” to the file /usr/share/X11/xorg.conf.d/10-nvidia.conf and by replacing Driver “amdgpu” with Driver “modesetting” to the file /usr/share/X11/xorg.conf.d/10-amdgpu.conf like this :
Section “OutputClass”
Identifier “nvidia”
MatchDriver “nvidia-drm”
Driver “nvidia”
Option “AllowEmptyInitialConfiguration”
ModulePath “/usr/lib/x86_64-linux-gnu/nvidia/xorg”
EndSection
Identifier “AMDgpu”
MatchDriver “amdgpu”
#Driver “amdgpu”
EndSection
But i just figured out by rebooting my laptop (without extetnal monitor connected) that Lightdm want to display HDMI instead of the screen of the laptop.
The consequence is the the screen of the laptop stays black on the login screen. Fortunaly, i can type my password (blind). Once password validated, the OS understand there is no monitor on HDMI and displays the screen of the laptop.
Important point, in Nvidia-settings the monitor number 1 is the external monitor, not the one of my laptop. And i can’t change it.
Does anyone already had this problem ?
I put some results to help.
Best regards,
Jimmy
inxi -Fxxz
System:
Kernel: 5.8.0-33-generic x86_64 bits: 64 compiler: N/A
Desktop: Xfce 4.14.2 tk: Gtk 3.24.13 wm: xfwm4 dm: LightDM
Distro: Ubuntu 20.04.1 LTS (Focal Fossa)
Machine:
Type: Laptop System: Acer product: Nitro AN515-44 v: V1.02
serial: <filter>
Mobo: RO model: Stonic_RNS v: V1.02 serial: <filter> UEFI: Insyde v: 1.02
date: 06/16/2020
CPU:
Topology: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
type: MT MCP arch: Zen rev: 1 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 71867
Speed: 1397 MHz min/max: 1400/3000 MHz Core speeds (MHz): 1: 1397 2: 1398
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1396 9: 1413 10: 1396 11: 1401
12: 1397
Graphics:
Device-1: NVIDIA vendor: Acer Incorporated ALI driver: nvidia v: 455.38
bus ID: 01:00.0 chip ID: 10de:1f95
Device-2: AMD Renoir vendor: Acer Incorporated ALI driver: amdgpu
v: kernel bus ID: 05:00.0 chip ID: 1002:1636
Display: x11 server: X.Org 1.20.8 driver: ati,modesetting,nvidia
unloaded: amdgpu,fbdev,nouveau,vesa
resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1650 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38
direct render: Yes
Sensors:
System Temperatures: cpu: 43.6 C mobo: N/A
Fan Speeds (RPM): N/A
GPU: device: nvidia screen: :0.0 temp: 36 C device: amdgpu temp: 34 C
Info:
Processes: 298 Uptime: 6h 22m Memory: 7.21 GiB used: 1.97 GiB (27.3%)
Init: systemd v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Shell: bash
v: 5.0.17 running in: xfce4-terminal inxi: 3.0.38
lspci -vnn | grep -A12 '\''[030[02]\]' | grep -Ei "vga|3d|display|kernel"
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:1f95] (rev a1) (prog-if 00 [VGA controller])
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
05:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636] (rev c7) (prog-if 00 [VGA controller])
Kernel driver in use: amdgpu
Kernel modules: amdgpu
uname -a
Linux s-Nitro-AN515-44 5.8.0-33-generic #36~20.04.1-Ubuntu SMP Wed Dec 9 17:01:13 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
s@s-Nitro-AN515-44:~$ uname -a
s@s-Nitro-AN515-44:~$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 2160, maximum 32767 x 32767
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+
1680x1050 59.95
1440x900 74.98 59.89
1280x1024 75.02 60.02
1280x720 60.00
1024x768 75.03 60.00
800x600 75.00 60.32
640x480 75.00 72.81 59.94
eDP-1-1 connected 1920x1080+0+1080 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.01*+ 60.01 59.97 59.96 59.93
1680x1050 60.01 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.01 60.02
1440x900 60.01 59.89
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 60.01 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 60.01 59.99 59.86 59.74
1024x768 60.01 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.01 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.01 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
1680x1050 (0x1e9) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1280x1024 (0x1f2) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x1f4) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1024x768 (0x20b) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x21b) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
640x480 (0x22b) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
dpkg -l | grep -v ^ii
Souhait=inconnU/Installé/suppRimé/Purgé/H=à garder
| État=Non/Installé/fichier-Config/dépaqUeté/échec-conFig/H=semi-installé/W=attend-traitement-déclenchements
