BMC unreachable
I can no longer ping the BMC internally (192.168.1.110).
I was able to do that once and change the default password, but now repeating the same steps, I can’t ping it anymore.
This is blocking the dGPU conversion process.
Both 1GbE NICs are linked up now to the NVIDIA network with DHCP-provided IPs.
Do I need to disconnect the inner port (eth0) before configuring a static IPrunning?
Do I need to have a cable connected there for BMC access from inside the node’s OS?
Hi isdias, we don’t support accessing the BMC from inside the node’s OS. We recommend using a directly connected cable from a separate system to the Ethernet port on the devkit.
