Hello I am using an AGX Xavier Developer Kit. I flashed it to JetPack 4.5.1 and gives an RAMDISK error after I run the sudo apt-get upgrade. I checked the other topics on same issue but the only official solution is upgrading the JetPack version.
In my situation, I am using Leopard Imaging IMX577 cameras and 4CAM adapter board. Cameras’ drivers are working only on JetPack 4.5.1 so need to make my AGX Xavier work on JetPack4.5.1.
Is there a solution on this? Any help will be appreciated. Thanks in advance.
Hello JerryChang thank you for your answer.
I installed JetPack both using SDK Manager and ./flash.sh seperately. Same error occured after I run apt upgrade.
At the end of the apt upgrade command there is a warning: “Couldn’t identify filesystem type for fsck hook, ignoring”
Also when I run the update-initramfs -u there is an error like this.
As I noted in first entry, the driver of cameras I bought from Leopard Imaging works on only JP4.5.1, I am wondering any idea to solve this issue.
