Initially the ‘NVIDIA Jetson AGX Xavier Developer Kit’ was booting fine with the default image.
Later, the board booting is failing with the following error message.
0000.290] E> Task 49 failed (err: 0x7979061c)
[0000.295] E> Top caller module: ALIASCHECKER, error module: ALIASCHECKER, reason: 0x1c, aux_info: 0x06
[0000.303] I> MB1(1.5.1.2-t194-41334769-9ec1833d) BIT boot status dump :
0000000000011111111110111111111111111111111001111100000000000000000000000000000000000000000000000000000000000000000000000000000011011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0000.334] I> Reset to recovery mode
Requesting the suggestion for fixing the boot issue.
Thank you for the link. Based on the debugging mechanism indicated, please find attached the failure in microboot1 on booting the board. Could you kindly help in letting us know what could lead to this issue.
Based on the debugging mechanism indicated during flashing of the board, please find attached the failure log taken from the board’s console as well as the terminal logs exported from the sdkmanager during the flashing procedure.
Could you kindly share your suggestions/comments regarding the cause of the failure.
Based on the debugging mechanism indicated during flashing of the board, please find attached the failure log taken from the board’s console as well as the logs generated by the “flash script” during the flashing procedure.
The flash script was run using the command “sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1”.
We did not do anything specific. Could you kindly let us know what failure could lead to this issue. Before the failure started, we had captured the log when the board was working fine.
On comparing the working log vs the failure log at the point of failure, we see:
Could you kindly let us know whether any operation related to eMMC is failing. If not, could you kindly let us know what operation is being performed at the time of failure.
Hello Wayne,
Our main purpose is evaluation of eMMC devices with the AGX Xavier Developer Kit.
In order to identify the location of eMMC device on this developer Kit, our trained HW Engineer removed the outer casing and the Heatsink.
Other than that, we did not make any other alteration on the board.
After this, we noticed that the Developer Kit is not booting. The boot error is already shared in the ticket.
Requesting your suggestion for fixing this issue.
