BOARD E1780 TPS65913 tegra K1, nvtboot, tos, eks, fuse, u-boot port
Hi all, i have a board with soc Tegra k1, this is board without ethernet port, pcie, and full usb(only microusb)
I can’t start u-boot on this board.
My PMIC is TPS65913(used only in the tegra114 platform) and i can’t write init for regulators.
I write full pinmux, and gpio, but u-boot not booted(in t114 regulators set only for sdcard).
My board use nvtboot.bin tos.img eks.dat with bootloader.bin for boot kernel image, but i can’t get source for this blobs and i and my friend try to start u-boot on this board for port new kernel and get psci work without bugs.
I write this init
https://github.com/Insei/u-boot-nvidia/blob/60b3fa6ff374e5c50792c6cbb66e712562ee03fd/drivers/power/tps65913.c
from example init for sdcard(dalmore board), but this func dm_i2c_write or i2c_write do not be used in the pmic_enable_cpu_vdd func from init, need to use tegra_i2c_ll_write_addr func, but i’m not true developer, and i need a help with address of regulators for this func, or address stay normal? If yes its wrong?
Can you help me? can u-boot need something else?
And my board do not have fuse regulator. Tos.img we used from another board, i think bootloader not signed.
This is full commit with all my changes for this board, maybe this get additional info.
And sorry for my bad english.
Fastboot.bin from Linux for tegra not flash this board, i get “bad data” message. I can flash this board only with nvflash tool of the manufacturer and only from windows, i try change SPL_boot parameters in u-boot, for use old address, and use old nvflash tool, but it not working with fastboot.bin from l4t. Maybe L4T not support TPS65913 pmic chip?
Okay, i try to get board.bct.cfg via nvflash
Version       = 0x00400001;
BlockSize     = 0x00004000;
PageSize      = 0x00000200;
PartitionSize = 0x08000000;
OdmData       = 0x0049c000;
JtagCtrl      = 0x00000000;
RsaKeyModulus:
 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
RsaPssSigBct:
ChipUid       = 0x00000000000000000000000000000000;
# Bootloader used       = 2;
# Bootloaders max       = 4;
# BCT size              = 8192;
# Hash size             = 16;
# Crypto offset         = 1712;
# Crypto length         = 6480;
# Max BCT search blocks = 64;
# These values are set by cbootimage using the
# bootloader provided by the Bootloader=...
# configuration option.
# Bootloader[0].Version      = 0x00000001;
# Bootloader[0].Start block  = 640;
# Bootloader[0].Start page   = 0;
# Bootloader[0].Length       = 100320;
# Bootloader[0].Load address = 0x4000e000;
# Bootloader[0].Entry point  = 0x4000e000;
# Bootloader[0].Attributes   = 0x00000006;
# Bootloader[0].Bl AES Hash  = c7004faafe16bbbd7f64c33e83de5e48;
# Bootloader[0].RsaPssSigBl:
# Bootloader[1].Version      = 0x00000001;
# Bootloader[1].Start block  = 768;
# Bootloader[1].Start page   = 0;
# Bootloader[1].Length       = 4194304;
# Bootloader[1].Load address = 0x80108000;
# Bootloader[1].Entry point  = 0x80108000;
# Bootloader[1].Attributes   = 0x00000007;
# Bootloader[1].Bl AES Hash  = 2e097b5550ebf2b8d54be84000b6908e;
# Bootloader[1].RsaPssSigBl:
DevType[0] = NvBootDevType_Sdmmc;
DeviceParam[0].SdmmcParams.ClockDivider           = 0x00000009;
DeviceParam[0].SdmmcParams.DataWidth              = NvBootSdmmcDataWidth_8Bit;
DeviceParam[0].SdmmcParams.MaxPowerClassSupported = 0x00000000;
DeviceParam[0].SdmmcParams.MultiPageSupport       = 0x00000000;
Why rsa sig is 00?
Why nvtboot loaded from 0x4000e000 addr(this is miniloader?) I try flash u-boot via tegrarcm, and tegrarcm miniloader load from 0x4000e000 too. tegrarcm succesfuly flash u-boot but u-boot not boot.
Why DevType only 1?
I have a memory configuration too, but i can’t share full cfg from phone.
# CFG Version 02
# Do not edit. Generated by t124_emc_reg_tool5.0.16.exe V5.0.16. Command:
#   t124_emc_reg_tool5.0.16.exe -i Hynix_lpddr3_pop_X64_2GB_H9CKNNNBKTMTDR.par 4.9019607
#      -dram_board_cfg 15 -o E1922_Hynix_pop_2GB_H9CKNNNBKTMTDR_204MHz.cfg -b tBKV\E1922_Hynix_pop_2GB_H9CKNNNBKTMTDR_204MHz.txt
# Parameter file: Hynix_lpddr3_pop_X64_2GB_H9CKNNNBKTMTDR.par, tck = 4.90 ns (204.00 MHz)
# bkv file: tBKV\E1922_Hynix_pop_2GB_H9CKNNNBKTMTDR_204MHz.txt
SDRAM[0].MemoryType                               = NvBootMemoryType_LpDdr2;
SDRAM[0].PllMInputDivider                         = 0x00000001;
SDRAM[0].PllMFeedbackDivider                      = 0x00000022;
SDRAM[0].PllMStableTime                           = 0x0000012c;
SDRAM[0].PllMSetupControl                         = 0x00000000;
SDRAM[0].PllMSelectDiv2                           = 0x00000000;
SDRAM[0].PllMPDLshiftPh45                         = 0x00000001;
SDRAM[0].PllMPDLshiftPh90                         = 0x00000001;
SDRAM[0].PllMPDLshiftPh135                        = 0x00000001;
SDRAM[0].PllMKCP                                  = 0x00000000;
SDRAM[0].PllMKVCO                                 = 0x00000000;
SDRAM[0].EmcBctSpare0                             = 0x00000000;
SDRAM[0].EmcBctSpare1                             = 0x00000000;
SDRAM[0].EmcBctSpare2                             = 0x00000000;
SDRAM[0].EmcBctSpare3                             = 0x00000000;
SDRAM[0].EmcBctSpare4                             = 0x00000000;
SDRAM[0].EmcBctSpare5                             = 0x00000000;
SDRAM[0].EmcBctSpare6                             = 0x00000000;
SDRAM[0].EmcBctSpare7                             = 0x00000000;
SDRAM[0].EmcBctSpare8                             = 0x00000000;
SDRAM[0].EmcBctSpare9                             = 0x00000000;
SDRAM[0].EmcBctSpare10                            = 0x00000000;
SDRAM[0].EmcBctSpare11                            = 0x00000000;
SDRAM[0].EmcClockSource                           = 0x40000002;
SDRAM[0].EmcAutoCalInterval                       = 0x001fffff;
SDRAM[0].EmcAutoCalConfig                         = 0xa1430000;
SDRAM[0].EmcAutoCalConfig2                        = 0x00000000;
SDRAM[0].EmcAutoCalConfig3                        = 0x00000000;
SDRAM[0].EmcAutoCalWait                           = 0x00000190;
SDRAM[0].EmcAdrCfg                                = 0x00000000;
SDRAM[0].EmcPinProgramWait                        = 0x00000000;
SDRAM[0].EmcPinExtraWait                          = 0x00000000;
SDRAM[0].EmcTimingControlWait                     = 0x00000000;
SDRAM[0].EmcRc                                    = 0x0000000c;
SDRAM[0].EmcRfc                                   = 0x0000002a;
SDRAM[0].EmcRfcSlr                                = 0x00000000;
SDRAM[0].EmcRas                                   = 0x00000008;
SDRAM[0].EmcRp                                    = 0x00000003;
SDRAM[0].EmcR2r                                   = 0x00000000;
SDRAM[0].EmcW2w                                   = 0x00000000;
SDRAM[0].EmcR2w                                   = 0x00000007;
SDRAM[0].EmcW2r                                   = 0x00000008;
SDRAM[0].EmcR2p                                   = 0x00000003;
SDRAM[0].EmcW2p                                   = 0x0000000a;
SDRAM[0].EmcRdRcd                                 = 0x00000003;
SDRAM[0].EmcWrRcd                                 = 0x00000003;
SDRAM[0].EmcRrd                                   = 0x00000002;
SDRAM[0].EmcRext                                  = 0x00000003;
SDRAM[0].EmcWext                                  = 0x00000000;
SDRAM[0].EmcWdv                                   = 0x00000002;
SDRAM[0].EmcWdvMask                               = 0x00000002;
SDRAM[0].EmcQUse                                  = 0x00000005;
SDRAM[0].EmcQuseWidth                             = 0x00000003;
SDRAM[0].EmcIbdly                                 = 0x00000000;
SDRAM[0].EmcEInput                                = 0x00000003;
SDRAM[0].EmcEInputDuration                        = 0x00000007;
SDRAM[0].EmcPutermExtra                           = 0x00010000;
SDRAM[0].EmcPutermWidth                           = 0x00000004;
SDRAM[0].EmcPutermAdj                             = 0x00000000;
SDRAM[0].EmcCdbCntl1                              = 0x00000000;
SDRAM[0].EmcCdbCntl2                              = 0x00000000;
