Boot problem
We just received a “Drive AGX Thor Developer Kit”. When we plug the 220 Vac the message in the console is:
*************** NvShell Initialization Start******************\cf1\highlight2
DRIVE-V7.0.3-P3960-AFW-RH850-U2A16-2.03.12\cf1\highlight2
Inforom detected Board ID - 63960-0010-000\cf1\highlight2
Compilation date: Jun 5 2025, 08:28:12\cf1\highlight2
Enter ‘help’ to see the available commands.\cf1\highlight2
*************** NvShell Initialized *************************\cf1\highlight2
Press ‘Enter’ for NvShell prompt\cf1\highlight2
*************************************************************\cf1\highlight2
INFO: BtChn_Cfg: NvMCbk - TA DfltBtChn Pri Blk, SId-12, JobRes-0\cf1\highlight2
INFO: BtChn_Cfg: NvMCbk - TB DfltBtChn Pri Blk, SId-12, JobRes-0\cf1\highlight2
INFO: BtChn_Cfg: NvMCbk - TA NxtBtChn Pri Blk, SId-12, JobRes-0\cf1\highlight2
INFO: BtChn_Cfg: NvMCbk - TB NxtBtChn Pri Blk, SId-12, JobRes-0\cf1\highlight2
INFO: BtChn_Cfg: NvMCbk - TB DfltBtChn Red Blk, SId-12, JobRes-0\cf1\highlight2
INFO: BtChn_Cfg: NvMCbk - TB NxtBtChn Red Blk, SId-12, JobRes-0\cf1\highlight2
INFO: BtChn_Cfg: NvMCbk - TA DfltBtChn Red Blk, SId-12, JobRes-0\cf1\highlight2
INFO: BtChn_Cfg: NvMCbk - TA NxtBtChn Red Blk, SId-12, JobRes-0\cf1\highlight2
INFO: MCU Version PIM- DRIVE-V7.0.3-P3960-AFW-RH850-U2A16-2.03.12\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: Identified Board from Inforom - Board - 3960, BoardId - 000, Sku - 0010\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: NumSoc: 1\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: MCU reset 0x0 triggered…\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Number of SoCs to be powered: 1\cf1\highlight2
INFO: MCU_BOARDVMON: Loading up common ADC Configuration for boards : TS2/TS3/TS4\cf1\highlight2
INFO: FanMon_IoHwAbs: FAN Tach sensor measurement started\cf1\highlight2
I:RptrID - 0x810A PsCd - 0xF - ISTManager:IST execution status read success.\cf1\highlight2
I:RptrID - 0x810A PsCd - 0xE - ISTManager:No plausibility error in NVM data.\cf1\highlight2
I:RptrID - 0x810A PsCd - 0x14 - ISTManager:No range plausibility error in NVM data.\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x16 - PwrCtrl Init Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x16 - PwrCtrl Init Ok ErrAttr - 0x01\cf1\highlight2
I:RptrID - 0x810F PsCd - 0x7 - BootchainCfg Cfg Range Check Success\cf1\highlight2
I:RptrID - 0x810F PsCd - 0x2 - BootchainCfg NvM Read Success\cf1\highlight2
I:RptrID - 0x810F PsCd - 0x4 - BootchainCfg NvM Plaus Check Success\cf1\highlight2
MCU_FOH: Switched to IDLE_STATE\cf1\highlight2
MCU_FOH: Initialization done\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Powering up\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: PMIC: Wakeup Status - 0x1, Error Status: 0x0\cf1\highlight2
INFO: MCU_BOARDVMON: Voltage Monitor enabled for ADCJ0 and ADCJ1 signals\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: VDD_MV_CVM voltage (139mV)\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: VDD_HV_CVM voltage (19mV)\cf1\highlight2
