Blank optimus laptop screen on xinit after updating to (Fedora-25) kernel v4.10.9-200 and NVIDIA v378.13 (patched) ...
F25 mesa is built with libglvnd support, using bumblebee or the nvidia .run isn’t recommended as both overwrite system files.
The nvidia .run file will try to overwrite most of these files
$ rpm -qal libglvnd\*
/etc/glvnd
/usr/lib/libGLdispatch.so.0
/usr/lib/libGLdispatch.so.0.0.0
/usr/share/doc/libglvnd
/usr/share/doc/libglvnd/README.md
/usr/share/glvnd
/usr/lib64/libOpenGL.so.0
/usr/lib64/libOpenGL.so.0.0.0
/usr/lib64/libGL.so.1
/usr/lib64/libGL.so.1.0.0
/usr/lib64/libGLX.so.0
/usr/lib64/libGLX.so.0.0.0
/usr/lib/libGL.so.1
/usr/lib/libGL.so.1.0.0
/usr/lib/libGLX.so.0
/usr/lib/libGLX.so.0.0.0
/etc/egl/egl_external_platform.d
/etc/glvnd/egl_vendor.d
/usr/lib64/libEGL.so.1
/usr/lib64/libEGL.so.1.0.0
/usr/share/egl/egl_external_platform.d
/usr/share/glvnd/egl_vendor.d
/etc/glvnd
/usr/lib64/libGLdispatch.so.0
/usr/lib64/libGLdispatch.so.0.0.0
/usr/share/glvnd
/usr/include/glvnd
/usr/include/glvnd/GLdispatchABI.h
/usr/include/glvnd/libeglabi.h
/usr/include/glvnd/libglxabi.h
/usr/lib64/pkgconfig/libglvnd.pc
/usr/lib/libOpenGL.so.0
/usr/lib/libOpenGL.so.0.0.0
/usr/lib/libEGL.so.1
/usr/lib/libEGL.so.1.0.0
/usr/lib64/libGLESv1_CM.so.1
/usr/lib64/libGLESv1_CM.so.1.0.0
/usr/lib64/libGLESv2.so.2
/usr/lib64/libGLESv2.so.2.0.0
/usr/lib64/libGL.so
/usr/lib/libGLESv1_CM.so.1
/usr/lib/libGLESv1_CM.so.1.0.0
/usr/lib/libGLESv2.so.2
/usr/lib/libGLESv2.so.2.0.0
bumblebee wasn’t libglvnd compatible last time I checked.
TBH you would be better off using negativo17 or rpmfusion nvidia as they have prime support already
https://github.com/negativo17/nvidia-driver/blob/master/10-nvidia.conf
https://pkgs.rpmfusion.org/cgit/nonfree/xorg-x11-drv-nvidia.git/tree/nvidia.conf
P.S nvidia wont even look at your issue unless you provide the request info, see
https://devtalk.nvidia.com/default/topic/522835/linux/if-you-have-a-problem-please-read-this-first/
