Hello
I’m testing the Nano dev kit
I’ve installed the OS following the user guide : “developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit” this morning. It has booted correctly.
But after an apt upgrade, boot fails with error about i2c probe.
Please see the log from the serial port :
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.09.09 13:42:58 =~=~=~=~=~=~=~=~=~=~=~=
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.140] Power-up reason: pmc por
[0000.143] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.149] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.158] max77620 disabling SD1 Remote Sense
[0000.162] Setting DDR voltage to 1125mv
[0000.166] Serial Number of Pmic Max77663: 0x1b0de1
[0000.174] Entering ramdump check
[0000.177] Get RamDumpCarveOut = 0x0
[0000.180] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.185] Last reboot was clean, booting normally!
[0000.190] Sdram initialization is successful
[0000.194] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.200] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.206] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.212] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.229] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.235] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.251] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.327] Csd NumOfBlocks=61071360
[0000.332] Set High speed to 1
[0000.342] Using GPT Primary to query partitions
[0000.346] Loading Tboot-CPU binary
[0000.359] Verifying TBC in OdmNonSecureSBK mode
[0000.369] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.376] Bootloader downloaded successfully.
[0000.380] Downloaded Tboot-CPU binary to 0xa0000258
[0000.385] MAX77620_GPIO5 configured
[0000.389] CPU power rail is up
[0000.391] CPU clock enabled
[0000.395] Performing RAM repair
[0000.398] Updating A64 Warmreset Address to 0xa00002e9
[0000.403] Loading NvTbootBootloaderDTB
[0000.439] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.504] Bootloader DTB Load Address: 0x83000000
[0000.509] Loading NvTbootKernelDTB
[0000.545] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.609] Kernel DTB Load Address: 0x83100000
[0000.614] Loading cboot binary
[0000.658] Verifying EBT in OdmNonSecureSBK mode
[0000.701] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.708] Bootloader downloaded successfully.
[0000.712] Next binary entry address: 0x92c00258
[0000.717] BoardId: 3448
[0000.721] Overriding pmu board id with proc board id
[0000.726] Display board id is not available
[0000.768] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.820] /bpmp deleted
[0000.822] SC7EntryFw header found loaded at 0xff700000
[0001.010] OVR2 PMIC
[0001.012] Bpmp FW successfully loaded
[0001.016] WB0 init successfully at 0xff780000
[0001.020] Set NvDecSticky Bits
[0001.024] GSC2 address ff53fffc value c0edbbcc
[0001.030] GSC MC Settings done
[0001.034] TOS Image length 53680
[0001.037] Monitor size 53680
[0001.039] OS size 0
[0001.048] Secure Os AES-CMAC Verification Success!
[0001.052] TOS image cipher info: plaintext
[0001.056] Loading and Validation of Secure OS Successful
[0001.072] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.077] NvTbootPackSdramParams: start.
[0001.082] NvTbootPackSdramParams: done.
[0001.086] Tegraboot started after 53778 us
[0001.090] Basic modules init took 694680 us
[0001.094] NvTbootQspiFlashIoctl: Opcode = 1 not supported
[0001.099] Sec Bootdevice Read Time = 622327755 ms, Read Size = 622327755 KB
[0001.106] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.111] Storage Device Read Time = 165 ms, Read Size = 2241 KB
[0001.117] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.122] Next stage binary read took 38096 us
[0001.127] Carveout took -49760 us
[0001.130] CPU initialization took 375375 us
[0001.134] Total time taken by TegraBoot 1058391 us
[0001.139] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 16:52:46, Jul 16 2019
ERROR: Error initializing runtime service trusty_fast
[0001.261] RamCode = 0
[0001.266] LPDDR4 Training: Read DT: Number of tables = 2
[0001.271] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.283] EMC Training Successful
[0001.286] 408000 not found in DVFS table
[0001.293] RamCode = 0
[0001.296] DT Write: emc-table@204000 succeeded
[0001.302] DT Write: emc-table@1600000 succeeded
[0001.306] LPDDR4 Training: Write DT: Number of tables = 2
[0001.346]
[0001.347] Debug Init done
[0001.350] Marked DTB cacheable
[0001.353] Bootloader DTB loaded at 0x83000000
[0001.358] Marked DTB cacheable
[0001.360] Kernel DTB loaded at 0x83100000
[0001.364] DeviceTree Init done
[0001.376] Pinmux applied successfully
[0001.381] gicd_base: 0x50041000
[0001.384] gicc_base: 0x50042000
[0001.387] Interrupts Init done
[0001.391] Using base:0x60005090 & irq:208 for tick-timer
[0001.396] Using base:0x60005098 for delay-timer
[0001.401] platform_init_timer: DONE
[0001.404] Timer(tick) Init done
[0001.408] osc freq = 38400 khz
[0001.412]
[0001.413] welcome to cboot
[0001.416]
[0001.417] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.422] calling constructors
[0001.425] initializing heap
[0001.428] initializing threads
[0001.430] initializing timers
[0001.433] creating bootstrap completion thread
[0001.438] top of bootstrap2()
[0001.441] CPU: ARM Cortex A57
[0001.443] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.448] initializing platform
[0001.451] Scratch reg 37 & 271 initial value set..
