Issue closed as it has been resolved. Thanks
Related topics
| Jetson TX2 Ethernet module doesn't work after update to L4T 32.6.1 | 11 | 2247 | October 18, 2021 | |
| Lost Ethernet on upgrade from r32.4.3 to r37.7.1 | 3 | 756 | October 12, 2022 | |
| Ethernet port (eth0) not working after Jetpack 4.6.3 update | 12 | 766 | March 21, 2023 | |
| After the OTA upgrade, the eth0 network card (with lspci) is lost | 10 | 590 | September 19, 2021 | |
| OTA fIrmware upgrade from L4T 28.2 to 32.4.2 (changed flash layout) | 5 | 683 | August 18, 2021 | |
| Flashing DTB on Jetson TX2 / L4T 32.4.4 | 5 | 1124 | October 18, 2021 | |
| L4T 32.5.1 Unable to Update DTB | 33 | 893 | March 29, 2022 | |
| The Jetson TX2 cannot load using the Jetpack4.4 system initialization interface | 11 | 502 | July 22, 2022 | |
| USB port is not working after kernel updated | 6 | 686 | October 18, 2021 | |
| TX1 field update from 28.2 to 32.3.1 | 4 | 808 | October 18, 2021 |
