Blackscreen after GRUB on multiple distros
nvidia-bug-report.log.gz (299.9 KB)
My system is a desktop PC with a 4070, further details in the inxi output at the bottom.
This has happened in both Manjaro and Mint Linux. Most recently I did a fresh install of Manjaro and chose the proprietary drivers option. Grub loads fine and I am able to boot into Manjaro but shortly after that my monitor stops registering any input. I am unable to view a TTY while in this state. I am able to boot by plugging my hdmi cable directly into my motherboard but nothing I have tried has enabled me to use my GPU.
I have tried everything I can find online but nothing seems to resolve it
a short list of the things I remember trying:
  • removing the splash quiet from the kernel options
  • disabling plymouth
  • enabling “Above 4G decoding” and disabling CSM in my bios
  • booting with “nomodset”
Below I have included the output of the inxi command in case it can be of use:
System:
  Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64
    root=UUID=edbc090f-e5f3-40d2-a025-09762011f5be rw rootflags=subvol=@ quiet
    splash udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
    wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Machine:
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z370-E GAMING v: Rev X.0x
    serial: <superuser required> part-nu: SKU uuid: <superuser required>
    UEFI: American Megatrends v: 0615 date: 04/11/2018
Battery:
  Message: No system battery data found. Is one present?
Memory:
  System RAM: total: 32 GiB available: 31.2 GiB used: 3.73 GiB (12.0%)
  Message: For most reliable report, use superuser + dmidecode.
  Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
    max-module-size: 8 GiB note: est.
  Device-1: ChannelA-DIMM1 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMK16GX4M2B3000C15
    serial: N/A
  Device-2: ChannelA-DIMM2 type: DDR4 detail: synchronous unbuffered
    serial: N/A
  Device-3: ChannelB-DIMM1 type: DDR4 detail: synchronous unbuffered
    serial: N/A
  Device-4: ChannelB-DIMM2 type: DDR4 detail: synchronous unbuffered
    serial: N/A
CPU:
  Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88824
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
    clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
    pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
    sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
    vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Vulnerabilities:
  Type: gather_data_sampling mitigation: Microcode
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: l1tf mitigation: PTE Inversion
  Type: mds mitigation: Clear CPU buffers; SMT vulnerable
  Type: meltdown mitigation: PTI
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
  Type: reg_file_data_sampling status: Not affected
  Type: retbleed mitigation: IBRS
  Type: spec_rstack_overflow status: Not affected
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
    prctl
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
    sanitization
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: conditional;
    RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Type: srbds mitigation: Microcode
  Type: tsx_async_abort mitigation: TSX disabled
Graphics:
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20
    ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1,HDMI-A-3 bus-ID: 00:02.0
    chip-ID: 8086:3e92 class-ID: 0300
  Device-2: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none empty: DP-2,
    DP-3, DP-4, HDMI-A-4 bus-ID: 01:00.0 chip-ID: 10de:2782 class-ID: 0300
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.4:8
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
    s-diag: 1165mm (45.88") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-2 model: LG (GoldStar) Ultra HD serial: <filter>
    built: 2017 res: 3840x2160 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
    diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
    platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2 drv: iris
    device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11:
    drv: iris inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
    device-ID: 8086:3e92 memory: 15.23 GiB unified: yes
  API: Vulkan v: 1.4.309 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4070 Ti driver: nvidia v: 570.133.07 device-ID: 10de:2782
    surfaces: xcb,xlib
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
    de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
    wl: wayland-info x11: xdpyinfo,xprop
Audio:
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  Device-2: NVIDIA AD104 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22bc
    class-ID: 0403
  API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsactl,alsamixer,amixer
  Server-1: JACK v: 1.9.22 status: off tools: N/A
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
    tools: pactl,pw-cat,pw-cli,wpctl
Network:
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v4: <filter> type: dynamic noprefixroute scope: global
    broadcast: <filter>
  IP v6: <filter> type: dynamic noprefixroute scope: global
  IP v6: <filter> type: noprefixroute scope: link
  Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
    driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:b822 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
  WAN IP: <filter>
Bluetooth:
  Device-1: ASUSTek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0b05:185c
    class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Logical:
  Message: No logical block device data found.
RAID:
  Message: No RAID data found.
Drives:
  Local Storage: total: 1.82 TiB used: 6.25 GiB (0.3%)
  SMART Message: Required tool smartctl not installed. Check --recommends
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 020 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: MBR
  Message: No optical or floppy data found.
Partition:
  ID-1: / raw-size: 92.65 GiB size: 92.65 GiB (100.00%) used: 6.22 GiB (6.7%)
    fs: btrfs dev: /dev/sdb5 maj-min: 8:21 label: N/A
    uuid: edbc090f-e5f3-40d2-a025-09762011f5be
  ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
    used: 31.1 MiB (32.7%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 429D-3750
  ID-3: /home raw-size: 92.65 GiB size: 92.65 GiB (100.00%)
    used: 6.22 GiB (6.7%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21 label: N/A
  ID-4: /var/cache raw-size: 92.65 GiB size: 92.65 GiB (100.00%)
  ID-5: /var/log raw-size: 92.65 GiB size: 92.65 GiB (100.00%)
Swap:
  Alert: No swap data was found.
Unmounted:
  ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: Recovery
    uuid: CE2E9CD62E9CB943
  ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda4 maj-min: 8:4 size: 930.91 GiB fs: ntfs label: N/A
    uuid: 2A86AE1986ADE613
  ID-4: /dev/sdb1 maj-min: 8:17 size: 838.36 GiB fs: ntfs label: Media
    uuid: 2EDEF49FDEF4608F
  ID-5: /dev/sdb2 maj-min: 8:18 size: 512 MiB fs: vfat label: N/A
    uuid: 3B90-75D8
  ID-6: /dev/sdb3 maj-min: 8:19 size: 1 KiB fs: <superuser required>
USB:
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002
    class-ID: 0900
  Hub-2: 1-5:2 info: Terminus Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-5.2:4 info: Sunplus Innovation Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
  Device-2: 1-5.3:6 info: Keychron V3 Max type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0933 class-ID: 0300
  Device-3: 1-5.4:8 info: Logitech HD Pro Webcam C920 type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
  Device-4: 1-7:3 info: ASUSTek Bluetooth Radio type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0b05:185c class-ID: e001 serial: <filter>
  Device-5: 1-8:5 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:1872 class-ID: 0300
    serial: <filter>
  Device-6: 1-9:7 info: Corsair H80i v2 type: <vendor specific> driver: N/A
    interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 50mA chip-ID: 1b1c:0c08 class-ID: 0000 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
    class-ID: 0900
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
    class-ID: 0900
  Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
    class-ID: 0900
Sensors:
  System Temperatures: cpu: 35.0 C mobo: N/A
  Fan Speeds (rpm): N/A
Info:
  Processes: 289 Power: uptime: 14m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 257 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1172 libs: 319 tools: pamac pm: flatpak pkgs: 0
    Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37 running-in: konsole
    inxi: 3.3.38
For what it’s worth, I tried using a displayport cable after reading some other users had success doing so and it worked right away. This is no longer urgent for me but if anybody knows why the hdmi wasn’t working I’d be interested to hear it.
