I have been implementing a driver for a sensor. The communication is done using RS-232 and I have been using a generic RS-232 to USB/UART adapter.
When implementing in my developer machine (x86) I decided to use the boost.asio library to interface with the device with no issues. The driver can poll at high frequency. I am able to send a request and then immediately start reading the buffer. Here it seems the read function blocks (as the documentation states), I read character by character until the end of the transmission char.
When I tested on the Jetson device I started having a lot of issues and the library throwing many exceptions. I can get it working if my program runs much slower. I make a request, wait a while (to make sure there is a response) and then I can read. This really slow downs how fast I can poll data from the device.
Is there any known issues regarding boost/boost.asio and Jetson devices? Any caveats regarding compilation/installation of the library?
I have exactly the same versions of Ubuntu 18.04, libboost-dev(1.65.1) and gcc(7.5.0-3) in both of the mentioned machines (so I’m discarding any versioning issues)
Many thanks.