INFO: MCU_PLTFPWRMGR: SW Latent Test configuration: 0x0\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: KL30_PROTECT Voltage (12098mV) exceeded threshold (6689mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: SAFE_3V3_PG Voltage (3269mV) exceeded threshold (3135mV). Continuing…!\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x8 - PwrCtrl Dio Chk Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x7 - PwrCtrl Config Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x17 - PwrCtrl PrePwrUp Ok\cf1\highlight2
INFO: MCU_PLTFPWRMGR: MPFDTI Timer started with period set to - 28800 seconds\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: PWRYNK_SHDN-1, VBAT_SOC_FAULT-0, VDD_MV_CVM-4992mV, VDD_HV_CVM-12126mV !\cf1\highlight2
ERROR: MCU_ERRHANDLER: PltfPwrMgr : ReporterID - 0x8100 ErrorCode - 0x4\cf1\highlight2
ERROR: MCU_PLTFPWRMGR: Enable Pre-regulator Request failed! Move to error state\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Move to error state…!\cf1\highlight2
After that we write the command “poweron” and the result is:
Info: Executing cmd: poweron, argc: 0, args:\cf1\highlight2
NvShell>INFO: MCU_PLTFPWRMGR: Powering up\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: VDD_MV_CVM voltage (4990mV)\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: VDD_HV_CVM voltage (12126mV)\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: KL30_PROTECT Voltage (12110mV) exceeded threshold (6689mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: SAFE_3V3_PG Voltage (3283mV) exceeded threshold (3135mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: VBAT_SOC_FAULT is set to 1. Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: PWRYNK_SHDN is set to 1. Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: VDD_MV_CVM voltage (4992mV) exceeded threshold (4751mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: VDD_HV_CVM voltage (12126mV) exceeded threshold (6695mV). Continuing…!\cf1\highlight2
I:RptrID - 0x810B PsCd - 0x20 - VMON Config Valid\cf1\highlight2
I:RptrID - 0x810B PsCd - 0x13 - VMON i2c addr load passed\cf1\highlight2
I:RptrID - 0x810B PsCd - 0xA - VMON Bist Passed\cf1\highlight2
Check for VRS10…\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x3 - PwrCtrl I2C Read Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x6 - PwrCtrl I2C Read Crc Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x14 - PwrCtrl VRS10 BIST Complete\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x19 - PwrCtrl VRS10 BIST Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x9 - PwrCtrl Vrs10 Int Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0xD - PwrCtrl ActShdn Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0xF - PwrCtrl ActSlp Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0xE - PwrCtrl Actslp Ok\cf1\highlight2
INFO: WAR: NVMCU_SOCPWRCTRL: Program correct OTPs for Power sequencing\cf1\highlight2
INFO: NvMCU_SocTMON: Soc-0 Temperature sensor initialized\cf1\highlight2
I:RptrID - 0x810C PsCd - 0x17 - TMON Configuration in default mode pass\cf1\highlight2
Check for VRS11-1…\cf1\highlight2
Check for VRS11-2…\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x1A - PwrCtrl VRS11 BIST Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0xA - PwrCtrl VRS11 Int Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x2 - PwrCtrl I2C Write Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x4 - PwrCtrl I2C Val Ok\cf1\highlight2
INFO: SftyMon_IoHwAbs: toggle check of local and remote sensor successfull\cf1\highlight2
INFO: NVMCU_SOCPWRCTRL: Programming thermal thresholds done!\cf1\highlight2
