BodyPoseNet with DeepStream
Currently my DeepStream version is 5.1
I am trying to run BodyPoseNet model with DeepStream test5 app and getting errors, As BodyPoseNet is supported by DeepStream 6.0 , So I applied for early access to DeepStream6.0 as well, but not yet received access . Can you please provide guidence for getting access . TIA.
I’m asking our internal team to check and to approve the access. Please stay tuned.
Thanks @kayccc for quick response.
@kayccc I received access link from NGC but I am not seeing DeepStream 6.0 downloadable on dashboard (NVIDIA NGC)
Please access the NVIDIA DeepStream SDK 6.0 - Early Access | NVIDIA Developer to get the DeepStream SDK 6.0 EA version.
@kayccc Not able to download .deb file when I tried to download it is giving Failed-Server problem .
Which one you can’t download?
Please provid the file name, then we can check it.
From Early access assets option - DeepStream for Servers and Workstations (T4, A100, other NVIDIA GPUs) - there is deb and tar but both are not downloading. @kayccc here is screenshot for more ref-
@kayccc is there any other link from where I can dowload Deepstream- 6.0 .Deb file ?
Can you try again, please?
Maybe there was a hiccup on the server side? Or pleae clear all cache and cookie to try again.
I cleared cookies and cache as well but still having same issue.
@kayccc I have done everything and my other teammate is also checked from different system and location. Also Documentation link is redirecting to (https://devcenter.heroku.com/)(attaching screenshots) … Can you please confirm
Issue should be resovled now, please help to try it again.
Thanks @kayccc . It is working now .
Hi.
Sorry for posting on already solved issue
I would also love to try a BodyPoseNet application with DeepStream 6.0, can I get EA approval?
Hi mikolaj.badocha,
If you have applied the NVIDIA DeepStream SDK 6.0 - Early Access | NVIDIA Developer, you should get approval in couple days.
@kayccc I am trying to use BodyPoseNet with deepstreams-test5-app but not getting any documentation for how to use BodyPoseNet as PGIE/SGIE , I want to try with deployable model so where I can find config file for BodyPoseNet ?
Hi priti,
Please help to initial a new topic. Thanks
I created new one already but not received any suport there https://forums.developer.nvidia.com/t/bodyposenet-model-integration-with-deepstream-6-0/191217
