Blender python api
Trying to install bpy on jetson orin, and it’s not going so well,
Is it possible that this package is not support on orin?
Kind regards,
Kfir
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
It looks like there is no prebuilt package for the Jetson environment.
But you can try to build it from the source with the below instructions:
https://developer.blender.org/docs/handbook/building_blender/linux/#__tabbed_1_1