SDRAM[0].EmcCdbCntl3                              = 0x00000000;
SDRAM[0].EmcQRst                                  = 0x00000002;
SDRAM[0].EmcQSafe                                 = 0x0000000e;
SDRAM[0].EmcRdv                                   = 0x0000000f;
SDRAM[0].EmcRdvMask                               = 0x00000011;
SDRAM[0].EmcQpop                                  = 0x0000000a;
SDRAM[0].EmcCtt                                   = 0x00000000;
SDRAM[0].EmcCttDuration                           = 0x00000004;
SDRAM[0].EmcRefresh                               = 0x00000304;
SDRAM[0].EmcBurstRefreshNum                       = 0x00000000;
SDRAM[0].EmcPreRefreshReqCnt                      = 0x000000c1;
SDRAM[0].EmcPdEx2Wr                               = 0x00000002;
SDRAM[0].EmcPdEx2Rd                               = 0x00000002;
SDRAM[0].EmcPChg2Pden                             = 0x00000003;
SDRAM[0].EmcAct2Pden                              = 0x00000000;
SDRAM[0].EmcAr2Pden                               = 0x00000001;
SDRAM[0].EmcRw2Pden                               = 0x0000000c;
SDRAM[0].EmcTxsr                                  = 0x0000002d;
SDRAM[0].EmcTxsrDll                               = 0x0000002d;
SDRAM[0].EmcTcke                                  = 0x00000003;
SDRAM[0].EmcTckesr                                = 0x00000004;
SDRAM[0].EmcTpd                                   = 0x00000003;
SDRAM[0].EmcTfaw                                  = 0x00000009;
SDRAM[0].EmcTrpab                                 = 0x00000005;
SDRAM[0].EmcTClkStable                            = 0x00000003;
SDRAM[0].EmcTClkStop                              = 0x00000003;
SDRAM[0].EmcTRefBw                                = 0x0000055b;
SDRAM[0].EmcFbioCfg5                              = 0x1363a296;
SDRAM[0].EmcFbioCfg6                              = 0x00000000;
SDRAM[0].EmcFbioSpare                             = 0x00000000;
SDRAM[0].EmcCfgRsv                                = 0xff00ff00;
SDRAM[0].EmcMrs                                   = 0x00000000;
SDRAM[0].EmcEmrs                                  = 0x00000000;
SDRAM[0].EmcEmrs2                                 = 0x00000000;
SDRAM[0].EmcEmrs3                                 = 0x00000000;
SDRAM[0].EmcMrw1                                  = 0x80010083;
SDRAM[0].EmcMrw2                                  = 0x80020004;
SDRAM[0].EmcMrw3                                  = 0x80030001;
SDRAM[0].EmcMrw4                                  = 0x800b0000;
SDRAM[0].EmcMrwExtra                              = 0x80010083;
SDRAM[0].EmcWarmBootMrwExtra                      = 0x80020004;
SDRAM[0].EmcWarmBootExtraModeRegWriteEnable       = 0x00000000;
SDRAM[0].EmcExtraModeRegWriteEnable               = 0x00000000;
SDRAM[0].EmcMrwResetCommand                       = 0x803f00fc;
SDRAM[0].EmcMrwResetNInitWait                     = 0x0000000a;
SDRAM[0].EmcMrsWaitCnt                            = 0x00cc0011;
SDRAM[0].EmcMrsWaitCnt2                           = 0x00cc0011;
SDRAM[0].EmcCfg                                   = 0xf3200000;
SDRAM[0].EmcCfg2                                  = 0x000008cf;
SDRAM[0].EmcCfgPipe                               = 0x0000d3b3;
SDRAM[0].EmcDbg                                   = 0x01000c00;
SDRAM[0].EmcCmdQ                                  = 0x10004408;
SDRAM[0].EmcMc2EmcQ                               = 0x06000404;
SDRAM[0].EmcDynSelfRefControl                     = 0x80000713;
SDRAM[0].AhbArbitrationXbarCtrlMemInitDone        = 0x00000001;
SDRAM[0].EmcCfgDigDll                             = 0x005800a0;
SDRAM[0].EmcCfgDigDllPeriod                       = 0x00008000;
SDRAM[0].EmcDevSelect                             = 0x00000002;
SDRAM[0].EmcSelDpdCtrl                            = 0x0004013c;
SDRAM[0].EmcDllXformDqs0                          = 0x00080000;
SDRAM[0].EmcDllXformDqs1                          = 0x00080000;
SDRAM[0].EmcDllXformDqs2                          = 0x00080000;
SDRAM[0].EmcDllXformDqs3                          = 0x00080000;
SDRAM[0].EmcDllXformDqs4                          = 0x00080000;
SDRAM[0].EmcDllXformDqs5                          = 0x00080000;
SDRAM[0].EmcDllXformDqs6                          = 0x00080000;
SDRAM[0].EmcDllXformDqs7                          = 0x00080000;
SDRAM[0].EmcDllXformDqs8                          = 0x00080000;
SDRAM[0].EmcDllXformDqs9                          = 0x00080000;
SDRAM[0].EmcDllXformDqs10                         = 0x00080000;
SDRAM[0].EmcDllXformDqs11                         = 0x00080000;
SDRAM[0].EmcDllXformDqs12                         = 0x00080000;
SDRAM[0].EmcDllXformDqs13                         = 0x00080000;
SDRAM[0].EmcDllXformDqs14                         = 0x00080000;
SDRAM[0].EmcDllXformDqs15                         = 0x00080000;
SDRAM[0].EmcDllXformQUse0                         = 0x00000000;
SDRAM[0].EmcDllXformQUse1                         = 0x00000000;
SDRAM[0].EmcDllXformQUse2                         = 0x00000000;
SDRAM[0].EmcDllXformQUse3                         = 0x00000000;
SDRAM[0].EmcDllXformQUse4                         = 0x00000000;
SDRAM[0].EmcDllXformQUse5                         = 0x00000000;
SDRAM[0].EmcDllXformQUse6                         = 0x00000000;
SDRAM[0].EmcDllXformQUse7                         = 0x00000000;
SDRAM[0].EmcDllXformAddr0                         = 0x00098000;
SDRAM[0].EmcDllXformAddr1                         = 0x00098000;
SDRAM[0].EmcDllXformAddr2                         = 0x00000000;
SDRAM[0].EmcDllXformAddr3                         = 0x00098000;
SDRAM[0].EmcDllXformAddr4                         = 0x00098000;
SDRAM[0].EmcDllXformAddr5                         = 0x00000000;
SDRAM[0].EmcDllXformQUse8                         = 0x00000000;
SDRAM[0].EmcDllXformQUse9                         = 0x00000000;
SDRAM[0].EmcDllXformQUse10                        = 0x00000000;
SDRAM[0].EmcDllXformQUse11                        = 0x00000000;
SDRAM[0].EmcDllXformQUse12                        = 0x00000000;
SDRAM[0].EmcDllXformQUse13                        = 0x00000000;
SDRAM[0].EmcDllXformQUse14                        = 0x00000000;
SDRAM[0].EmcDllXformQUse15                        = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs0                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs1                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs2                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs3                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs4                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs5                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs6                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs7                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs8                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs9                         = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs10                        = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs11                        = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs12                        = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs13                        = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs14                        = 0x00000000;
SDRAM[0].EmcDliTrimTxDqs15                        = 0x00000000;
SDRAM[0].EmcDllXformDq0                           = 0x0008c000;
SDRAM[0].EmcDllXformDq1                           = 0x00088000;
SDRAM[0].EmcDllXformDq2                           = 0x00088000;
SDRAM[0].EmcDllXformDq3                           = 0x00088000;
SDRAM[0].EmcDllXformDq4                           = 0x00008800;
SDRAM[0].EmcDllXformDq5                           = 0x00008800;
SDRAM[0].EmcDllXformDq6                           = 0x00008800;
SDRAM[0].EmcDllXformDq7                           = 0x00008800;
SDRAM[0].WarmBootWait                             = 0x00000001;
SDRAM[0].EmcCttTermCtrl                           = 0x00000802;
SDRAM[0].EmcOdtWrite                              = 0x00000000;
