Hi
I have a jetson orin nano devkit. After a failed flashing, the board is now stuck in a reboot loop with an UEFI assertion error (visible only through UART).
Since this failure, every attempt at flashing the QSPI failed, and the board remain “bricked”.
When flashing fails, I get the following messages:
in UART:
[0008.051] E> Failed to load MB2
[0008.054] C> Task 0x46 failed (err: 0x27228311)
[0008.059] E> Top caller module: MB2_PARAMS, error module: LOADER, reason: 0x11, aux_info: 0x83
[0008.067] C> Boot Info Table status dump :
0111100000111000110111111111000000011110000000000000011000001 -
in flash.sh output:
[ 0.4393 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.4402 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 656573201
[ 0.6182 ] Sending applet
[ 0.6417 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
— Error: Reading board information failed.
What can I do to properly flash and restore this board?
Regards
