If I use the Bluetooth module on Jetson Nano, can I pair it with mobile phone, and use the phone to provide cellular connectivity to Jetson box?
Rational: I build a solution for vehicle that needs to communicate remotely. Vehicle will not have WiFi environment, but always will have the driver mobile phone around (Bluetooth).
Thank you
I don’t have answer as never tried this use case, but most of edge device might work on similar environment, you may google which BT profile can support it and try ti enable it, See also: How to Set Up a Bluetooth Network | Techwalla