SDRAM[0].EmcOdtRead                               = 0x00000000;
SDRAM[0].EmcZcalInterval                          = 0x00064000;
SDRAM[0].EmcZcalWaitCnt                           = 0x00000017;
SDRAM[0].EmcZcalMrwCmd                            = 0x800a0056;
SDRAM[0].EmcMrsResetDll                           = 0x00000000;
SDRAM[0].EmcZcalInitDev0                          = 0x840a00ff;
SDRAM[0].EmcZcalInitDev1                          = 0x00000000;
SDRAM[0].EmcZcalInitWait                          = 0x00000001;
SDRAM[0].EmcZcalWarmColdBootEnables               = 0x00000003;
SDRAM[0].EmcMrwLpddr2ZcalWarmBoot                 = 0x040a00ab;
SDRAM[0].EmcZqCalDdr3WarmBoot                     = 0x00000000;
SDRAM[0].EmcZcalWarmBootWait                      = 0x00000001;
SDRAM[0].EmcMrsWarmBootEnable                     = 0x00000001;
SDRAM[0].EmcMrsResetDllWait                       = 0x00000000;
SDRAM[0].EmcMrsExtra                              = 0x00000000;
SDRAM[0].EmcWarmBootMrsExtra                      = 0x00000000;
SDRAM[0].EmcEmrsDdr2DllEnable                     = 0x00000000;
SDRAM[0].EmcMrsDdr2DllReset                       = 0x00000000;
SDRAM[0].EmcEmrsDdr2OcdCalib                      = 0x00000000;
SDRAM[0].EmcDdr2Wait                              = 0x00000000;
SDRAM[0].EmcClkenOverride                         = 0x00000000;
SDRAM[0].McDisExtraSnapLevels                     = 0x00000000;
SDRAM[0].EmcExtraRefreshNum                       = 0x00000002;
SDRAM[0].EmcClkenOverrideAllWarmBoot              = 0x00000000;
SDRAM[0].McClkenOverrideAllWarmBoot               = 0x00000000;
SDRAM[0].EmcCfgDigDllPeriodWarmBoot               = 0x00000003;
SDRAM[0].PmcVddpSel                               = 0x00000001;
SDRAM[0].PmcVddpSelWait                           = 0x00000002;
SDRAM[0].PmcDdrPwr                                = 0x00000003;
SDRAM[0].PmcDdrCfg                                = 0x00001000;
SDRAM[0].PmcIoDpd3Req                             = 0x4ffccea7;
SDRAM[0].PmcIoDpd3ReqWait                         = 0x00000000;
SDRAM[0].PmcRegShort                              = 0x0000330f;
SDRAM[0].PmcNoIoPower                             = 0x00000000;
SDRAM[0].PmcPorDpdCtrlWait                        = 0x00000001;
SDRAM[0].EmcXm2CmdPadCtrl                         = 0x00000200;
SDRAM[0].EmcXm2CmdPadCtrl2                        = 0x770c0000;
SDRAM[0].EmcXm2CmdPadCtrl3                        = 0x050c0000;
SDRAM[0].EmcXm2CmdPadCtrl4                        = 0x00000000;
SDRAM[0].EmcXm2CmdPadCtrl5                        = 0x00100100;
SDRAM[0].EmcXm2DqsPadCtrl                         = 0x770c1414;
SDRAM[0].EmcXm2DqsPadCtrl2                        = 0x0130b018;
SDRAM[0].EmcXm2DqsPadCtrl3                        = 0x51451400;
SDRAM[0].EmcXm2DqsPadCtrl4                        = 0x00514514;
SDRAM[0].EmcXm2DqsPadCtrl5                        = 0x00514514;
SDRAM[0].EmcXm2DqsPadCtrl6                        = 0x51451400;
SDRAM[0].EmcXm2DqPadCtrl                          = 0x770c2990;
SDRAM[0].EmcXm2DqPadCtrl2                         = 0x00000000;
SDRAM[0].EmcXm2DqPadCtrl3                         = 0x00000000;
SDRAM[0].EmcXm2ClkPadCtrl                         = 0x77ffc000;
SDRAM[0].EmcXm2ClkPadCtrl2                        = 0x00000404;
SDRAM[0].EmcXm2CompPadCtrl                        = 0x81f1f008;
SDRAM[0].EmcXm2VttGenPadCtrl                      = 0x07070000;
SDRAM[0].EmcXm2VttGenPadCtrl2                     = 0x0000003f;
SDRAM[0].EmcXm2VttGenPadCtrl3                     = 0x015ddddd;
SDRAM[0].EmcAcpdControl                           = 0x00000000;
SDRAM[0].EmcSwizzleRank0ByteCfg                   = 0x00000321;
SDRAM[0].EmcSwizzleRank0Byte0                     = 0x72361054;
SDRAM[0].EmcSwizzleRank0Byte1                     = 0x76325410;
SDRAM[0].EmcSwizzleRank0Byte2                     = 0x14763250;
SDRAM[0].EmcSwizzleRank0Byte3                     = 0x06413572;
SDRAM[0].EmcSwizzleRank1ByteCfg                   = 0x00000321;
SDRAM[0].EmcSwizzleRank1Byte0                     = 0x31607452;
SDRAM[0].EmcSwizzleRank1Byte1                     = 0x20436175;
SDRAM[0].EmcSwizzleRank1Byte2                     = 0x03241756;
SDRAM[0].EmcSwizzleRank1Byte3                     = 0x10463257;
SDRAM[0].EmcDsrVttgenDrv                          = 0x0000003f;
SDRAM[0].EmcTxdsrvttgen                           = 0x00000000;
SDRAM[0].EmcBgbiasCtl0                            = 0x00000008;
SDRAM[0].McEmemAdrCfg                             = 0x00000000;
SDRAM[0].McEmemAdrCfgDev0                         = 0x00080303;
SDRAM[0].McEmemAdrCfgDev1                         = 0x00080303;
SDRAM[0].McEmemAdrCfgBankMask0                    = 0x00001248;
SDRAM[0].McEmemAdrCfgBankMask1                    = 0x00002490;
SDRAM[0].McEmemAdrCfgBankMask2                    = 0x00000920;
SDRAM[0].McEmemAdrCfgBankSwizzle3                 = 0x00000001;
SDRAM[0].McEmemCfg                                = 0x00000800;
SDRAM[0].McEmemArbCfg                             = 0x01000003;
SDRAM[0].McEmemArbOutstandingReq                  = 0x80000040;
SDRAM[0].McEmemArbTimingRcd                       = 0x00000001;
SDRAM[0].McEmemArbTimingRp                        = 0x00000001;
SDRAM[0].McEmemArbTimingRc                        = 0x00000006;
SDRAM[0].McEmemArbTimingRas                       = 0x00000003;
SDRAM[0].McEmemArbTimingFaw                       = 0x00000005;
SDRAM[0].McEmemArbTimingRrd                       = 0x00000001;
SDRAM[0].McEmemArbTimingRap2Pre                   = 0x00000002;
SDRAM[0].McEmemArbTimingWap2Pre                   = 0x00000007;
SDRAM[0].McEmemArbTimingR2R                       = 0x00000003;
SDRAM[0].McEmemArbTimingW2W                       = 0x00000001;
SDRAM[0].McEmemArbTimingR2W                       = 0x00000005;
SDRAM[0].McEmemArbTimingW2R                       = 0x00000005;
SDRAM[0].McEmemArbDaTurns                         = 0x05050103;
SDRAM[0].McEmemArbDaCovers                        = 0x000a0506;
SDRAM[0].McEmemArbMisc0                           = 0x72e40a07;
SDRAM[0].McEmemArbMisc1                           = 0x70000f03;
SDRAM[0].McEmemArbRing1Throttle                   = 0x001f0000;
SDRAM[0].McEmemArbOverride                        = 0x10000000;
SDRAM[0].McEmemArbOverride1                       = 0x00000000;
SDRAM[0].McEmemArbRsv                             = 0xff00ff00;
SDRAM[0].McClkenOverride                          = 0x00000000;
SDRAM[0].McStatControl                            = 0x00000000;
SDRAM[0].McDisplaySnapRing                        = 0x00000003;
SDRAM[0].McVideoProtectBom                        = 0xfff00000;
SDRAM[0].McVideoProtectBomAdrHi                   = 0x00000000;
SDRAM[0].McVideoProtectSizeMb                     = 0x00000000;
SDRAM[0].McVideoProtectVprOverride                = 0xe4bac743;
SDRAM[0].McVideoProtectVprOverride1               = 0x00000013;
SDRAM[0].McVideoProtectGpuOverride0               = 0x00000000;
SDRAM[0].McVideoProtectGpuOverride1               = 0x00000000;
SDRAM[0].McSecCarveoutBom                         = 0xfff00000;
SDRAM[0].McSecCarveoutAdrHi                       = 0x00000000;
SDRAM[0].McSecCarveoutSizeMb                      = 0x00000000;
SDRAM[0].McVideoProtectWriteAccess                = 0x00000000;
SDRAM[0].McSecCarveoutProtectWriteAccess          = 0x00000000;
SDRAM[0].EmcCaTrainingEnable                      = 0x00000001;
SDRAM[0].EmcCaTrainingTimingCntl1                 = 0x09257359;
SDRAM[0].EmcCaTrainingTimingCntl2                 = 0x00000017;
SDRAM[0].SwizzleRankByteEncode                    = 0x0000004c;
SDRAM[0].BootRomPatchControl                      = 0x00000000;
SDRAM[0].BootRomPatchData                         = 0x00000000;
SDRAM[0].McMtsCarveoutBom                         = 0xfff00000;
SDRAM[0].McMtsCarveoutAdrHi                       = 0x00000000;
SDRAM[0].McMtsCarveoutSizeMb                      = 0x00000000;
SDRAM[0].McMtsCarveoutRegCtrl                     = 0x00000000;
#@ MC_MLL_MPCORER_PTSA_RATE {0x7001944c}          = 0x00000001;
#@ MC_PTSA_GRANT_DECREMENT {0x70019960}           = 0x00000062;
#@ MC_LATENCY_ALLOWANCE_XUSB_0 {0x7001937c}       = 0x00ff006d;
