I am using Flir Blackfly S camera with Jetson Orin NX. When running SpinView I notice really low frame rate for this camera ca. 15 FPS. Also image flickers a lot.
Can this frame rate be increased and how? Can flickering be removed?
Running the same camera on same device but through python script, image is stable and no noticeable lag when something moves in front of the camera.
Please consult with the vendor to get further support. By default UVC driver is enabled in Jetpack releases. If the device supports it, the device mode shall be present and you can capture frame data through v4l2 interface. Seems like the device doesn’t support UVC driver and has its own driver. Would be great if you can check with the vendor.
