-nano
-latest jetpack https://developer.nvidia.com/jetson-nano-sd-card-image
-deepstream 6
i’m starting a docker myimage:latest2 which is a slightly modified (added some more packages) of nvcr.io/nvidia/deepstream:6.0-base
docker run --name=streamcontroller -it --cap-add=SYS_PTRACE --runtime=nvidia -e DISPLAY=$DISPLAY --privileged --volume /tmp/.X11-unix:/tmp/.X11-unix --net=host -e NVIDIA_VISIBLE_DEVICES=all -v $HOME/.Xauthority:/root/.Xauthority -v /run/udev/control:/run/udev/control -v /greengrass/v2:/greengrass/v2 -v /dev:/dev -v /sys/firmware/devicetree/base/serial-number:/sys/firmware/devicetree/base/serial-number -v /data:/data -e NVIDIA_DRIVER_CAPABILITIES=compute,utility,graphics xxxxx.dkr.ecr.ap-southeast-2.amazonaws.com/myimage:latest2
inside the docker:
root@ljeteye:/opt/nvidia/deepstream/deepstream-6.0# cd /usr/lib/aarch64-linux-gnu/gstreamer-1.0/
root@ljeteye:/usr/lib/aarch64-linux-gnu/gstreamer-1.0# ls
deepstream libgstaudiomixmatrix.so libgstcutter.so libgstflac.so libgstisomp4.so libgstmpegtsdemux.so libgstofa.so libgstrtmp.so libgststereo.so libgstvideotestsrc.so
libgst1394.so libgstaudioparsers.so libgstdashdemux.so libgstflite.so libgstivfparse.so libgstmpegtsmux.so libgstogg.so libgstrtp.so libgstsubenc.so libgstvmnc.so
libgsta52dec.so libgstaudiorate.so libgstdc1394.so libgstfluidsynthmidi.so libgstivtc.so libgstmpg123.so libgstomx.so libgstrtpmanager.so libgstsubparse.so libgstvoaacenc.so
libgstaasink.so libgstaudioresample.so libgstde265.so libgstflv.so libgstjack.so libgstmplex.so libgstopenal.so libgstrtponvif.so libgsttaglib.so libgstvoamrwbenc.so
libgstaccurip.so libgstaudiotestsrc.so libgstdebug.so libgstflxdec.so libgstjp2kdecimator.so libgstmulaw.so libgstopenexr.so libgstrtsp.so libgsttcp.so libgstvolume.so
libgstadder.so libgstaudiovisualizers.so libgstdebugutilsbad.so libgstfreeverb.so libgstjpeg.so libgstmultifile.so libgstopenglmixers.so libgstrtspclientsink.la libgstteletext.so libgstvorbis.so
libgstadpcmdec.so libgstauparse.so libgstdecklink.so libgstfrei0r.so libgstjpegformat.so libgstmultipart.so libgstopenjpeg.so libgstrtspclientsink.so libgsttheora.so libgstvpx.so
libgstadpcmenc.so libgstautoconvert.so libgstdeinterlace.so libgstgaudieffects.so libgstkate.so libgstmusepack.so libgstopenmpt.so libgstsbc.so libgsttimecode.so libgstvulkan.so
libgstaiff.so libgstautodetect.so libgstdtls.so libgstgdkpixbuf.so libgstkms.so libgstmxf.so libgstopus.so libgstsdpelem.so libgstttmlsubs.so libgstwavenc.so
libgstalaw.so libgstavi.so libgstdtmf.so libgstgdp.so libgstkvssink.so libgstnavigationtest.so libgstopusparse.so libgstsegmentclip.so libgsttwolame.so libgstwavpack.so
libgstalpha.so libgstbayer.so libgstdtsdec.so libgstgeometrictransform.so libgstladspa.so libgstnetsim.so libgstoss4.so libgstshapewipe.so libgsttypefindfunctions.so libgstwavparse.so
libgstalphacolor.so libgstbluez.so libgstdv.so libgstgio.so libgstlame.so libgstnvarguscamerasrc.so libgstossaudio.so libgstshm.so libgstudp.so libgstwaylandsink.so
libgstalsa.so libgstbs2b.so libgstdvb.so libgstgme.so libgstlegacyrawparse.so libgstnvcompositor.so libgstpango.so libgstshout2.so libgstuvch264.so libgstwebp.so
