Boot Failure on Orin NX (fuses are burn - Secure boot enabled)
Hi everyone,
I am experiencing a boot failure.
My device is a Jetson Orin NX (fuses are burned / secure boot enabled). I had successfully flashed the image, and the system had been running smoothly for a long time. However, during a recent reboot, I encountered the following error, and the system now drops directly into the maintenance shell interface.
Could you please assist me in debugging this issue? I have attached my log output below.
Thank you in advance for your support.
boot_issue_orin_nx.txt (37.0 KB)
hello kingssize19,
according to the logs, it seems you’ve switch to boot from ethernet?
please try update the boot orders, see-also.. Customizing the Default Boot Order in the UEFI Menu.