#@ MC_LATENCY_ALLOWANCE_XUSB_1 {0x70019380}       = 0x00ff006d;
#@ MC_LATENCY_ALLOWANCE_TSEC_0 {0x70019390}       = 0x00ff003c;
#@ MC_LATENCY_ALLOWANCE_SDMMCA_0 {0x700193b8}     = 0x00ff00af;
#@ MC_LATENCY_ALLOWANCE_SDMMCAA_0 {0x700193bc}    = 0x00ff004f;
#@ MC_LATENCY_ALLOWANCE_SDMMC_0 {0x700193c0}      = 0x00ff00af;
#@ MC_LATENCY_ALLOWANCE_SDMMCAB_0 {0x700193c4}    = 0x00ff004f;
#@ MC_LATENCY_ALLOWANCE_PPCS_0 {0x70019344}       = 0x004e0049;
#@ MC_LATENCY_ALLOWANCE_PPCS_1 {0x70019348}       = 0x00ff0080;
#@ MC_LATENCY_ALLOWANCE_MPCORE_0 {0x70019320}     = 0x00ff0004;
#@ MC_LATENCY_ALLOWANCE_MPCORELP_0 {0x70019324}   = 0x00ff0004;
#@ MC_LATENCY_ALLOWANCE_HC_0 {0x70019310}         = 0x00080057;
#@ MC_LATENCY_ALLOWANCE_HC_1 {0x70019314}         = 0x000000ff;
#@ MC_LATENCY_ALLOWANCE_AVPC_0 {0x700192e4}       = 0x00ff0004;
#@ MC_LATENCY_ALLOWANCE_GPU_0 {0x700193ac}        = 0x00ff0063;
#@ MC_LATENCY_ALLOWANCE_MSENC_0 {0x70019328}      = 0x00ff0036;
#@ MC_LATENCY_ALLOWANCE_HDA_0 {0x70019318}        = 0x00ff0024;
#@ MC_LATENCY_ALLOWANCE_VIC_0 {0x70019394}        = 0x00ff006b;
#@ MC_LATENCY_ALLOWANCE_VI2_0 {0x70019398}        = 0x000000ff;
#@ MC_LATENCY_ALLOWANCE_ISP2_0 {0x70019370}       = 0x00000050;
#@ MC_LATENCY_ALLOWANCE_ISP2_1 {0x70019374}       = 0x00ff00ff;
#@ MC_LATENCY_ALLOWANCE_ISP2B_0 {0x70019384}      = 0x00000050;
#@ MC_LATENCY_ALLOWANCE_ISP2B_1 {0x70019388}      = 0x00ff00ff;
#@ MC_LATENCY_ALLOWANCE_VDE_0 {0x70019354}        = 0x00d400ff;
#@ MC_LATENCY_ALLOWANCE_VDE_1 {0x70019358}        = 0x00510050;
#@ MC_LATENCY_ALLOWANCE_VDE_2 {0x7001935c}        = 0x00ff00ff;
#@ MC_LATENCY_ALLOWANCE_VDE_3 {0x70019360}        = 0x00ff00ff;
#@ MC_LATENCY_ALLOWANCE_SATA_0 {0x70019350}       = 0x00ff00c6;
#@ MC_LATENCY_ALLOWANCE_AFI_0 {0x700192e0}        = 0x00ff006d;
SDRAM[1].MemoryType                               = NvBootMemoryType_LpDdr2;
SDRAM[1].PllMInputDivider                         = 0x00000001;
SDRAM[1].PllMFeedbackDivider                      = 0x0000004d;
SDRAM[1].PllMStableTime                           = 0x0000012c;
SDRAM[1].PllMSetupControl                         = 0x00000000;
SDRAM[1].PllMSelectDiv2                           = 0x00000000;
SDRAM[1].PllMPDLshiftPh45                         = 0x00000001;
SDRAM[1].PllMPDLshiftPh90                         = 0x00000001;
SDRAM[1].PllMPDLshiftPh135                        = 0x00000001;
SDRAM[1].PllMKCP                                  = 0x00000000;
SDRAM[1].PllMKVCO                                 = 0x00000000;
SDRAM[1].EmcBctSpare0                             = 0x00000000;
SDRAM[1].EmcBctSpare1                             = 0x00000000;
SDRAM[1].EmcBctSpare2                             = 0x00000000;
SDRAM[1].EmcBctSpare3                             = 0x00000000;
SDRAM[1].EmcBctSpare4                             = 0x00000000;
SDRAM[1].EmcBctSpare5                             = 0x00000000;
SDRAM[1].EmcBctSpare6                             = 0x00000000;
SDRAM[1].EmcBctSpare7                             = 0x00000000;
SDRAM[1].EmcBctSpare8                             = 0x00000000;
SDRAM[1].EmcBctSpare9                             = 0x00000000;
SDRAM[1].EmcBctSpare10                            = 0x00000000;
SDRAM[1].EmcBctSpare11                            = 0x00000000;
SDRAM[1].EmcClockSource                           = 0x80000000;
SDRAM[1].EmcAutoCalInterval                       = 0x001fffff;
SDRAM[1].EmcAutoCalConfig                         = 0xa1430000;
SDRAM[1].EmcAutoCalConfig2                        = 0x00000000;
SDRAM[1].EmcAutoCalConfig3                        = 0x00000000;
SDRAM[1].EmcAutoCalWait                           = 0x00000190;
SDRAM[1].EmcAdrCfg                                = 0x00000000;
SDRAM[1].EmcPinProgramWait                        = 0x00000000;
SDRAM[1].EmcPinExtraWait                          = 0x00000000;
SDRAM[1].EmcTimingControlWait                     = 0x00000000;
SDRAM[1].EmcRc                                    = 0x00000037;
SDRAM[1].EmcRfc                                   = 0x000000c2;
SDRAM[1].EmcRfcSlr                                = 0x00000000;
SDRAM[1].EmcRas                                   = 0x00000026;
SDRAM[1].EmcRp                                    = 0x00000010;
SDRAM[1].EmcR2r                                   = 0x00000000;
SDRAM[1].EmcW2w                                   = 0x00000000;
SDRAM[1].EmcR2w                                   = 0x0000000f;
SDRAM[1].EmcW2r                                   = 0x00000010;
SDRAM[1].EmcR2p                                   = 0x00000006;
SDRAM[1].EmcW2p                                   = 0x00000017;
SDRAM[1].EmcRdRcd                                 = 0x00000010;
SDRAM[1].EmcWrRcd                                 = 0x00000010;
SDRAM[1].EmcRrd                                   = 0x00000009;
SDRAM[1].EmcRext                                  = 0x00000005;
SDRAM[1].EmcWext                                  = 0x00000000;
SDRAM[1].EmcWdv                                   = 0x00000007;
SDRAM[1].EmcWdvMask                               = 0x00000007;
SDRAM[1].EmcQUse                                  = 0x00000010;
SDRAM[1].EmcQuseWidth                             = 0x00000005;
SDRAM[1].EmcIbdly                                 = 0x00000000;
SDRAM[1].EmcEInput                                = 0x00000005;
SDRAM[1].EmcEInputDuration                        = 0x00000012;
SDRAM[1].EmcPutermExtra                           = 0x000d0000;
SDRAM[1].EmcPutermWidth                           = 0x00000007;
SDRAM[1].EmcPutermAdj                             = 0x00000000;
SDRAM[1].EmcCdbCntl1                              = 0x00000000;
SDRAM[1].EmcCdbCntl2                              = 0x00000000;
SDRAM[1].EmcCdbCntl3                              = 0x00000000;
SDRAM[1].EmcQRst                                  = 0x00000004;
SDRAM[1].EmcQSafe                                 = 0x00000019;
SDRAM[1].EmcRdv                                   = 0x00000020;
SDRAM[1].EmcRdvMask                               = 0x00000022;
SDRAM[1].EmcQpop                                  = 0x00000017;
SDRAM[1].EmcCtt                                   = 0x00000000;
SDRAM[1].EmcCttDuration                           = 0x00000007;
SDRAM[1].EmcRefresh                               = 0x00000dd4;
SDRAM[1].EmcBurstRefreshNum                       = 0x00000000;
SDRAM[1].EmcPreRefreshReqCnt                      = 0x00000375;
SDRAM[1].EmcPdEx2Wr                               = 0x00000006;
SDRAM[1].EmcPdEx2Rd                               = 0x00000006;
SDRAM[1].EmcPChg2Pden                             = 0x00000010;
SDRAM[1].EmcAct2Pden                              = 0x00000000;
SDRAM[1].EmcAr2Pden                               = 0x00000001;
SDRAM[1].EmcRw2Pden                               = 0x0000001b;
SDRAM[1].EmcTxsr                                  = 0x000000cc;
SDRAM[1].EmcTxsrDll                               = 0x000000cc;
SDRAM[1].EmcTcke                                  = 0x00000007;
SDRAM[1].EmcTckesr                                = 0x0000000e;
SDRAM[1].EmcTpd                                   = 0x00000007;
SDRAM[1].EmcTfaw                                  = 0x0000002d;
SDRAM[1].EmcTrpab                                 = 0x00000014;
SDRAM[1].EmcTClkStable                            = 0x00000003;
SDRAM[1].EmcTClkStop                              = 0x00000003;
SDRAM[1].EmcTRefBw                                = 0x00001842;
SDRAM[1].EmcFbioCfg5                              = 0x1363a896;
SDRAM[1].EmcFbioCfg6                              = 0x00000000;
SDRAM[1].EmcFbioSpare                             = 0x00000000;
SDRAM[1].EmcCfgRsv                                = 0xff00ff00;
SDRAM[1].EmcMrs                                   = 0x00000000;
SDRAM[1].EmcEmrs                                  = 0x00000000;
SDRAM[1].EmcEmrs2                                 = 0x00000000;
SDRAM[1].EmcEmrs3                                 = 0x00000000;
SDRAM[1].EmcMrw1                                  = 0x80010083;
SDRAM[1].EmcMrw2                                  = 0x8002001c;