|/ Err?=(aucune)/besoin Réinstallation (État,Err: majuscule=mauvais)
||/ Nom Version Architecture Description
lsmod | sort
acer_wireless 20480 0
acer_wmi 24576 0
aesni_intel 372736 4
af_alg 28672 6 algif_hash,algif_skcipher
ahci 40960 0
algif_hash 16384 1
algif_skcipher 16384 1
amdgpu 5214208 2
autofs4 45056 2
binfmt_misc 24576 1
bluetooth 577536 41 btrtl,btintel,btbcm,bnep,btusb,rfcomm
bnep 24576 2
btbcm 16384 1 btusb
btintel 28672 1 btusb
btrtl 24576 1 btusb
btusb 57344 0
ccp 98304 1 kvm_amd
cec 53248 1 drm_kms_helper
cfg80211 778240 3 iwlmvm,iwlwifi,mac80211
cmac 16384 3
crc32_pclmul 16384 0
crct10dif_pclmul 16384 1
cryptd 24576 3 crypto_simd,ghash_clmulni_intel
crypto_simd 16384 1 aesni_intel
drm 552960 10 gpu_sched,drm_kms_helper,amdgpu,nvidia_drm,ttm
drm_kms_helper 217088 2 amdgpu,nvidia_drm
ecc 32768 1 ecdh_generic
ecdh_generic 16384 2 bluetooth
edac_mce_amd 32768 0
efi_pstore 16384 0
fb_sys_fops 16384 1 drm_kms_helper
ghash_clmulni_intel 16384 0
glue_helper 16384 1 aesni_intel
gpu_sched 36864 1 amdgpu
hid 135168 3 i2c_hid,hid_multitouch,hid_generic
hid_generic 16384 0
hid_multitouch 28672 0
i2c_algo_bit 16384 1 amdgpu
i2c_hid 28672 0
i2c_piix4 28672 0
input_leds 16384 0
iommu_v2 20480 1 amdgpu
ip_tables 32768 0
iwlmvm 393216 0
iwlwifi 352256 1 iwlmvm
joydev 24576 0
k10temp 16384 0
kvm 712704 1 kvm_amd
kvm_amd 98304 0
ledtrig_audio 16384 1 snd_hda_codec_generic
libahci 36864 1 ahci
libarc4 16384 1 mac80211
lp 20480 0
mac80211 905216 1 iwlmvm
mac_hid 16384 0
mc 57344 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
Module Size Used by
nls_iso8859_1 16384 1
nvidia 27705344 208 nvidia_uvm,nvidia_modeset
nvidia_drm 53248 7
nvidia_modeset 1216512 5 nvidia_drm
nvidia_uvm 1003520 0
nvme 45056 4
nvme_core 110592 6 nvme
parport 65536 3 parport_pc,lp,ppdev
parport_pc 45056 0
ppdev 24576 0
r8169 77824 0
rapl 20480 0
rc_core 57344 1 cec
realtek 24576 1
rfcomm 81920 16
sch_fq_codel 20480 2
serio_raw 20480 0
snd 94208 19 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
snd_hda_codec 139264 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_codec_generic 81920 1 snd_hda_codec_realtek
snd_hda_codec_hdmi 61440 1
snd_hda_codec_realtek 126976 1
snd_hda_core 94208 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hda_intel 53248 4
snd_hwdep 20480 1 snd_hda_codec
snd_intel_dspcfg 24576 1 snd_hda_intel
snd_pci_acp3x 20480 0
snd_pcm 114688 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_rawmidi 36864 1 snd_seq_midi
snd_rn_pci_acp3x 20480 0
snd_seq 69632 2 snd_seq_midi,snd_seq_midi_event
snd_seq_device 16384 3 snd_seq,snd_seq_midi,snd_rawmidi
snd_seq_midi 20480 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_timer 40960 2 snd_seq,snd_pcm
soundcore 16384 1 snd
sparse_keymap 16384 1 acer_wmi
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
ttm 102400 1 amdgpu
uvcvideo 98304 0
video 49152 1 acer_wmi
videobuf2_common 53248 2 videobuf2_v4l2,uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 24576 1 uvcvideo
videobuf2_vmalloc 20480 1 uvcvideo
videodev 237568 3 videobuf2_v4l2,uvcvideo,videobuf2_common
wmi 32768 2 acer_wmi,wmi_bmof
wmi_bmof 16384 0
xhci_pci 20480 0
xhci_pci_renesas 20480 1 xhci_pci
x_tables 45056 1 ip_tables
s@s-Nitro-AN515-44:~$ lsmod | sort
acer_wmi 24576 0
ahci 40960 0
algif_hash 16384 1
amdgpu 5214208 2
autofs4 45056 2
binfmt_misc 24576 1
bnep 24576 2
btbcm 16384 1 btusb
btrtl 24576 1 btusb
btusb 57344 0
ccp 98304 1 kvm_amd
cmac 16384 3
efi_pstore 16384 0
hid_generic 16384 0
i2c_hid 28672 0
i2c_piix4 28672 0
input_leds 16384 0
ip_tables 32768 0
iwlmvm 393216 0
joydev 24576 0
k10temp 16384 0
kvm_amd 98304 0
lp 20480 0
mac_hid 16384 0
Module Size Used by
nvidia_drm 53248 8
nvme 45056 4
parport_pc 45056 0
ppdev 24576 0
r8169 77824 0
rapl 20480 0
rc_core 57344 1 cec
realtek 24576 1
rfcomm 81920 16
serio_raw 20480 0
ttm 102400 1 amdgpu
uvcvideo 98304 0
wmi_bmof 16384 0
xhci_pci 20480 0
acer_wmi 24576 0
ahci 40960 0
algif_hash 16384 1
amdgpu 5214208 2
autofs4 45056 2
binfmt_misc 24576 1
bnep 24576 2
btbcm 16384 1 btusb
btrtl 24576 1 btusb
btusb 57344 0
ccp 98304 1 kvm_amd
cmac 16384 3
efi_pstore 16384 0
hid_generic 16384 0
i2c_hid 28672 0
i2c_piix4 28672 0
input_leds 16384 0
ip_tables 32768 0
iwlmvm 393216 0
joydev 24576 0
k10temp 16384 0
kvm_amd 98304 0
lp 20480 0
mac_hid 16384 0
Module Size Used by
nvidia_drm 53248 8
nvme 45056 4
parport_pc 45056 0
ppdev 24576 0
r8169 77824 0
rapl 20480 0
rc_core 57344 1 cec
realtek 24576 1
rfcomm 81920 16
serio_raw 20480 0
ttm 102400 1 amdgpu
uvcvideo 98304 0
wmi_bmof 16384 0
xhci_pci 20480 0
