Hi
Excuse me, How to check the DRIVE OS version?
It can be started successfully on the Carrier Board of the kit, But it can’t start on our own Carrier Board.
I brushed the system on the DRIVE AGX Orin Devkit and used the AGX Orin core on my own board based。Result:
I 've already reflash, but the issue hasn’t been solved yet. From the log, it can be seen that the system died during the boot phase. Excuse me, Can I control boot startup by modifying the device three?
Hi
Now, The system can be started up on our own Carrier Board, but , After the system is up, The network port is not up. this is OK on DRIVE AGX Orin devkit. I want to know how to reconfigure the network interface. we are using “Gigabit Ethernet” moudel.
The following is a module diagram use
Dear @wufenghui,
It looks like you are using Jetson AGX Orin. This forum is intended for DRIVE AGX orin platform related queries. I will move this thread to relavant forum Jetson AGX Orin - NVIDIA Developer Forums
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Hi @wufenghui
所以你買的是DRIVE 還是Jetson平台? 還是你不知道自己買的是哪個?
