Description
Encounter the error as follows:
[blockChooser.cpp::getRegionBlockSize::690] Error Code 2: Internal Error (Assertion memSize >= 0 failed. )
Environment
TensorRT Version: 8+
NVIDIA GPU: 1660
NVIDIA Driver Version: 470
CUDA Version: 11.3
CUDNN Version: compatible with cuda 11.3
Operating System: linux x86
Python Version (if applicable): 3.8
PyTorch Version (if applicable): 1.10
Steps To Reproduce
import torch
import onnx
import tensorrt as trt
onnx_model = 'model.onnx'
class NaiveModel(torch.nn.Module):
def __init__(self):
super().__init__()
def forward(self, x):
B, C, H, W = x.shape
pad_w = W % 7
pad_h = H % 7
x_t = torch.zeros((B, C, H + pad_h, W + pad_w), device=x.device)
x_t[:, :, :H, :W] = x
return x_t
device = torch.device('cuda:0')
# generate ONNX model
torch.onnx.export(
NaiveModel(),
torch.randn(1, 3, 224, 224),
onnx_model,
input_names=['input'],
output_names=['output'],
dynamic_axes=dict(
input=dict({
0: 'batch',
2: 'height',
3: 'width'
output=dict({0: 'batch'})),
opset_version=11)
onnx_model = onnx.load(onnx_model)
# load_tensorrt_plugin()
# create builder and network
logger = trt.Logger(trt.Logger.ERROR)
builder = trt.Builder(logger)
EXPLICIT_BATCH = 1 << (int)(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
network = builder.create_network(EXPLICIT_BATCH)
# parse onnx
parser = trt.OnnxParser(network, logger)
if not parser.parse(onnx_model.SerializeToString()):
error_msgs = ''
for error in range(parser.num_errors):
error_msgs += f'{parser.get_error(error)}\n'
raise RuntimeError(f'Failed to parse onnx, {error_msgs}')
config = builder.create_builder_config()
config.max_workspace_size = 1 << 30
profile = builder.create_optimization_profile()
profile.set_shape('input', [1, 3, 112, 112], [1, 3, 224, 224],
[1, 3, 512, 512])
config.add_optimization_profile(profile)
# create engine
with torch.cuda.device(device):
engine = builder.build_engine(network, config)
with open('model.engine', mode='wb') as f:
f.write(bytearray(engine.serialize()))
print("generating file done!")
