rl12
August 2, 2024, 12:37pm
1
I am facing issues when trying to connect a xbox controller with Jetson Orin Nano(Jetpack 5.1.2 (L4T 35.4.1)) over bluetooth.
The problem:
The controller appears to repeatedly connect and disconnect
Controller is not configurable with jstest-gtk
Troubleshooting steps I have tried:
Install xboxdrv
Disable ertm
Disable the WiFi module
I have attached the syslog, showing the period in which Iturned on the bluetooth and attempted to connect the controller.
Note: The controller works when connected with a cable to the jetson
syslog-jetson-nano-2.log (284.6 KB)
There are some discussions about it:
Jetson/L4T/r36.3.x patches - eLinux.org
Enable F710 controller
Please check and give it a try. And please also apply this:
Enabling Bluetooth Audio — NVIDIA Jetson Linux Developer Guide 1 documentation
rl12
August 6, 2024, 2:04pm
4
I have enabled the bluetooth Audio following the steps you mentioned above.
And based on the discussions and links in your first source,
I attempted kernel customization
I followed the steps entailed here:
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/Kernel/KernelCustomization.html#to-build-the-kernel
However, I run into an error when I attempt to build it
I have attached a subset of the log file (sys log) and the error message
Am I doing something wrong?
build_attempt_log.txt (17.1 KB)
newlog1.log (2.0 KB)
rl12
August 16, 2024, 9:52am
5
Could I get some help with this?
The issue continues to persist.
Please apply this for a try:
Can't receive file via Bluetooth on Jetson AGX Orin with JetPack 6 - #20 by DaneLLL
It is for another BT function and might be helpful for this. Please give it a try.
system
Closed
September 11, 2024, 3:36am
8
