BME280 pressure sensor and Jetson TX1
Hi
I have BME280 bosch temperature and pressure sensor module and I want to interact with it.
this module supports I2C and SPI Protocol
I want to use I2C protocol for get pressure and temperature value from sensor
how can I do that ?
is there any library for using this sensor ?
We don’t have the lib, and you can check the Search: sensor (nvidia.com) for the sensor integration, also can refer to Adafruit I2C devices on the Jetson Nano - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums to see if can help.
@kayccc
Hi, Thank you for your response
the BME280 sensor have I2C and SPI protocol for communication.
but I don’t know how can I integrate with sensor with I2C protocol.
is there any code sample or library (in C++) that can working with I2C on Jetson Nano ?