libgstamrnb.so libgstbz2.so libgstdvbsuboverlay.so libgstgoom.so libgstlevel.so libgstnvdrmvideosink.so libgstpbtypes.so libgstsid.so libgstvcdsrc.so libgstwebrtc.so
libgstamrwbdec.so libgstcacasink.so libgstdvdlpcmdec.so libgstgoom2k1.so libgstlibav.so libgstnveglglessink.so libgstpcapparse.so libgstsiren.so libgstvideo4linux2.so libgstwebrtcdsp.so
libgstapetag.so libgstcairo.so libgstdvdread.so libgstgsm.so libgstlibvisual.so libgstnveglstreamsrc.so libgstplayback.so libgstsmooth.so libgstvideobox.so libgstwildmidi.so
libgstapp.so libgstcamerabin.so libgstdvdspu.so libgsthls.so libgstlv2.so libgstnvegltransform.so libgstpng.so libgstsmoothstreaming.so libgstvideoconvert.so libgstx264.so
libgstasf.so libgstcdio.so libgstdvdsub.so libgsticydemux.so libgstmatroska.so libgstnvivafilter.so libgstpnm.so libgstsmpte.so libgstvideocrop.so libgstx265.so
libgstasfmux.so libgstcdparanoia.so libgsteffectv.so libgstid3demux.so libgstmidi.so libgstnvjpeg.so libgstproxy.so libgstsndfile.so libgstvideofilter.so libgstximagesrc.so
libgstassrender.so libgstchromaprint.so libgstencoding.so libgstid3tag.so libgstmms.so libgstnvtee.so libgstrawparse.so libgstsoundtouch.so libgstvideofiltersbad.so libgstxingmux.so
libgstaudiobuffersplit.so libgstcoloreffects.so libgstequalizer.so libgstimagefreeze.so libgstmodplug.so libgstnvv4l2camerasrc.so libgstrealmedia.so libgstsoup.so libgstvideoframe_audiolevel.so libgsty4mdec.so
libgstaudioconvert.so libgstcolormanagement.so libgstfaad.so libgstinter.so libgstmonoscope.so libgstnvvidconv.so libgstremovesilence.so libgstspandsp.so libgstvideomixer.so libgsty4menc.so
libgstaudiofx.so libgstcompositor.so libgstfaceoverlay.so libgstinterlace.so libgstmpeg2dec.so libgstnvvideo4linux2.so libgstreplaygain.so libgstspectrum.so libgstvideoparsersbad.so libgstyadif.so
libgstaudiofxbad.so libgstcoreelements.so libgstfbdevsink.so libgstinterleave.so libgstmpeg2enc.so libgstnvvideocuda.so libgstresindvd.so libgstspeed.so libgstvideorate.so libgstzbar.so
libgstaudiolatency.so libgstcoretracers.so libgstfestival.so libgstinterpipe.so libgstmpegpsdemux.so libgstnvvideosink.so libgstrfbsrc.so libgstspeex.so libgstvideoscale.so libsei.so
libgstaudiomixer.so libgstcurl.so libgstfieldanalysis.so libgstipcpipeline.so libgstmpegpsmux.so libgstnvvideosinks.so libgstrsvg.so libgstsrtp.so libgstvideosignal.so
root@ljeteye:/usr/lib/aarch64-linux-gnu/gstreamer-1.0# export DISPLAY=:0
root@ljeteye:/usr/lib/aarch64-linux-gnu/gstreamer-1.0# export GST_PLUGIN_PATH=/usr/lib/aarch64-linux-gnu/gstreamer-1.0:/opt/nvidia/deepstream/deepstream/lib/gst-plugins
root@ljeteye:/usr/lib/aarch64-linux-gnu/gstreamer-1.0# export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/aarch64-linux-gnu/open-source:/usr/lib/aarch64-linux-gnu/gstreamer-1.0:/opt/nvidia/deepstream/deepstream/lib
when i check to see which plugins are available it is giving me a lot of errors:
I have started the whole nano as a headless unit and have uninstalled gdm
Are the below errors expected because of this ? It doesn’t seem right that some of these plugins are blacklisted just because there is no UI started. Or is this normal ?