SDRAM[1].EmcMrw3                                  = 0x80030001;
SDRAM[1].EmcMrw4                                  = 0x800b0000;
SDRAM[1].EmcMrwExtra                              = 0x80010083;
SDRAM[1].EmcWarmBootMrwExtra                      = 0x8002001c;
SDRAM[1].EmcWarmBootExtraModeRegWriteEnable       = 0x00000000;
SDRAM[1].EmcExtraModeRegWriteEnable               = 0x00000000;
SDRAM[1].EmcMrwResetCommand                       = 0x803f00fc;
SDRAM[1].EmcMrwResetNInitWait                     = 0x0000000a;
SDRAM[1].EmcMrsWaitCnt                            = 0x039c0019;
SDRAM[1].EmcMrsWaitCnt2                           = 0x039c0019;
SDRAM[1].EmcCfg                                   = 0xf3300000;
SDRAM[1].EmcCfg2                                  = 0x0000089f;
SDRAM[1].EmcCfgPipe                               = 0x00004080;
SDRAM[1].EmcDbg                                   = 0x01000c00;
SDRAM[1].EmcCmdQ                                  = 0x10004408;
SDRAM[1].EmcMc2EmcQ                               = 0x06000404;
SDRAM[1].EmcDynSelfRefControl                     = 0x80001c77;
SDRAM[1].AhbArbitrationXbarCtrlMemInitDone        = 0x00000001;
SDRAM[1].EmcCfgDigDll                             = 0xe00400b9;
SDRAM[1].EmcCfgDigDllPeriod                       = 0x00008000;
SDRAM[1].EmcDevSelect                             = 0x00000002;
SDRAM[1].EmcSelDpdCtrl                            = 0x0004001c;
SDRAM[1].EmcDllXformDqs0                          = 0x00000004;
SDRAM[1].EmcDllXformDqs1                          = 0x00000004;
SDRAM[1].EmcDllXformDqs2                          = 0x00000004;
SDRAM[1].EmcDllXformDqs3                          = 0x00000004;
SDRAM[1].EmcDllXformDqs4                          = 0x00000004;
SDRAM[1].EmcDllXformDqs5                          = 0x00000004;
SDRAM[1].EmcDllXformDqs6                          = 0x00000004;
SDRAM[1].EmcDllXformDqs7                          = 0x00000004;
SDRAM[1].EmcDllXformDqs8                          = 0x00000004;
SDRAM[1].EmcDllXformDqs9                          = 0x00000004;
SDRAM[1].EmcDllXformDqs10                         = 0x00000004;
SDRAM[1].EmcDllXformDqs11                         = 0x00000004;
SDRAM[1].EmcDllXformDqs12                         = 0x00000004;
SDRAM[1].EmcDllXformDqs13                         = 0x00000004;
SDRAM[1].EmcDllXformDqs14                         = 0x00000004;
SDRAM[1].EmcDllXformDqs15                         = 0x00000004;
SDRAM[1].EmcDllXformQUse0                         = 0x00000000;
SDRAM[1].EmcDllXformQUse1                         = 0x00000000;
SDRAM[1].EmcDllXformQUse2                         = 0x00000000;
SDRAM[1].EmcDllXformQUse3                         = 0x00000000;
SDRAM[1].EmcDllXformQUse4                         = 0x00000000;
SDRAM[1].EmcDllXformQUse5                         = 0x00000000;
SDRAM[1].EmcDllXformQUse6                         = 0x00000000;
SDRAM[1].EmcDllXformQUse7                         = 0x00000000;
SDRAM[1].EmcDllXformAddr0                         = 0x0000000f;
SDRAM[1].EmcDllXformAddr1                         = 0x0000000f;
SDRAM[1].EmcDllXformAddr2                         = 0x00000000;
SDRAM[1].EmcDllXformAddr3                         = 0x00000011;
SDRAM[1].EmcDllXformAddr4                         = 0x00000012;
SDRAM[1].EmcDllXformAddr5                         = 0x00000000;
SDRAM[1].EmcDllXformQUse8                         = 0x00000000;
SDRAM[1].EmcDllXformQUse9                         = 0x00000000;
SDRAM[1].EmcDllXformQUse10                        = 0x00000000;
SDRAM[1].EmcDllXformQUse11                        = 0x00000000;
SDRAM[1].EmcDllXformQUse12                        = 0x00000000;
SDRAM[1].EmcDllXformQUse13                        = 0x00000000;
SDRAM[1].EmcDllXformQUse14                        = 0x00000000;
SDRAM[1].EmcDllXformQUse15                        = 0x00000000;
SDRAM[1].EmcDliTrimTxDqs0                         = 0x00000004;
SDRAM[1].EmcDliTrimTxDqs1                         = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs2                         = 0x00000004;
SDRAM[1].EmcDliTrimTxDqs3                         = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs4                         = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs5                         = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs6                         = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs7                         = 0x00000005;
SDRAM[1].EmcDliTrimTxDqs8                         = 0x00000004;
SDRAM[1].EmcDliTrimTxDqs9                         = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs10                        = 0x00000004;
SDRAM[1].EmcDliTrimTxDqs11                        = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs12                        = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs13                        = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs14                        = 0x00000006;
SDRAM[1].EmcDliTrimTxDqs15                        = 0x00000005;
SDRAM[1].EmcDllXformDq0                           = 0x0000000a;
SDRAM[1].EmcDllXformDq1                           = 0x00000009;
SDRAM[1].EmcDllXformDq2                           = 0x00000009;
SDRAM[1].EmcDllXformDq3                           = 0x0000000a;
SDRAM[1].EmcDllXformDq4                           = 0x00000009;
SDRAM[1].EmcDllXformDq5                           = 0x00000009;
SDRAM[1].EmcDllXformDq6                           = 0x00000009;
SDRAM[1].EmcDllXformDq7                           = 0x00000009;
SDRAM[1].WarmBootWait                             = 0x00000001;
SDRAM[1].EmcCttTermCtrl                           = 0x00000802;
SDRAM[1].EmcOdtWrite                              = 0x00000000;
SDRAM[1].EmcOdtRead                               = 0x00000000;
SDRAM[1].EmcZcalInterval                          = 0x00064000;
SDRAM[1].EmcZcalWaitCnt                           = 0x00000058;
SDRAM[1].EmcZcalMrwCmd                            = 0x800a0056;
SDRAM[1].EmcMrsResetDll                           = 0x00000000;
SDRAM[1].EmcZcalInitDev0                          = 0x840a00ff;
SDRAM[1].EmcZcalInitDev1                          = 0x00000000;
SDRAM[1].EmcZcalInitWait                          = 0x00000001;
SDRAM[1].EmcZcalWarmColdBootEnables               = 0x00000003;
SDRAM[1].EmcMrwLpddr2ZcalWarmBoot                 = 0x040a00ab;
SDRAM[1].EmcZqCalDdr3WarmBoot                     = 0x00000000;
SDRAM[1].EmcZcalWarmBootWait                      = 0x00000001;
SDRAM[1].EmcMrsWarmBootEnable                     = 0x00000001;
SDRAM[1].EmcMrsResetDllWait                       = 0x00000000;
SDRAM[1].EmcMrsExtra                              = 0x00000000;
SDRAM[1].EmcWarmBootMrsExtra                      = 0x00000000;
SDRAM[1].EmcEmrsDdr2DllEnable                     = 0x00000000;
SDRAM[1].EmcMrsDdr2DllReset                       = 0x00000000;
SDRAM[1].EmcEmrsDdr2OcdCalib                      = 0x00000000;
SDRAM[1].EmcDdr2Wait                              = 0x00000000;
SDRAM[1].EmcClkenOverride                         = 0x00000000;
SDRAM[1].McDisExtraSnapLevels                     = 0x00000000;
SDRAM[1].EmcExtraRefreshNum                       = 0x00000002;
SDRAM[1].EmcClkenOverrideAllWarmBoot              = 0x00000000;
SDRAM[1].McClkenOverrideAllWarmBoot               = 0x00000000;
SDRAM[1].EmcCfgDigDllPeriodWarmBoot               = 0x00000003;
SDRAM[1].PmcVddpSel                               = 0x00000001;
SDRAM[1].PmcVddpSelWait                           = 0x00000002;
SDRAM[1].PmcDdrPwr                                = 0x00000003;
SDRAM[1].PmcDdrCfg                                = 0x00001000;
SDRAM[1].PmcIoDpd3Req                             = 0x4ffecea7;
SDRAM[1].PmcIoDpd3ReqWait                         = 0x00000000;
SDRAM[1].PmcRegShort                              = 0x0000330f;
SDRAM[1].PmcNoIoPower                             = 0x00000000;
SDRAM[1].PmcPorDpdCtrlWait                        = 0x00000001;
SDRAM[1].EmcXm2CmdPadCtrl                         = 0x00000220;
SDRAM[1].EmcXm2CmdPadCtrl2                        = 0x770c0000;
SDRAM[1].EmcXm2CmdPadCtrl3                        = 0x050c0000;
