Originally published at: https://developer.nvidia.com/blog/boosting-dynamic-programming-performance-using-nvidia-hopper-gpu-dpx-instructions/
Dynamic programming (DP) is a well-known algorithmic technique and a mathematical optimization that has been used for several decades to solve groundbreaking problems in computer science. An example DP use case is route optimization with hundreds or thousands of constraints or weights using the Floyd-Warshall all-pair shortest paths algorithm. Another use case is the alignment…