[0001.458] cboot:secure-pmc present
[0001.461] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.465] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.470] Macronix QSPI chip present
[0001.473] SPI device register
[0001.476] init boot device
[0001.479] allocating memory for boot device(SPI)
[0001.483] registering boot device
[0001.493] sdmmc node status = okay
[0001.496] sdcard instance = 0
[0001.499] sdcard gpio handle 0x56
[0001.502] sdcard gpio pin 0xc9
[0001.505] sdcard gpio flags 0x0
[0001.508] vmmc-supply 0x99
[0001.511] Instance: 0
[0001.513] Allocating memory for context
[0001.517] enabling clock
[0001.519] sd card init
[0001.521] Check card present and stable
[0001.525] Send command 0
[0001.542] Send command 3
[0001.546] Set RCA for the card
[0001.549] Query card specific data by command 9
[0001.555] Parse CSD data
[0001.558] Send command 7
[0001.568] Calling sd device register
[0001.571] Init sdcard
[0001.574] Allocating memory for boot device
[0001.578] Registering user device
[0001.591] Enable APE clock
[0001.593] Un-powergate APE partition
[0001.597] of_register: registering tegra_udc to of_hal
[0001.602] of_register: registering tegra_udc to of_hal
[0001.607] of_register: registering inv20628-driver to of_hal
[0001.613] of_register: registering ads1015-driver to of_hal
[0001.618] of_register: registering lp8557-bl-driver to of_hal
[0001.624] of_register: registering bq2419x_charger to of_hal
[0001.630] of_register: registering cpc to of_hal
[0001.634] of_register: registering bq27441_fuel_gauge to of_hal
[0001.646] gpio framework initialized
[0001.649] of_register: registering tca9539_gpio to of_hal
[0001.654] of_register: registering tca9539_gpio to of_hal
[0001.660] of_register: registering i2c_bus_driver to of_hal
[0001.665] of_register: registering i2c_bus_driver to of_hal
[0001.671] of_register: registering i2c_bus_driver to of_hal
[0001.676] of_register: registering i2c_bus_driver to of_hal
[0001.682] pmic framework initialized
[0001.686] of_register: registering max77620_pmic to of_hal
[0001.691] regulator framework initialized
[0001.695] of_register: registering tps65132_bl_driver to of_hal
[0001.701] initializing target
[0001.707] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.715] fixed regulator driver initialized
[0001.732] initializing OF layer
[0001.735] NCK carveout not present
[0001.738] Skipping dts_overrides
[0001.743] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.759] I2C Bus Init done
[0001.762] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.772] I2C Bus Init done
[0001.775] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.785] I2C Bus Init done
[0001.787] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.798] I2C Bus Init done
[0001.800] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.811] I2C Bus Init done
[0001.813] of_children_init: Ops found for compatible string maxim,max77620
[0001.823] max77620_init using irq 118
[0001.828] register 'maxim,max77620' pmic
[0001.832] gpio_driver_register: register 'max77620-gpio' driver
[0001.839] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.849] I2C Bus Init done
[0001.853] NCK carveout not present
[0001.856] shim_invoke: No NCT, Calling dts updates
[0001.867] Find /i2c@7000c000's alias i2c0
[0001.871] get eeprom at 1-a0, size 256, type 0
[0001.880] Find /i2c@7000c500's alias i2c2
[0001.884] get eeprom at 3-a0, size 256, type 0
[0001.888] get eeprom at 3-ae, size 256, type 0
[0001.893] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.898] I2C slave not started
[0001.901] I2C write failed
[0001.903] Writing offset failed
[0001.907] eeprom_init: EEPROM read failed
[0001.910] pm_ids_update: eeprom init failed
[0001.915] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.945] pm_ids_update: The pm board id is 3448-0000-200
[0001.951] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0001.959] pm_ids_update: pm id update successful
[0001.963] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.994] pm_ids_update: The pm board id is 3449-0000-200
[0002.000] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.007] pm_ids_update: pm id update successful
[0002.038] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.044] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.052] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.058] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.066] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:4c:86
