Hi
I followed the instructions:
to flash the TX2 module on the TX2 Dev Kit.
I found there is two different options for board name:
1- jetson-tx2
2- jetson-tx2-devkit
The corresponding .conf files exist in the Linux_For_Tegra
directory.
I tried both names for flashing:
sudo ./flash.sh jetson-tx2 mmcblk0p1
and
sudo ./flash.sh jetson-tx2-devkit mmcblk0p1
When flashed with jetson-tx2, everything is OK.
But when using jetson-tx2-devkit name, the module is successfully flashed and the initial setup of the ubuntu with mouse/keyboard/HDMI monitor is done with no proeblem. But, the USB0 port do not work! i.e., the L4T drive is not shown in the host machine as is the case in normal condition, and SSH using 192.168.55.1 IP do not work.
It is worth noting that the NVIDIA recommendation is jetson-tx2-devkit name.
Here is the error message during boot time:
L4T version: 32.5.1
