Boot orin nano developerkit after shutdown only works afgter desconnecting the barrel connector
When I shutdown (‘sudo shutdown’) the jetson orin nano developer kit, the system will only boot up when I physically remove the barrel connector and reinsert it. Is there a way to avoid this? I have a switch on the mains power supply to power down/power up the complete system.
Hi, you can short pin 11 and 12 of J14 by jumper to implement a power-on.