[0002.073] Plugin Manager: Parse ODM data 0x00094000
[0002.083] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.104] Find /i2c@7000c000's alias i2c0
[0002.108] get eeprom at 1-a0, size 256, type 0
[0002.117] Find /i2c@7000c500's alias i2c2
[0002.120] get eeprom at 3-a0, size 256, type 0
[0002.125] get eeprom at 3-ae, size 256, type 0
[0002.129] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.134] I2C slave not started
[0002.137] I2C write failed
[0002.140] Writing offset failed
[0002.143] eeprom_init: EEPROM read failed
[0002.147] pm_ids_update: eeprom init failed
[0002.151] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.181] pm_ids_update: The pm board id is 3448-0000-200
[0002.188] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.195] pm_ids_update: pm id update successful
[0002.199] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.229] pm_ids_update: The pm board id is 3449-0000-200
[0002.236] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.243] pm_ids_update: pm id update successful
[0002.273] Chip UID is 00000001644495810c00000008018180
[0002.278] Add serial number:14220190847940808101 as DT property
[0002.287] Applying platform configs
[0002.293] platform-init is not present. Skipping
[0002.298] calling apps_init()
[0002.323] Found 12 GPT partitions in "sd0"
[0002.327] Proceeding to Cold Boot
[0002.330] starting app android_boot_app
[0002.334] Device state: unlocked
[0002.337] display console init
[0002.345] could not find regulator
[0002.349] hdmi cable connected
[0002.364] edid read success
[0002.379] edid read success
[0002.382] widDT entry for leds-pwm not found
t[0002.390] h = 640, height = 480, frequency = 25174825
[0002.395] width = 640, height = 480, frequency = 25174825
[0002.400] width = 640, height = 480, frequency = 25174825
[0002.405] width = 640, height = 480, frequency = 25174825
[0002.411] width = 1920, height = 1080, frequency = 148500000
[0002.416] width = 1920, height = 1080, frequency = 148500000
[0002.422] width = 640, height = 480, frequency = 25174825
[0002.427] width = 720, height = 480, frequency = 26973026
[0002.433] width = 720, height = 480, frequency = 26973026
[0002.438] width = 1920, height = 1080, frequency = 148351648
[0002.444] width = 720, height = 576, frequency = 26973026
[0002.449] width = 720, height = 576, frequency = 26973026
[0002.455] width = 1280, height = 720, frequency = 74175824
[0002.460] width = 1920, height = 1080, frequency = 148351648
[0002.466] width = 1280, height = 720, frequency = 74175824
[0002.471] width = 1920, height = 1080, frequency = 74175824
[0002.477] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.484] tmds-config node not found
[0002.488] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.503] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.511] could not find regulator
[0002.514] could not find regulator
[0002.517] could not find regulator
[0002.546] using default cmu settings
[0002.549] dc_hdmi_enable, starting HDMI initialisation
[0002.555] dc_hdmi_enable, HDMI initialisation complete
[0002.560] list and configure display window
[0002.569] display console init completed
[0002.580] subnode volume_up is not found !
[0002.584] subnode back is not found !
[0002.588] subnode volume_down is not found !
[0002.592] subnode menu is not found !
[0002.596] Gpio keyboard init success
[0002.628] found decompressor handler: lz4-legacy
[0002.642] decompressing blob (type 1)...
[0002.677] load_bmp_blob: panelresolution=1080 type=3
[0002.717] decompressor handler not found
[0002.720] load_firmware_blob: Firmware blob loaded, entries=2
[0002.726] se_aes_verify_sbk_clear: Error
[0002.730] bl_battery_charging: connected to external power supply
[0002.737] xusb is supported
[0002.743] error while finding nvidia,portmap
[0002.749] could not find regulator
[0003.252] xusb blob version 0 size 124416
[0003.256] firmware size 124416
[0003.261] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0003.273] xhci0: 64 bytes context size, 32-bit DMA
[0003.313] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.333] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.983] uhub0: 9 ports with 9 removable, self powered
[0004.983] failed to get HID devices
[0004.987] failed to init xhci or no usb device attached
[0004.994] device_query_partition_size: failed to open partition sd0:MSC !
[0005.001] MSC Partition not found
[0005.004] device_query_partition_size: failed to open partition sd0:USP !
[0005.011] USP partition read failed!
