Board support package flash to Jetson orin nx
I am installing bsp for the first jetson orin nx installation. After typing the ./install.sh --create_default_account command, the process goes smoothly for a while, and I get the following error in step 2. What is the error and how can i fix it?
************************************************ * * * Step 2: Boot the device with flash initrd image * * * ************************************************ ~/JetPack_5.1.1_Linux_JETSON/Linux_for_Tegra/temp_initrdflash/bootloader0 ~/JetPack_5.1.1_Linux_JETSON/Linux_for_Tegra ./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0000-p3509-a02.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd “rcmboot” --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins “psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.imgimg; kernel_dtb tegra234-p3767-0001-p3509-a02.dtb” --secondary_gpt_backup --bct_backup --boot_chain A --instance 1-1 Welcome to Tegra Flash version 1.0.0 Type ? or help for help and q or quit to exit Use ! to execute system commands Entering RCM boot [ 0.0202 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin [ 0.0202 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin [ 0.0202 ] rcm boot with presigned binaries [ 0.0210 ] tegrarcm_v2 --instance 1-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt [ 0.0217 ] BR_CID: 0x80012344705DD4614000000010FE8080 [ 0.0269 ] Sending bct_br [ 0.0308 ] Sending mb1 [ 0.0318 ] Sending psc_bl1 [ 0.0524 ] Sending bct_mb1
[ 0.0649 ] Generating blob for T23x
[ 0.0692 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0755 ] Stat for blob_boot0.imgimg failed
[ 0.0755 ]
Error: Return value 19
Command tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
Cleaning up…
What documents are you referring to?
What L4T version is in use?
Is it a DevKit or a custom carrier board?
it is a custom carrier board. i am referring to avermedia doxuments. The version is 35.3.1.
i applied the following instructions.
  1. Decompress by root
    sudo tar zxf D131OX-R2.2.4.5.1.1.tar.gz
  2. Enter L4T directory
    cd JetPack_5.1.1_Linux_JETSON/Linux_for_Tegra
  3. Select one profile for MIPI CSI camera (optional)
    (default camera setting is appropho_imx179)
    sudo ./setup.sh
    Supported CSI camera profiles:
  1. appropho_imx179
  2. appropho_imx290
  3. appropho_imx290isp
  4. appropho_imx334
  5. appropho_imx334+imx290isp
  6. appropho_imx334thcv
  7. ar0234
  8. no_camera
  9. raspberry_pi_v2
  10. raspberry_pi_v3
  1. Connect a Jetson platform and a host PC(*) through a Micro USB to USB Cable
    • The host PC must be a physical Ubuntu 18.04 PC with x64 CPU, not a virtual machine or Jetson platform.
  2. Enter the recovery mode
    power off → press recovery button → power on → wait 2 seconds → release recovery button
  3. Start to flash BSP
    a. Use default user account. ( user_name/password: nvidia )
    ./install.sh
    b. Create other user name and password as default user
    • Note1: Jetson Orin NX does not have any built-in eMMC to run the kernel and file system.
      You need to use an NVMe or a USB flash device as a storage device.
    • Note2: If you are flashing with a USB flash drive as storage, the USB drive must be at least 64GB.
    1. nvme0n1p1
    2. sda1
Please contact the board vendor for help.
We do not have the same carrier board and cannot help you.