SDRAM[1].EmcXm2CmdPadCtrl4                        = 0x00000000;
SDRAM[1].EmcXm2CmdPadCtrl5                        = 0x00100100;
SDRAM[1].EmcXm2DqsPadCtrl                         = 0x770c1414;
SDRAM[1].EmcXm2DqsPadCtrl2                        = 0x0120103d;
SDRAM[1].EmcXm2DqsPadCtrl3                        = 0x51451420;
SDRAM[1].EmcXm2DqsPadCtrl4                        = 0x00514514;
SDRAM[1].EmcXm2DqsPadCtrl5                        = 0x00514514;
SDRAM[1].EmcXm2DqsPadCtrl6                        = 0x51451400;
SDRAM[1].EmcXm2DqPadCtrl                          = 0x770c2990;
SDRAM[1].EmcXm2DqPadCtrl2                         = 0x00000000;
SDRAM[1].EmcXm2DqPadCtrl3                         = 0x00000000;
SDRAM[1].EmcXm2ClkPadCtrl                         = 0x77ffc004;
SDRAM[1].EmcXm2ClkPadCtrl2                        = 0x00000404;
SDRAM[1].EmcXm2CompPadCtrl                        = 0x81f1f008;
SDRAM[1].EmcXm2VttGenPadCtrl                      = 0x07070000;
SDRAM[1].EmcXm2VttGenPadCtrl2                     = 0x00000000;
SDRAM[1].EmcXm2VttGenPadCtrl3                     = 0x015ddddd;
SDRAM[1].EmcAcpdControl                           = 0x00000000;
SDRAM[1].EmcSwizzleRank0ByteCfg                   = 0x00000321;
SDRAM[1].EmcSwizzleRank0Byte0                     = 0x72361054;
SDRAM[1].EmcSwizzleRank0Byte1                     = 0x76325410;
SDRAM[1].EmcSwizzleRank0Byte2                     = 0x14763250;
SDRAM[1].EmcSwizzleRank0Byte3                     = 0x06413572;
SDRAM[1].EmcSwizzleRank1ByteCfg                   = 0x00000321;
SDRAM[1].EmcSwizzleRank1Byte0                     = 0x31607452;
SDRAM[1].EmcSwizzleRank1Byte1                     = 0x20436175;
SDRAM[1].EmcSwizzleRank1Byte2                     = 0x03241756;
SDRAM[1].EmcSwizzleRank1Byte3                     = 0x10463257;
SDRAM[1].EmcDsrVttgenDrv                          = 0x0000003f;
SDRAM[1].EmcTxdsrvttgen                           = 0x00000000;
SDRAM[1].EmcBgbiasCtl0                            = 0x00000000;
SDRAM[1].McEmemAdrCfg                             = 0x00000000;
SDRAM[1].McEmemAdrCfgDev0                         = 0x00080303;
SDRAM[1].McEmemAdrCfgDev1                         = 0x00080303;
SDRAM[1].McEmemAdrCfgBankMask0                    = 0x00001248;
SDRAM[1].McEmemAdrCfgBankMask1                    = 0x00002490;
SDRAM[1].McEmemAdrCfgBankMask2                    = 0x00000920;
SDRAM[1].McEmemAdrCfgBankSwizzle3                 = 0x00000001;
SDRAM[1].McEmemCfg                                = 0x00000800;
SDRAM[1].McEmemArbCfg                             = 0x0e00000d;
SDRAM[1].McEmemArbOutstandingReq                  = 0x80000040;
SDRAM[1].McEmemArbTimingRcd                       = 0x00000007;
SDRAM[1].McEmemArbTimingRp                        = 0x00000008;
SDRAM[1].McEmemArbTimingRc                        = 0x0000001b;
SDRAM[1].McEmemArbTimingRas                       = 0x00000012;
SDRAM[1].McEmemArbTimingFaw                       = 0x00000017;
SDRAM[1].McEmemArbTimingRrd                       = 0x00000004;
SDRAM[1].McEmemArbTimingRap2Pre                   = 0x00000004;
SDRAM[1].McEmemArbTimingWap2Pre                   = 0x0000000e;
SDRAM[1].McEmemArbTimingR2R                       = 0x00000004;
SDRAM[1].McEmemArbTimingW2W                       = 0x00000001;
SDRAM[1].McEmemArbTimingR2W                       = 0x00000009;
SDRAM[1].McEmemArbTimingW2R                       = 0x00000009;
SDRAM[1].McEmemArbDaTurns                         = 0x09090104;
SDRAM[1].McEmemArbDaCovers                        = 0x001e141b;
SDRAM[1].McEmemArbMisc0                           = 0x72ae2a1c;
SDRAM[1].McEmemArbMisc1                           = 0x70000f02;
SDRAM[1].McEmemArbRing1Throttle                   = 0x001f0000;
SDRAM[1].McEmemArbOverride                        = 0x10000000;
SDRAM[1].McEmemArbOverride1                       = 0x00000000;
SDRAM[1].McEmemArbRsv                             = 0xff00ff00;
SDRAM[1].McClkenOverride                          = 0x00000000;
SDRAM[1].McStatControl                            = 0x00000000;
SDRAM[1].McDisplaySnapRing                        = 0x00000003;
SDRAM[1].McVideoProtectBom                        = 0xfff00000;
SDRAM[1].McVideoProtectBomAdrHi                   = 0x00000000;
SDRAM[1].McVideoProtectSizeMb                     = 0x00000000;
SDRAM[1].McVideoProtectVprOverride                = 0xe4bac743;
SDRAM[1].McVideoProtectVprOverride1               = 0x00000013;
SDRAM[1].McVideoProtectGpuOverride0               = 0x00000000;
SDRAM[1].McVideoProtectGpuOverride1               = 0x00000000;
SDRAM[1].McSecCarveoutBom                         = 0xfff00000;
SDRAM[1].McSecCarveoutAdrHi                       = 0x00000000;
SDRAM[1].McSecCarveoutSizeMb                      = 0x00000000;
SDRAM[1].McVideoProtectWriteAccess                = 0x00000000;
SDRAM[1].McSecCarveoutProtectWriteAccess          = 0x00000000;
SDRAM[1].EmcCaTrainingEnable                      = 0x00000001;
SDRAM[1].EmcCaTrainingTimingCntl1                 = 0x09257359;
SDRAM[1].EmcCaTrainingTimingCntl2                 = 0x00000017;
SDRAM[1].SwizzleRankByteEncode                    = 0x0000004c;
SDRAM[1].BootRomPatchControl                      = 0x00000000;
SDRAM[1].BootRomPatchData                         = 0x00000000;
SDRAM[1].McMtsCarveoutBom                         = 0xfff00000;
SDRAM[1].McMtsCarveoutAdrHi                       = 0x00000000;
SDRAM[1].McMtsCarveoutSizeMb                      = 0x00000000;
SDRAM[1].McMtsCarveoutRegCtrl                     = 0x00000000;
#@ MC_MLL_MPCORER_PTSA_RATE {0x7001944c}          = 0x00000017;
#@ MC_PTSA_GRANT_DECREMENT {0x70019960}           = 0x000001bb;
#@ MC_LATENCY_ALLOWANCE_XUSB_0 {0x7001937c}       = 0x006e0038;
#@ MC_LATENCY_ALLOWANCE_XUSB_1 {0x70019380}       = 0x006e0038;
#@ MC_LATENCY_ALLOWANCE_TSEC_0 {0x70019390}       = 0x006e003c;
#@ MC_LATENCY_ALLOWANCE_SDMMCA_0 {0x700193b8}     = 0x006e0090;
#@ MC_LATENCY_ALLOWANCE_SDMMCAA_0 {0x700193bc}    = 0x006e0041;
#@ MC_LATENCY_ALLOWANCE_SDMMC_0 {0x700193c0}      = 0x006e0090;
#@ MC_LATENCY_ALLOWANCE_SDMMCAB_0 {0x700193c4}    = 0x006e0041;
#@ MC_LATENCY_ALLOWANCE_PPCS_0 {0x70019344}       = 0x00270049;
#@ MC_LATENCY_ALLOWANCE_PPCS_1 {0x70019348}       = 0x006e0080;
#@ MC_LATENCY_ALLOWANCE_MPCORE_0 {0x70019320}     = 0x006e0004;
#@ MC_LATENCY_ALLOWANCE_MPCORELP_0 {0x70019324}   = 0x006e0004;
#@ MC_LATENCY_ALLOWANCE_HC_0 {0x70019310}         = 0x00080016;
#@ MC_LATENCY_ALLOWANCE_HC_1 {0x70019314}         = 0x0000006e;
#@ MC_LATENCY_ALLOWANCE_AVPC_0 {0x700192e4}       = 0x006e0004;
#@ MC_LATENCY_ALLOWANCE_GPU_0 {0x700193ac}        = 0x006e0019;
#@ MC_LATENCY_ALLOWANCE_MSENC_0 {0x70019328}      = 0x006e0018;
#@ MC_LATENCY_ALLOWANCE_HDA_0 {0x70019318}        = 0x006e0024;
#@ MC_LATENCY_ALLOWANCE_VIC_0 {0x70019394}        = 0x006e001b;
#@ MC_LATENCY_ALLOWANCE_VI2_0 {0x70019398}        = 0x0000006e;
#@ MC_LATENCY_ALLOWANCE_ISP2_0 {0x70019370}       = 0x00000036;
#@ MC_LATENCY_ALLOWANCE_ISP2_1 {0x70019374}       = 0x006e006e;
#@ MC_LATENCY_ALLOWANCE_ISP2B_0 {0x70019384}      = 0x00000036;
#@ MC_LATENCY_ALLOWANCE_ISP2B_1 {0x70019388}      = 0x006e006e;
#@ MC_LATENCY_ALLOWANCE_VDE_1 {0x70019358}        = 0x00510029;
#@ MC_LATENCY_ALLOWANCE_VDE_2 {0x7001935c}        = 0x006e006e;
#@ MC_LATENCY_ALLOWANCE_VDE_3 {0x70019360}        = 0x006e006e;
#@ MC_LATENCY_ALLOWANCE_SATA_0 {0x70019350}       = 0x006e0065;
#@ MC_LATENCY_ALLOWANCE_AFI_0 {0x700192e0}        = 0x006e001c;
SDRAM[2].MemoryType                               = NvBootMemoryType_LpDdr2;
SDRAM[2].PllMInputDivider                         = 0x00000001;
SDRAM[2].PllMFeedbackDivider                      = 0x0000004d;
SDRAM[2].PllMStableTime                           = 0x0000012c;
SDRAM[2].PllMSetupControl                         = 0x00000000;
SDRAM[2].PllMSelectDiv2                           = 0x00000000;
SDRAM[2].PllMPDLshiftPh45                         = 0x00000001;
SDRAM[2].PllMPDLshiftPh90                         = 0x00000001;
SDRAM[2].PllMPDLshiftPh135                        = 0x00000001;
SDRAM[2].PllMKCP                                  = 0x00000000;
