Severity: High — blocks P/D disaggregation for LLM inference on multi-GPU nodes
Component: mlx5_core / BlueField-3 eSwitch (legacy mode)
Environment:
- Hardware: Dell PowerEdge XE9680L, 10× BF3 B3140H SuperNIC (900-9D3D4-00EN-HA0, PSID MT_0000001069)
- Firmware: 32.43.1014
- Driver: Tested on both DOCA 3.3.0 (OFED 26.01-1.0.0) and DOCA 3.4.0 (OFED 26.04-0.8.6) — same result
- OS: RHCOS 9.6, kernel 5.14.0-570.99.1.el9_6, OpenShift 4.21
- eSwitch: legacy mode, NIC mode
- Kernel: iommu=pt pci=noacs
- SR-IOV: 8 VFs per PF, netdevice, isRdma=true
- Network: L3 routed RoCE via NVIDIA Cumulus switches, nv-ipam + sbr-custom
Problem:
When 2 SR-IOV VFs from the same PF simultaneously perform RDMA operations, all RDMA traffic fails with IBV_WC_RETRY_EXCEEDED (status 12, syndrome 0x81). Zero or near-zero completions. TCP/ping between the same
VFs continues to work — only RDMA verbs traffic is affected. The degradation persists after removing the second VF’s workload and only clears with a full node reboot.
Test Results:
│ Scenario │ Result │
│ 1 VF per PF, single PF │ 391 Gb/s (line rate) │
│ 1 VF per PF, all 8 PFs simultaneously │ 390 Gb/s per rail │
│ 2 VFs from same PF, both doing RDMA │ 0.005 Gb/s / IBV_WC_RETRY_EXCEEDED │
│ 2 VFs from different PFs │ 390 Gb/s (no issue) │
│ After removing 2nd VF pod (no reboot) │ Still degraded │
│ After node reboot │ Recovers │
Error output:
Completion with error at client
Failed status 12: qp_num 473 wr_id 0 syndrom 0x81
scnt=128, ccnt=0
RDMA HW counters after failure:
mlx5_19: out_of_sequence=2, rx_write_requests=5000
mlx5_24: out_of_sequence=13, rx_write_requests=1627
What was ruled out:
- ATS_ENABLED (disabled, rebooted — no change)
- Switch (SSH verified: MACs learned, no port security, ping works)
- Physical link (0 errors, BER 15E-255, FEC clean)
- GID table (4 valid GIDs per VF)
- DRA drivers (suspended, rebooted — no change)
- IOMMU/ACS settings (iommu=pt pci=noacs as recommended)
- IPAM (tested nv-ipam+sbr and whereabouts — same result)
- PCIe VF DevCtl (verified identical on working CX-6 Dx cluster)
- RDMA exclusive netns mode (breaks SR-IOV device plugin with isRdma=true)
- BIOS SR-IOV (PCIe SR-IOV cap shows VF_Enable=True, VF_MSE=True)
- Driver upgrade (DOCA 3.3.0 → 3.4.0: slightly improved from ccnt=0 to ccnt=17 on some tests, but still fails)
Reproducer:
- BF3 in NIC mode, legacy eSwitch, fw 32.43.1014
- Create SriovNetworkNodePolicy: numVfs=8, isRdma=true, deviceType=netdevice, linkType=eth
- Deploy 2 pods on each node, each requesting 1 VF from the same PF
- Run: ib_write_bw -d mlx5_XX --gid-index 3 -s 262144 -n 1000 -F --report_gbits
- Result: IBV_WC_RETRY_EXCEEDED, zero completions
Reference architecture note:
NVIDIA DGX B200 uses ConnectX-7 (not BF3) for compute SR-IOV with multi-VF RDMA. BF3 is only used for storage/management. The Dell XE9680L uses BF3 SuperNICs for compute, which may not be a tested
configuration for multi-VF RDMA.
b200-rdma-dumps.tar.gz — 31 binary dumps from mstresourcedump captured during baseline (1 VF, 391 Gb/s), pre-test (2 VFs, before RDMA),
b200-rdma-dumps.tar.gz (4.5 KB)
during-test (2 VFs, RDMA failing), and post-failure states. Segments:
QUERY_VNIC_ENV, STEER_PIPE_CHK, L2_TBL_ENTRIES, QUERY_FT_ALL, QUERY_FTE_ALL, FLOW_COUNTER, PORT_INFO, BASIC_DEBUG, FW_CNTRS. -
b200-multi-vf-investigation.md — full investigation document with mstconfig dumps, PCIe config, switch verification, RDMA counters
Request:
- Analyze the binary dumps to identify the eSwitch steering failure
- Confirm whether multi-VF RDMA on the same PF is supported on BF3 B3140H in NIC mode with legacy eSwitch
- If supported, provide a firmware fix (current 32.43.1014, DOCA 3.4.0 bundles 32.49.1014 but no image available for PSID MT_0000001069)