[0005.014] blob_init: blob-partition USP header read failed
[0005.020] android_boot Unable to update recovery partition
[0005.025] kfs_getpartname: name = LNX
[0005.029] Loading kernel from LNX
[0005.086] Verifying boot image in OdmNonSecureSBK mode
[0005.130] kernel load address: 0x80080000, size: 482032 bytes
[0005.135] ramdisk load address: 0x84100000, size: 0 bytes
[0005.141] load kernel from storage
[0005.152] decompressor handler not found
[0005.210] Successfully loaded kernel and ramdisk images
[0005.216] load_bmp_blob: panelresolution=1080 type=3
[0005.711] display bmp image done
[0005.714] NCK carveout not present
[0005.717] Skipping dts_overrides
[0005.720] NCK carveout not present
[0005.724] shim_invoke: No NCT, Calling dts updates
[0005.735] Find /i2c@7000c000's alias i2c0
[0005.739] get eeprom at 1-a0, size 256, type 0
[0005.748] Find /i2c@7000c500's alias i2c2
[0005.751] get eeprom at 3-a0, size 256, type 0
[0005.756] get eeprom at 3-ae, size 256, type 0
[0005.760] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.766] I2C slave not started
[0005.769] I2C write failed
[0005.771] Writing offset failed
[0005.774] eeprom_init: EEPROM read failed
[0005.778] pm_ids_update: eeprom init failed
[0005.782] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.812] pm_ids_update: The pm board id is 3448-0000-200
[0005.819] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.827] pm_ids_update: pm id update successful
[0005.831] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.861] pm_ids_update: The pm board id is 3449-0000-200
[0005.868] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0005.875] pm_ids_update: pm id update successful
[0005.906] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.912] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.920] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.926] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.934] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:4c:86
[0005.940] Plugin Manager: Parse ODM data 0x00094000
[0005.950] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.965] Add serial number:14220190847940808101 as DT property
[0005.975] "bpmp" doesn't exist, creating
[0005.980] Updated bpmp info to DTB
[0005.985] Updated initrd info to DTB
[0005.988] "proc-board" doesn't exist, creating
[0005.994] Updated board info to DTB
[0005.997] "pmu-board" doesn't exist, creating
[0006.003] Updated board info to DTB
[0006.006] "display-board" doesn't exist, creating
[0006.012] Updated board info to DTB
[0006.015] "reset" doesn't exist, creating
[0006.019] Updated reset info to DTB
[0006.023] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb7000 is_hdmi_initialised=1
[0006.062] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.074] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0006.087] Updated bootarg info to DTB
[0006.091] Adding uuid 00000001644495810c00000008018180 to DT
[0006.097] Adding eks info 0 to DT
[0006.102] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0006.108] Updated memory info to DTB
[0006.114] Updated system-lp0-disable info to DTB
[0006.122] set vdd_core voltage to 1125 mv
[0006.126] setting 'vdd-core' regulator to 1125000 micro volts
[0006.143] could not find regulator
[0006.147] Found secure-pmc; disable BPMP
U-Boot 2016.07-gd917e08cec (Jul 16 2019 - 16:52:59 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 84 ms (7.8 KiB/s)
L4T boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
5562393 bytes read in 366 ms (14.5 MiB/s)
Retrieving file: /boot/Image
34179080 bytes read in 1557 ms (20.9 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb7000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 0000000083177282
Starting kernel ...
<hit enter to activate fiq debugger>
[ 1.091735] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.243933] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.243962] imx219 6-0010: board setup failed
[ 15.846338] mmc0: Data timeout error
[ 15.849937] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 15.855795] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 15.861651] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000010
[ 15.867507] sdhci: Argument: 0x00006000 | Trn mode: 0x00000023
[ 15.873362] sdhci: Present: 0x01eb0000 | Host ctl: 0x00000017
[ 15.879217] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 15.885071] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 15.890926] sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
[ 15.896780] sdhci: Int enab: 0x02ff100b | Sig enab: 0x02fc100b
[ 15.902635] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 15.908491] sdhci: Caps: 0x376cd08c | Caps_1: 0x10006f73
[ 15.914345] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 15.920200] sdhci: Host ctl2: 0x00003009
[ 15.924139] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe410
[ 15.930713] sdhci: ===========================================
[ 28.018788] mmc0: Timeout waiting for hardware interrupt.
[ 28.024222] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 28.030079] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 28.035934] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000010
[ 28.041790] sdhci: Argument: 0x00000000 | Trn mode: 0x00000023
[ 28.047646] sdhci: Present: 0x01eb0107 | Host ctl: 0x00000017
[ 28.053501] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 28.059355] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 28.065210] sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
[ 28.071066] sdhci: Int enab: 0x02ff100b | Sig enab: 0x02fc100b
[ 28.076922] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 28.082777] sdhci: Caps: 0x376cd08c | Caps_1: 0x10006f73
[ 28.088632] sdhci: Cmd: 0x00000c1b | Max curr: 0x00000000
[ 28.094486] sdhci: Host ctl2: 0x00003009
[ 28.098425] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe410
[ 28.104996] sdhci: ===========================================
After this, it stop the boot (not freeze, I can still use the keyboard)
on Hdmi screen, I see the Nvidia logo, and the end of the console log.
There is only hmdi screen, mouse, keyboard and ethernet cable plugged.
