I’m experiencing an issue when trying to enable Adaptive Routing for RoCE on my NVIDIA BlueField3 NIC. Despite my configuration attempts, the adaptive_routing_forced_en value remains unchanged.
When I execute the mlxreg command, the adaptive_routing_forced_en value doesn’t change as expected:
root:/home/ubuntu# mlxreg -d /dev/mst/mt41692_pciconf0 --reg_name ROCE_ACCL --set "adaptive_routing_forced_en=0x1"
You are about to send access register: ROCE_ACCL with the following data:
Field Name | Data
roce_adp_retrans_field_select | 0x00000001
roce_tx_window_field_select | 0x00000001
roce_slow_restart_field_select | 0x00000001
roce_slow_restart_idle_field_select | 0x00000001
min_ack_timeout_limit_disabled_field_select | 0x00000001
adaptive_routing_forced_en_field_select | 0x00000000
selective_repeat_forced_en_field_select | 0x00000001
dc_half_handshake_en_field_select | 0x00000000
ack_dscp_force_field_select | 0x00000001
roce_adp_retrans_en | 0x00000001
roce_tx_window_en | 0x00000000
roce_slow_restart_en | 0x00000001
roce_slow_restart_idle_en | 0x00000000
min_ack_timeout_limit_disabled | 0x00000000
adaptive_routing_forced_en | 0x00000001
selective_repeat_forced_en | 0x00000000
dc_half_handshake_en | 0x00000000
ack_dscp_force | 0x00000000
ack_dscp | 0x00000000
Do you want to continue ? (y/n) [n] : y
Sending access register...
root:/home/ubuntu# mlxreg -d /dev/mst/mt41692_pciconf0 --get --reg_name ROCE_ACCL
Field Name | Data
adaptive_routing_forced_en | 0x00000000
I notice that in the output, the “adaptive_routing_forced_en_field_select” value still is 0x00000000,.
Prior to this, I had already set ROCE_ADAPTIVE_ROUTING_EN=1 via mlxconfig:
root:/home/xiangzhou# mlxconfig -d /dev/mst/mt41692_pciconf0 -e q | grep -i ADAPTIVE
* ROCE_ADAPTIVE_ROUTING_EN False(0) True(1) True(1)
Hardware, Firmware, and Driver Information:
root:/home/ubuntu# mlxconfig -d /dev/mst/mt41692_pciconf0 -e q
Device #1:
Device type: BlueField3
Description: NVIDIA BlueField-3 B3240 P-Series Dual-slot FHHL DPU; 400GbE / NDR IB (default mode); Dual-port QSFP112; PCIe Gen5.0 x16 with x16 PCIe extension option; 16 Arm cores; 32GB on-board DDR; integrated BMC; Crypto Enabled
Device: /dev/mst/mt41692_pciconf0
root@gpu15:/home/ubuntu# mlxburn -d /dev/mst/mt41692_pciconf0 query
-I- Image type: FS4
-I- FW Version: 32.44.1036
-I- FW Release Date: 7.2.2025
-I- Product Version: 32.42.1000
-I- Rom Info: type=UEFI Virtio net version=21.4.13 cpu=AMD64,AARCH64
-I- type=UEFI Virtio blk version=22.4.13 cpu=AMD64,AARCH64
-I- type=UEFI version=14.35.15 cpu=AMD64,AARCH64
-I- type=PXE version=3.7.500 cpu=AMD64
-I- Description: UID GuidsNumber
-I- Base GUID: 7c8c090300bf3484 38
-I- Base MAC: 7c8c09bf3484 38
-I- Image VSD: N/A
-I- Device VSD: N/A
-I- PSID: MT_0000000883
-I- Security Attributes: secure-fw
root:/home/ubuntu# mlxreg --version
mlxreg, mft 4.31.0-149, built on Feb 7 2025, 12:26:42. Git SHA Hash: N/A
root:/home/ubuntu# ofed_info -s
OFED-internal-25.01-0.6.0:
root:/home/ubuntu# cat /opt/mellanox/doca/applications/VERSION
2.10.0087
Could someone please advise on the correct procedure to enable Adaptive Routing for RoCE on the BlueField3? Are there additional steps required, or am I missing something in my current approach?
Thank you for your assistance.