I:RptrID - 0x810D PsCd - 0xC - PwrCtrl Actshdn Ok\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x10 - PwrCtrl Vrs10 NIRQ Chk Ok\cf1\highlight2
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS10 !\cf1\highlight2
I:RptrID - 0x810D PsCd - 0x11 - PwrCtrl Vrs11 NIRQ Chk Ok\cf1\highlight2
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS11-1!\cf1\highlight2
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS11-2!\cf1\highlight2
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ continuous monitoring Enabled!\cf1\highlight2
INFO: SftyMon_IoHwAbs: Board Temperature sensor initialized\cf1\highlight2
INFO: NvMCU_SocTMON: toggle check of local and remote sensor successfull\cf1\highlight2
I:RptrID - 0x810C PsCd - 0xB - TMON Toggle Check for Alert & Shutdown Pass\cf1\highlight2
I:RptrID - 0x810B PsCd - 0x8 - VMON Seq Record\cf1\highlight2
I:RptrID - 0x810B PsCd - 0x7 - VMON Seq Match\cf1\highlight2
I:RptrID - 0x810B PsCd - 0x23 - VMON Seq Ackld\cf1\highlight2
ERROR: MCU_ERRHANDLER: SocVMON : ReportedID - 0x810B ErrorCode - 0x15\cf1\highlight2
I:RptrID - 0x810B PsCd - 0xD - VMON Plausibility pass\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Request NVMCU_SOCTMON_REQ_TOGGLE_CHK Service - finished\cf1\highlight2
ERROR: MCU_PLTFPWRMGR: Request VMON Power-up sequence verification failed! Continue sequence\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Board TMON enabled.\cf1\highlight2
INFO: NvMCU_SocTMON: Soc TMON init complete\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Soc TMON enabled …\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Bootchain selection mode: GPIO\cf1\highlight2
INFO: BtChn_Cfg: Tegra x1 Boot Chain is : A\cf1\highlight2
INFO: BtChn_Cfg: Btchn Pin SOC0_BOOTCHAIN0 set to 0\cf1\highlight2
INFO: BtChn_Cfg: Btchn Pin SOC0_BOOTCHAIN1 set to 0\cf1\highlight2
I:RptrID - 0x810F PsCd - 0x6 - BootchainCfg Dio set success\cf1\highlight2
INFO: NVMCU_SOCPWRCTRL: Tegra reset released\cf1\highlight2
MCU_FOH: MCU FOH : Start Monitoring Called\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Start Network power-up sequence .\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_3V3_AO voltage (3307mV) exceeded threshold (3135mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V8 voltage (813mV) exceeded threshold (759mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_3V3 voltage (3301mV) exceeded threshold (3135mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_1V2 voltage (1208mV) exceeded threshold (1140mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V9 voltage (904mV) exceeded threshold (854mV). Continuing…!\cf1\highlight2
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V84 voltage (838mV) exceeded threshold (798mV). Continuing…!\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Request Power-up Ethernet Switch done !\cf1\highlight2
INFO: NvMCU_SocTMON: Thermal Monitoring Enabled\cf1\highlight2
I:RptrID - 0x810C PsCd - 0x10 - TMON All thermal events are clear\cf1\highlight2
I:RptrID - 0x810C PsCd - 0x11 - TMON All alert events are clear\cf1\highlight2
INFO: NvMCU_SocTMON: Thermal Alert Trigger not present anymore\cf1\highlight2
I:RptrID - 0x810C PsCd - 0xF - TMON No notification present\cf1\highlight2
INFO: Network config 0x3: Hyperion 8_1\cf1\highlight2
