Boosting clocks is breaking camera stream
I’m running cameras over GMSL2 on an Xavier NX. Without boosting the clocks, v4l2 will stream at 30fps and the trace looks like this:
 vi-output, ox08-1955    [000] ....   248.772092: tegra_channel_capture_frame: sof:269.968555520
 vi-output, ox08-1955    [000] ....   248.772096: tegra_channel_capture_frame: eof:270.206176
     kworker/2:1-47      [002] ....   248.803766: rtcpu_vinotify_event: tstamp:8437023306 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:269968843552 data:0xcd9ce20010000000
     kworker/2:1-47      [002] ....   248.803768: rtcpu_vinotify_event: tstamp:8437023459 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:269968887008 data:0x00000000310009f2
     kworker/2:1-47      [002] ....   248.803776: rtcpu_vinotify_event: tstamp:8437567117 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:270000156384 data:0x00000000086f0002
     kworker/2:1-47      [002] ....   248.803777: rtcpu_vinotify_event: tstamp:8437567286 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:270000157248 data:0x0000000000000000
     kworker/2:1-47      [002] ....   248.803777: rtcpu_vinotify_event: tstamp:8437567459 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:270000177536 data:0x00000000020209f1
     kworker/2:1-47      [002] ....   248.803778: rtcpu_vinotify_event: tstamp:8437567612 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:270000206112 data:0x0000000000000020
     kworker/2:1-47      [002] ....   248.803778: rtcpu_vinotify_event: tstamp:8437567790 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:270000206176 data:0x0000000800000000
     kworker/2:1-47      [002] ....   248.803779: rtcpu_vinotify_event: tstamp:8437567939 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:270000242560 data:0x00000000000209f1
     kworker/2:1-47      [002] ....   248.803786: rtcpu_vinotify_event: tstamp:8437568110 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:270001801280 data:0x0000000000000010
     kworker/2:1-47      [002] ....   248.803787: rtcpu_vinotify_event: tstamp:8437568263 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:270001801344 data:0x0000000800000000
     kworker/2:1-47      [002] ....   248.803788: rtcpu_vinotify_event: tstamp:8437568433 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:270001863104 data:0x0000000000000001
     kworker/2:1-47      [002] ....   248.803789: rtcpu_vinotify_event: tstamp:8437568582 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:270001873888 data:0x00000000080209f2
     kworker/2:1-47      [002] ....   248.803789: rtcpu_vinotify_event: tstamp:8438108300 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:270002207360 data:0xcd9ce50010000000
     kworker/2:1-47      [002] ....   248.803790: rtcpu_vinotify_event: tstamp:8438108454 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:270002250816 data:0x00000000310009f3
 vi-output, ox08-1955    [000] ....   248.805226: tegra_channel_capture_frame: sof:270.1863104
 vi-output, ox08-1955    [000] ....   248.805229: tegra_channel_capture_frame: eof:270.33513792
 vi-output, ox08-1955    [000] ....   248.838685: tegra_channel_capture_frame: sof:270.35170720
 vi-output, ox08-1955    [000] ....   248.838689: tegra_channel_capture_frame: eof:270.66821408
when I boost the clocks to max and limit the rate using
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
The v4l2-ctl stream jams up and I get this in the trace:
     kworker/2:1-47      [002] ....   161.551789: rtcpu_vinotify_event: tstamp:5711557174 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:182766733440 data:0x00000000000000a0
     kworker/2:1-47      [002] ....   161.551790: rtcpu_vinotify_event: tstamp:5711557345 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:182766733440 data:0x0000000000000010
     kworker/2:1-47      [002] ....   161.551791: rtcpu_vinotify_event: tstamp:5711557493 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:182766795552 data:0x0000000000000589
     kworker/2:1-47      [002] ....   161.653760: rtcpu_vinotify_error: tstamp:5714589142 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:182866656192 data:0x00000000000000a0
     kworker/2:1-47      [002] ....   161.653763: rtcpu_vinotify_error: tstamp:5714590175 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:182866718304 data:0x0000000000000589
     kworker/2:1-47      [002] ....   161.653765: rtcpu_vinotify_event: tstamp:5714812138 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:182866656192 data:0x00000000000000a0
     kworker/2:1-47      [002] ....   161.653766: rtcpu_vinotify_event: tstamp:5714812292 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:182866656192 data:0x0000000000000010
echo’ing 0’s back into the files fixes it again
It looks like it gets FE errors? What could be going wrong here?
Please share which release you are using, Jetpack 4.6.3 or 5.1. And please disable trace log and see if it works.
Jetpack 5.1 and disabling trace logs doesn’t work unfortunately
If you don’t enable it, are you able to capture raw frames through v4l2-ctl command? If the device tree and driver are ready, you shall not need to manually set up the nodes.
Yes I can capture without tracing enabled.
I don’t quite follow this line, we have the device tree and driver, i’m just using the trace to debug because boosting the clocks changes what shows up in the trace.
There might be misunderstanding. Please make sure which cases succeeds or fails:
  1. Run v4l2-ctl command on default Jetpack 5.1
  2. Run v4l2-ctl command with boosting clocks
  3. Run v4l2-ctl command with boosting clocks + enable trace log
  1. works
  2. does not work
  3. does not work
to narrow it down further, its specifically
echo 0 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked`
that fixes it and
that breaks it
Do you hit performance issue in your use-case? If 1 is good you should not need to boost the clocks.
