Looks like device is not compatible with tegra. Do you have any other LE devices to do a quick test?
→ Logitech M585 mouse is the same problem.
Could you share the BLE spec of that mouse?
→ Logitech MX Anywhere2 specs: [url]Logitech Support + Download
We didn’t have much bt4.0 issues before, please report if it can be reproduced on other LE devices as well.
→ There is no problem with MacBook Pro.
Please also try below method to see if fixing smp error.
Add/uncomment lines in /etc/bluetooth/main.conf as below towards the end
[Policy]
AutoEnable=true
Comment out below line in /lib/udev/rules.d/50-bluetooth-hci-auto-poweron.rules
by prefixing “#” the line ACTION==“add”, SUBSYSTEM==“bluetooth”, KERNEL==“hci[0-9]*”, RUN+=“/bin/hciconfig %k up” in file /lib/udev/rules.d/50-bluetooth-hci-auto-poweron.rules