INFO: RTK_SWITCH: Realtek switch firmware init complete at SMI:24\cf1\highlight2
INFO: RTK_SWITCH: Condor1 Switch init complete\cf1\highlight2
INFO: RTK_SWITCH: Realtek switch firmware init complete at SMI:25\cf1\highlight2
INFO: RTK_SWITCH: Condor2 Switch init complete\cf1\highlight2
INFO: MRVL_SWITCH: FIR ACTIVE pin disabled (DENY ALL)\cf1\highlight2
INFO: MRVL_SWITCH: Fir switch 88Q5152 init complete\cf1\highlight2
Initialize 88Q222X PHY with SMI address: 3 in Master Mode, Detected Q2221M Package!!!\cf1\highlight2
INFO: PLTFPWRMGR_ETHCTRL: Ethernet switch and Phy initialization completed..\cf1\highlight2
INFO: PLTFPWRMGR_ETHCTRL: Ethernet Link Active\cf1\highlight2
INFO: PLTFPWRMGR_ETHCTRL: Linkup status is not active\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Request Eth initialization done !\cf1\highlight2
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring enable.\cf1\highlight2
INFO: MCU_PLTFPWRMGR: Power-up sequence is complete !\cf1\highlight2
INFO: CmnIf: Wdg Enabled Success!\cf1\highlight2
Power on the system\cf1\highlight2
Command Executed\cf1\highlight2
INFO: MCU_ERRHANDLER: Published Power State: Power-up complete\cf1\highlight2
Init Max load - 100, Average Load - 18\cf1\highlight2
INFO : MCU_ISTMGR: IST_DONE pin no monitor time of 2000 ms over.\cf1\highlight2
I:RptrID - 0x810A PsCd - 0xD - ISTManager:IST DONE pin stuck at low not observed.\cf1\highlight2
INFO: SftyMon_IoHwAbs: PG_VRS11 monitoring started…\cf1\highlight2
MCU_FOH: Switched to FSI_MONITORING_STATE\cf1\highlight2
MCU_FOH: SOC error pin is asserted\cf1\highlight2
ERROR: MCU_ERRHANDLER: SOC error pin is asserted\cf1\highlight2
MCU_FOH: Spi Transmit Started\cf1\highlight2
MCU_FOH: ErrReport: ErrorCode-0x64000cec ReporterId-0x8001 Error_Attribute-0x0 Timestamp-0xbc588355MCU_FOH: ErrReport: ErrorCode-0x2951 ReporterId-0xe01d Error_Attribute-0x8084984a Timestamp-0x53657MCU_FOH: ErrReport: ErrorCode-0x2953 ReporterId-0xe01d Error_Attribute-0x8084984a Timestamp-0x5368aMCU_FOH: ErrReport: ErrorCode-0x2955 ReporterId-0xe01d Error_Attribute-0x8084984a Timestamp-0x536b7MCU_FOH: ErrReport: ErrorCode-0x589d ReporterId-0xe01d Error_Attribute-0x8084984a Timestamp-0x536eeMCU_FOH: ErrReport: ErrorCode-0x2957 ReporterId-0xe01d Error_Attribute-0x8084984a Timestamp-0x5372aMCU_FOH: ErrReport: ErrorCode-0x4004 ReporterId-0xe04c Error_Attribute-0x0 Timestamp-0x5b2553fd\cf1\highlight2
MCU_FOH: ErrReport: ErrorCode-0x48be ReporterId-0xe025 Error_Attribute-0x4000082d Timestamp-0x2882eMCU_FOH: ErrReport: ErrorCode-0x2d88 ReporterId-0xe023 Error_Attribute-0x40000804 Timestamp-0x2893fMCU_FOH: ErrReport: ErrorCode-0x2985 ReporterId-0xe023 Error_Attribute-0x4000082d Timestamp-0x2894fMCU_FOH: ErrReport: ErrorCode-0x2d88 ReporterId-0xe023 Error_Attribute-0x40000804 Timestamp-0x28ac9MCU_FOH: Periodic Status [0] 0xab [1] 0xcd [250] 0x12 [251] 0x34\cf1\highlight2
MCU_FOH: ErrReport: ErrorCode-0x4806 ReporterId-0xe04c Error_Attribute-0x40000805 Timestamp-0xe00d9MCU_FOH: ErrReport: ErrorCode-0x480a ReporterId-0xe04c Error_Attribute-0x40000803 Timestamp-0x92b82MCU_FOH: ErrReport: ErrorCode-0x4808 ReporterId-0xe04c Error_Attribute-0x40000803 Timestamp-0x92b8dMCU_FOH: ErrReport: ErrorCode-0x58a5 ReporterId-0xe008 Error_Attribute-0x4000087d Timestamp-0x3d454MCU_FOH: ErrReport: ErrorCode-0x2807 ReporterId-0xe04c Error_Attribute-0x40000803 Timestamp-0x42b34MCU_FOH: ErrReport: ErrorCode-0x5801 ReporterId-0xe04c Error_Attribute-0x4000080b Timestamp-0x42b44INFO : MCU_ISTMGR: IST Manager initialized to send/receive commands\cf1\highlight2