root@ljeteye:/usr/lib/aarch64-linux-gnu/gstreamer-1.0# gst-inspect-1.0
No EGL Display
nvbufsurftransform: Could not get EGL display connection
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:20): GStreamer-WARNING **: 05:48:38.498: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20): GStreamer-WARNING **: 05:48:38.509: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
(gst-plugin-scanner:21): GStreamer-WARNING **: 05:48:38.646: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:26): GStreamer-WARNING **: 05:48:39.209: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
No EGL Display
(gst-plugin-scanner:28): GStreamer-WARNING **: 05:48:39.305: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
nvbuf_utils: Could not get EGL display connection
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:40): GStreamer-WARNING **: 05:48:40.326: Failed to load plugin '/opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:40): GStreamer-WARNING **: 05:48:40.337: Failed to load plugin '/opt/nvidia/deepstream/deepstream/lib/gst-plugins/libcustom2d_preprocess.so': /opt/nvidia/deepstream/deepstream/lib/gst-plugins/libcustom2d_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
(gst-plugin-scanner:41): GStreamer-WARNING **: 05:48:40.472: Failed to load plugin '/opt/nvidia/deepstream/deepstream/lib/gst-plugins/libcustom2d_preprocess.so': /opt/nvidia/deepstream/deepstream/lib/gst-plugins/libcustom2d_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:46): GStreamer-WARNING **: 05:48:41.030: Failed to load plugin '/opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_preprocess.so': /opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
No EGL Display
(gst-plugin-scanner:48): GStreamer-WARNING **: 05:48:41.126: Failed to load plugin '/opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:58): GStreamer-WARNING **: 05:48:43.083: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:58): GStreamer-WARNING **: 05:48:43.094: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
(gst-plugin-scanner:59): GStreamer-WARNING **: 05:48:43.233: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
(gst-plugin-scanner:64): GStreamer-WARNING **: 05:48:43.796: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so: undefined symbol: NvBufSurfTransformAsync
No EGL Display
No EGL Display
(gst-plugin-scanner:66): GStreamer-WARNING **: 05:48:43.894: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
No EGL Display
nvvideocuda: videocuda: CUDA Post processor
nvjpeg: nvjpegdec: JPEG image decoder
nvjpeg: nvjpegenc: JPEG image encoder
nvtee: nvtee: NvTee
nvegltransform: nvegltransform: NvEGLTransform
nvv4l2camerasrc: nvv4l2camerasrc: NvV4l2CameraSrc
nvvidconv: nvvidconv: NvVidConv Plugin
nvvideosink: nvvideosink: nVidia Video Sink
nveglstreamsrc: nveglstreamsrc: nVidia EGL Stream
nvvideosinks: nv3dsink: Nvidia 3D sink
nvivafilter: nvivafilter: NvIVAFilter Plugin
.... big list of plugins
list of blacklisted plugins
Blacklisted files:
libnvdsgst_multistream.so
libnvdsgst_multistreamtiler.so
libnvdsgst_dewarper.so
libnvdsgst_deepstream_bins.so
libnvdsgst_tracker.so
libnvdsgst_infer.so
libnvdsgst_udp.so
libnvdsgst_dsexample.so
libnvdsgst_osd.so
libgstnvvideoconvert.so
