Blank desktop following latest software upgrad
I can connect by Sync, but the desktop is grayed out with only the mouse cursor showing. Is there a CLI fix? I rebooted and CPU utilizaition is low. I did this through the dash, checking from the ssh shell, I see
olly@sparky:~$ sudo apt update
[sudo] password for olly:
Get:1 https://nvidia.github.io/libnvidia-container/stable/deb/arm64  InRelease [1,477 B]
Hit:2 https://downloads.1password.com/linux/debian/amd64 stable InRelease
Hit:3 https://repo.download.nvidia.com/baseos/ubuntu/noble/arm64 noble InRelease
Hit:5 https://workbench.download.nvidia.com/stable/linux/debian default InRelease
Hit:6
  InRelease
Hit:7 https://repo.download.nvidia.com/baseos/ubuntu/noble/arm64 noble-updates InRelease
Hit:8
  InRelease
Hit:9 https://repo.download.nvidia.com/spark/ubuntu/arm64 noble-updates InRelease
Hit:4 https://packagecloud.io/github/git-lfs/ubuntu noble InRelease
Hit:10
 noble InRelease
Hit:11
Hit:12
 noble-apps-security InRelease
Hit:13
 noble-backports InRelease
Hit:14
 noble-apps-updates InRelease
Hit:15
 noble-security InRelease
Hit:16 https://snapshot.ppa.launchpadcontent.net/canonical-nvidia/nvidia-desktop-edge/ubuntu noble InRelease
Hit:17 https://esm.ubuntu.com/infra/ubuntu noble-infra-security InRelease
Hit:18 https://snapshot.ppa.launchpadcontent.net/canonical-nvidia/vulkan-packages-nv-desktop/ubuntu noble InRelease
Hit:19 https://esm.ubuntu.com/infra/ubuntu noble-infra-updates InRelease
Fetched 1,477 B in 2s (853 B/s)
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
All packages are up to date.
olly@sparky:~$
And it’s hit16 that seems suspect.
Did you use the dashboard to do software upgrade?
Did the SW upgrade finish successfully?
If somehow not finished, you can continue the upgrade with these commands
ā€œsudo apt updateā€
ā€œsudo apt dist-upgradeā€
I did use the dash (having learned my lesson the hard way). As far as I could tell it finished successfully. I’ve run the apt commands and after a reboot through the ssh shell, I’m back to the grayed out screen.
I went ahead an used the recovery usb stick.
