the Xavier platform crashed during an Ubuntu OS Update.
Since then I get a blue Screen.
How can i solve this Problem?
Hi markus.krovinovitsch,
What’s your host PC environment? The JetPack can’t run well on a VM, the minimum requires an X86_64 Linux o/s host with a native Linux file system type.
or could you flash your Xavier again?
If you mean “sudo apt-get upgrade”, then perhaps GUI is down, but ssh and console would work. Can you see a console from CTRL-ALT-F2? Can you ssh in? If so, does all “ok” return from:
sha1sum -c /etc/nv_tegra_release
Have you resolved the problem?
Any result can be shared?
now i get the following error message: HSM ERROR 244, CRITICAL_ERR_NVL_CAR
Markus
Are you using drive platform???