SDRAM[2].PllMKVCO                                 = 0x00000000;
SDRAM[2].EmcBctSpare0                             = 0x00000000;
SDRAM[2].EmcBctSpare1                             = 0x00000000;
SDRAM[2].EmcBctSpare2                             = 0x00000000;
SDRAM[2].EmcBctSpare3                             = 0x00000000;
SDRAM[2].EmcBctSpare4                             = 0x00000000;
SDRAM[2].EmcBctSpare5                             = 0x00000000;
SDRAM[2].EmcBctSpare6                             = 0x00000000;
SDRAM[2].EmcBctSpare7                             = 0x00000000;
SDRAM[2].EmcBctSpare8                             = 0x00000000;
SDRAM[2].EmcBctSpare9                             = 0x00000000;
SDRAM[2].EmcBctSpare10                            = 0x00000000;
SDRAM[2].EmcBctSpare11                            = 0x00000000;
SDRAM[2].EmcClockSource                           = 0x80000000;
SDRAM[2].EmcAutoCalInterval                       = 0x001fffff;
SDRAM[2].EmcAutoCalConfig                         = 0xa1430000;
SDRAM[2].EmcAutoCalConfig2                        = 0x00000000;
SDRAM[2].EmcAutoCalConfig3                        = 0x00000000;
SDRAM[2].EmcAutoCalWait                           = 0x00000190;
SDRAM[2].EmcAdrCfg                                = 0x00000001;
SDRAM[2].EmcPinProgramWait                        = 0x00000000;
SDRAM[2].EmcPinExtraWait                          = 0x00000000;
SDRAM[2].EmcTimingControlWait                     = 0x00000000;
SDRAM[2].EmcRc                                    = 0x00000037;
SDRAM[2].EmcRfc                                   = 0x000000c2;
SDRAM[2].EmcRfcSlr                                = 0x00000000;
SDRAM[2].EmcRas                                   = 0x00000026;
SDRAM[2].EmcRp                                    = 0x00000010;
SDRAM[2].EmcR2r                                   = 0x00000000;
SDRAM[2].EmcW2w                                   = 0x00000000;
SDRAM[2].EmcR2w                                   = 0x0000000f;
SDRAM[2].EmcW2r                                   = 0x00000010;
SDRAM[2].EmcR2p                                   = 0x00000006;
SDRAM[2].EmcW2p                                   = 0x00000017;
SDRAM[2].EmcRdRcd                                 = 0x00000010;
SDRAM[2].EmcWrRcd                                 = 0x00000010;
SDRAM[2].EmcRrd                                   = 0x00000009;
SDRAM[2].EmcRext                                  = 0x00000005;
SDRAM[2].EmcWext                                  = 0x00000000;
SDRAM[2].EmcWdv                                   = 0x00000007;
SDRAM[2].EmcWdvMask                               = 0x00000007;
SDRAM[2].EmcQUse                                  = 0x00000010;
SDRAM[2].EmcQuseWidth                             = 0x00000005;
SDRAM[2].EmcIbdly                                 = 0x00000000;
SDRAM[2].EmcEInput                                = 0x00000005;
SDRAM[2].EmcEInputDuration                        = 0x00000012;
SDRAM[2].EmcPutermExtra                           = 0x000d0000;
SDRAM[2].EmcPutermWidth                           = 0x00000007;
SDRAM[2].EmcPutermAdj                             = 0x00000000;
SDRAM[2].EmcCdbCntl1                              = 0x00000000;
SDRAM[2].EmcCdbCntl2                              = 0x00000000;
SDRAM[2].EmcCdbCntl3                              = 0x00000000;
SDRAM[2].EmcQRst                                  = 0x00000004;
SDRAM[2].EmcQSafe                                 = 0x00000019;
SDRAM[2].EmcRdv                                   = 0x00000020;
SDRAM[2].EmcRdvMask                               = 0x00000022;
SDRAM[2].EmcQpop                                  = 0x00000017;
SDRAM[2].EmcCtt                                   = 0x00000000;
SDRAM[2].EmcCttDuration                           = 0x00000007;
SDRAM[2].EmcRefresh                               = 0x00000dd4;
SDRAM[2].EmcBurstRefreshNum                       = 0x00000000;
SDRAM[2].EmcPreRefreshReqCnt                      = 0x00000375;
SDRAM[2].EmcPdEx2Wr                               = 0x00000006;
SDRAM[2].EmcPdEx2Rd                               = 0x00000006;
SDRAM[2].EmcPChg2Pden                             = 0x00000010;
SDRAM[2].EmcAct2Pden                              = 0x00000000;
SDRAM[2].EmcAr2Pden                               = 0x00000001;
SDRAM[2].EmcRw2Pden                               = 0x0000001b;
SDRAM[2].EmcTxsr                                  = 0x000000cc;
SDRAM[2].EmcTxsrDll                               = 0x000000cc;
SDRAM[2].EmcTcke                                  = 0x00000007;
SDRAM[2].EmcTckesr                                = 0x0000000e;
SDRAM[2].EmcTpd                                   = 0x00000007;
SDRAM[2].EmcTfaw                                  = 0x0000002d;
SDRAM[2].EmcTrpab                                 = 0x00000014;
SDRAM[2].EmcTClkStable                            = 0x00000003;
SDRAM[2].EmcTClkStop                              = 0x00000003;
SDRAM[2].EmcTRefBw                                = 0x00001842;
SDRAM[2].EmcFbioCfg5                              = 0x1363a896;
SDRAM[2].EmcFbioCfg6                              = 0x00000000;
SDRAM[2].EmcFbioSpare                             = 0x00000000;
SDRAM[2].EmcCfgRsv                                = 0xff00ff00;
SDRAM[2].EmcMrs                                   = 0x00000000;
SDRAM[2].EmcEmrs                                  = 0x00000000;
SDRAM[2].EmcEmrs2                                 = 0x00000000;
SDRAM[2].EmcEmrs3                                 = 0x00000000;
SDRAM[2].EmcMrw1                                  = 0x00010083;
SDRAM[2].EmcMrw2                                  = 0x0002001c;
SDRAM[2].EmcMrw3                                  = 0x00030001;
SDRAM[2].EmcMrw4                                  = 0x800b0000;
SDRAM[2].EmcMrwExtra                              = 0x00010083;
SDRAM[2].EmcWarmBootMrwExtra                      = 0x0002001c;
SDRAM[2].EmcWarmBootExtraModeRegWriteEnable       = 0x00000000;
SDRAM[2].EmcExtraModeRegWriteEnable               = 0x00000000;
SDRAM[2].EmcMrwResetCommand                       = 0x003f00fc;
SDRAM[2].EmcMrwResetNInitWait                     = 0x0000000a;
SDRAM[2].EmcMrsWaitCnt                            = 0x039c0019;
SDRAM[2].EmcMrsWaitCnt2                           = 0x039c0019;
SDRAM[2].EmcCfg                                   = 0xf3300000;
SDRAM[2].EmcCfg2                                  = 0x0000089f;
SDRAM[2].EmcCfgPipe                               = 0x00004080;
SDRAM[2].EmcDbg                                   = 0x01000c00;
SDRAM[2].EmcCmdQ                                  = 0x10004408;
SDRAM[2].EmcMc2EmcQ                               = 0x06000404;
SDRAM[2].EmcDynSelfRefControl                     = 0x80001c77;
SDRAM[2].AhbArbitrationXbarCtrlMemInitDone        = 0x00000001;
SDRAM[2].EmcCfgDigDll                             = 0xe00400b9;
SDRAM[2].EmcCfgDigDllPeriod                       = 0x00008000;
SDRAM[2].EmcDevSelect                             = 0x00000000;
SDRAM[2].EmcSelDpdCtrl                            = 0x0004001c;
SDRAM[2].EmcDllXformDqs0                          = 0x00000004;
SDRAM[2].EmcDllXformDqs1                          = 0x00000004;
SDRAM[2].EmcDllXformDqs2                          = 0x00000004;
SDRAM[2].EmcDllXformDqs3                          = 0x00000004;
SDRAM[2].EmcDllXformDqs4                          = 0x00000004;
SDRAM[2].EmcDllXformDqs5                          = 0x00000004;
SDRAM[2].EmcDllXformDqs6                          = 0x00000004;
SDRAM[2].EmcDllXformDqs7                          = 0x00000004;
SDRAM[2].EmcDllXformDqs8                          = 0x00000004;
SDRAM[2].EmcDllXformDqs9                          = 0x00000004;
SDRAM[2].EmcDllXformDqs10                         = 0x00000004;
SDRAM[2].EmcDllXformDqs11                         = 0x00000004;
SDRAM[2].EmcDllXformDqs12                         = 0x00000004;
SDRAM[2].EmcDllXformDqs13                         = 0x00000004;
SDRAM[2].EmcDllXformDqs14                         = 0x00000004;
SDRAM[2].EmcDllXformDqs15                         = 0x00000004;
SDRAM[2].EmcDllXformQUse0                         = 0x00000000;
