Hello everybody!
I want to implement boolean GPIO fan control, to use boolean 1 and 0 on GPIO.
When GPIO is 1 (0) external scheme will turn Fan on, when GPIO is 0 (1) - will turn it off.
So I’ve tried to modify basic device-tree to achieve this functionality using FAN_PWM (C16) pin to set PWM for “1” of “0” without medium values.
I’ve modified:
I expected to see “0” on FAN_PWM for 255 value and “1” for 0 value.
But I’ve found what for 255 value FAN_PWM is no always in “0”:
it has a little “peak” for 250ns lengh with frequency of pwm from here:
Can I set up PWM to not do “peaks”, just clear “0”?
Or maybe is there a way just to switch GPIO output with no PWM needed if temperature goes above some value?
Thank you!
Please note that PWM-fan control is bind with the module temperature. You can still control the fan through sysfs. But if the temperature is near the thermalzone, it would be overwritten again.
I’ve tested 256 value for target_pwm but 250ns peak is still there. And also cur_pwm not becomes 256. I think 255 is max…
The matter is that I don’t want to control it through sysfs =) I want the driver and binding with the module temperature to control it.
But a little 250ns “peak” to “1” in PWM signal on FAN_PWM when cur_pwm is 255 is not suitable.
Is it possible to make PWM goes to “0” without “peaks”?