SDRAM[2].EmcDllXformQUse1                         = 0x00000000;
SDRAM[2].EmcDllXformQUse2                         = 0x00000000;
SDRAM[2].EmcDllXformQUse3                         = 0x00000000;
SDRAM[2].EmcDllXformQUse4                         = 0x00000000;
SDRAM[2].EmcDllXformQUse5                         = 0x00000000;
SDRAM[2].EmcDllXformQUse6                         = 0x00000000;
SDRAM[2].EmcDllXformQUse7                         = 0x00000000;
SDRAM[2].EmcDllXformAddr0                         = 0x0000400d;
SDRAM[2].EmcDllXformAddr1                         = 0x0000400d;
SDRAM[2].EmcDllXformAddr2                         = 0x00000000;
SDRAM[2].EmcDllXformAddr3                         = 0x00000011;
SDRAM[2].EmcDllXformAddr4                         = 0x00000011;
SDRAM[2].EmcDllXformAddr5                         = 0x00000000;
SDRAM[2].EmcDllXformQUse8                         = 0x00000000;
SDRAM[2].EmcDllXformQUse9                         = 0x00000000;
SDRAM[2].EmcDllXformQUse10                        = 0x00000000;
SDRAM[2].EmcDllXformQUse11                        = 0x00000000;
SDRAM[2].EmcDllXformQUse12                        = 0x00000000;
SDRAM[2].EmcDllXformQUse13                        = 0x00000000;
SDRAM[2].EmcDllXformQUse14                        = 0x00000000;
SDRAM[2].EmcDllXformQUse15                        = 0x00000000;
SDRAM[2].EmcDliTrimTxDqs0                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs1                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs2                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs3                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs4                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs5                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs6                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs7                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs8                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs9                         = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs10                        = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs11                        = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs12                        = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs13                        = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs14                        = 0x00000004;
SDRAM[2].EmcDliTrimTxDqs15                        = 0x00000004;
SDRAM[2].EmcDllXformDq0                           = 0x00000009;
SDRAM[2].EmcDllXformDq1                           = 0x00000009;
SDRAM[2].EmcDllXformDq2                           = 0x00000009;
SDRAM[2].EmcDllXformDq3                           = 0x00000009;
SDRAM[2].EmcDllXformDq4                           = 0x0000000a;
SDRAM[2].EmcDllXformDq5                           = 0x00000009;
SDRAM[2].EmcDllXformDq6                           = 0x0000000a;
SDRAM[2].EmcDllXformDq7                           = 0x00000009;
SDRAM[2].WarmBootWait                             = 0x00000001;
SDRAM[2].EmcCttTermCtrl                           = 0x00000802;
SDRAM[2].EmcOdtWrite                              = 0x00000000;
SDRAM[2].EmcOdtRead                               = 0x00000000;
SDRAM[2].EmcZcalInterval                          = 0x00064000;
SDRAM[2].EmcZcalWaitCnt                           = 0x00000058;
SDRAM[2].EmcZcalMrwCmd                            = 0x000a0056;
SDRAM[2].EmcMrsResetDll                           = 0x00000000;
SDRAM[2].EmcZcalInitDev0                          = 0x840a00ff;
SDRAM[2].EmcZcalInitDev1                          = 0x440a00ff;
SDRAM[2].EmcZcalInitWait                          = 0x00000001;
SDRAM[2].EmcZcalWarmColdBootEnables               = 0x00000003;
SDRAM[2].EmcMrwLpddr2ZcalWarmBoot                 = 0x040a00ab;
SDRAM[2].EmcZqCalDdr3WarmBoot                     = 0x00000000;
SDRAM[2].EmcZcalWarmBootWait                      = 0x00000001;
SDRAM[2].EmcMrsWarmBootEnable                     = 0x00000001;
SDRAM[2].EmcMrsResetDllWait                       = 0x00000000;
SDRAM[2].EmcMrsExtra                              = 0x00000000;
SDRAM[2].EmcWarmBootMrsExtra                      = 0x00000000;
SDRAM[2].EmcEmrsDdr2DllEnable                     = 0x00000000;
SDRAM[2].EmcMrsDdr2DllReset                       = 0x00000000;
SDRAM[2].EmcEmrsDdr2OcdCalib                      = 0x00000000;
SDRAM[2].EmcDdr2Wait                              = 0x00000000;
SDRAM[2].EmcClkenOverride                         = 0x00000000;
SDRAM[2].McDisExtraSnapLevels                     = 0x00000000;
SDRAM[2].EmcExtraRefreshNum                       = 0x00000002;
SDRAM[2].EmcClkenOverrideAllWarmBoot              = 0x00000000;
SDRAM[2].McClkenOverrideAllWarmBoot               = 0x00000000;
SDRAM[2].EmcCfgDigDllPeriodWarmBoot               = 0x00000003;
SDRAM[2].PmcVddpSel                               = 0x00000001;
SDRAM[2].PmcVddpSelWait                           = 0x00000002;
SDRAM[2].PmcDdrPwr                                = 0x00000003;
SDRAM[2].PmcDdrCfg                                = 0x00001000;
SDRAM[2].PmcIoDpd3Req                             = 0x4ffefef7;
SDRAM[2].PmcIoDpd3ReqWait                         = 0x00000000;
SDRAM[2].PmcRegShort                              = 0x0000330f;
SDRAM[2].PmcNoIoPower                             = 0x00000000;
SDRAM[2].PmcPorDpdCtrlWait                        = 0x00000001;
SDRAM[2].EmcXm2CmdPadCtrl                         = 0x00000220;
SDRAM[2].EmcXm2CmdPadCtrl2                        = 0x770c0000;
SDRAM[2].EmcXm2CmdPadCtrl3                        = 0x050c0000;
SDRAM[2].EmcXm2CmdPadCtrl4                        = 0x00000000;
SDRAM[2].EmcXm2CmdPadCtrl5                        = 0x00100100;
SDRAM[2].EmcXm2DqsPadCtrl                         = 0x770c1414;
SDRAM[2].EmcXm2DqsPadCtrl2                        = 0x0120103d;
SDRAM[2].EmcXm2DqsPadCtrl3                        = 0x5d75d720;
SDRAM[2].EmcXm2DqsPadCtrl4                        = 0x00514514;
SDRAM[2].EmcXm2DqsPadCtrl5                        = 0x00514514;
SDRAM[2].EmcXm2DqsPadCtrl6                        = 0x5d75d700;
SDRAM[2].EmcXm2DqPadCtrl                          = 0x770c2990;
SDRAM[2].EmcXm2DqPadCtrl2                         = 0x00000000;
SDRAM[2].EmcXm2DqPadCtrl3                         = 0x00000000;
SDRAM[2].EmcXm2ClkPadCtrl                         = 0x77ffc004;
SDRAM[2].EmcXm2ClkPadCtrl2                        = 0x00000303;
SDRAM[2].EmcXm2CompPadCtrl                        = 0x81f1f008;
SDRAM[2].EmcXm2VttGenPadCtrl                      = 0x07070000;
SDRAM[2].EmcXm2VttGenPadCtrl2                     = 0x00000000;
SDRAM[2].EmcXm2VttGenPadCtrl3                     = 0x015ddddd;
SDRAM[2].EmcAcpdControl                           = 0x00000000;
SDRAM[2].EmcSwizzleRank0ByteCfg                   = 0x00000321;
SDRAM[2].EmcSwizzleRank0Byte0                     = 0x72361054;
SDRAM[2].EmcSwizzleRank0Byte1                     = 0x76325410;
SDRAM[2].EmcSwizzleRank0Byte2                     = 0x14763250;
SDRAM[2].EmcSwizzleRank0Byte3                     = 0x06413572;
SDRAM[2].EmcSwizzleRank1ByteCfg                   = 0x00000321;
SDRAM[2].EmcSwizzleRank1Byte0                     = 0x31607452;
SDRAM[2].EmcSwizzleRank1Byte1                     = 0x20436175;
SDRAM[2].EmcSwizzleRank1Byte2                     = 0x03241756;
SDRAM[2].EmcSwizzleRank1Byte3                     = 0x10463257;
SDRAM[2].EmcDsrVttgenDrv                          = 0x0000003f;
SDRAM[2].EmcTxdsrvttgen                           = 0x00000000;
SDRAM[2].EmcBgbiasCtl0                            = 0x00000000;
SDRAM[2].McEmemAdrCfg                             = 0x00000001;
SDRAM[2].McEmemAdrCfgDev0
miss click
I search doc’s but i not found docs about rsa sign on t124.
Insei,
From what you described so far, I can tell you this is a long route for development. What are you trying to achieve for your project? My suggestion is to get a known good platform with known good BSP software to start your own development. For instance, getting a working Jetson TK1 platform and download our latest TK1 BSP.