I:RptrID - 0x810A PsCd - 0x11 - ISTManager:IST result fetched.\cf1\highlight2
INFO : IST_TESTAPP: IST Result Ready to fetch\cf1\highlight2
video_transmitter_hdr_pkgvideo_transmitter_hdr_pkg\cf1\highlight2
Finally if we write the command “showvoltages” the result is:
NvShell>showvoltages\cf1\highlight2
Info: Executing cmd: showvoltages, argc: 0, args:\cf1\highlight2
ADCJxIy - Rail Name : Actual Voltage : Expected Voltage : Voltage Range(default - +/- 5%)\cf1\highlight2
ADCJ0I1 - VDD_MV_CVM : 04.94V : 05.00V : { 04.75V to 05.25V}\cf1\highlight2
ADCJ0I2 - VDD_HV_CVM : 12.10V : 16.00V : { 06.70V to 18.00V}\cf1\highlight2
ADCJ0I3 - A2B_VDD : 09.10V : 09.00V : { 08.55V to 09.45V}\cf1\highlight2
ADCJ0I4 - VDD_12V_CVB : 12.04V : 12.00V : { 11.40V to 12.60V}\cf1\highlight2
ADCJ0I13 - ETH_SYS_3V3_AO : 03.31V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I14 - ETH_SYS_0V8 : 00.81V : 00.80V : { 00.76V to 00.84V}\cf1\highlight2
ADCJ0I16 - WUP_FLT_ADC : 03.29V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I17 - KL30_PWR : 00.05V : 18.00V : { 17.10V to 18.90V}\cf1\highlight2
ADCJ0I18 - KL30_PROTECT : 12.11V : 18.00V : { 06.69V to 18.00V}\cf1\highlight2
ADCJ0I19 - ETH_SYS_0V84 : 00.83V : 00.84V : { 00.80V to 00.88V}\cf1\highlight2
ADCJ0I8S - SMCU_5V : 03.85V : 05.00V : { 04.75V to 05.25V}\cf1\highlight2
ADCJ0I9S - FR1_5V : 03.85V : 05.00V : { 04.75V to 05.25V}\cf1\highlight2
ADCJ0I0 - LEAVE_NC_0 : 02.93V : 00.00V : { 00.00V to 05.00V}\cf1\highlight2
ADCJ0I5 - SOC0_CVM_PG : 03.28V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I6 - SAFE_3V3_PG : 03.28V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I7 - SMCU_3V3 : 03.33V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I8 - BUCK_3V3_PG : 03.29V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I9 - MV_PREREG_PG : 02.42V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I10 - A2B_VDD_PG : 03.33V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I11 - SMCU_3V3_1 : 03.33V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I12 - SOC_L0L1_RESET_N : 02.58V : 01.80V : { 01.71V to 01.89V}\cf1\highlight2
ADCJ0I15 - SOC_L2_RESET_N : 02.42V : 01.80V : { 01.71V to 01.89V}\cf1\highlight2
ADCJ0I6S - 12V_PREREG_PG : 03.32V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ0I7S - SMCU_3V3_6 : 03.33V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I0 - MV_LSW_MON : 04.90V : 05.00V : { 04.75V to 05.25V}\cf1\highlight2
ADCJ1I1 - VDD_MV_CVB : 04.92V : 05.00V : { 04.75V to 05.25V}\cf1\highlight2
ADCJ1I3 - USS1_VSUP : 11.85V : 12.00V : { 11.40V to 12.60V}\cf1\highlight2
ADCJ1I4 - USS2_VSUP : 11.85V : 12.00V : { 11.40V to 12.60V}\cf1\highlight2
ADCJ1I5 - SAFE_3V3 : 03.31V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I6 - VDD_3V3_CVB : 03.22V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I7 - ETH_SYS_3V3 : 03.31V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I10 - ETH_SYS_1V2 : 01.21V : 01.20V : { 01.14V to 01.26V}\cf1\highlight2
ADCJ1I12 - ETH_SYS_0V9 : 00.90V : 00.90V : { 00.85V to 00.94V}\cf1\highlight2
ADCJ1I17 - CAN1_5V : 05.00V : 05.00V : { 04.75V to 05.25V}\cf1\highlight2
ADCJ1I18 - CAN2_5V : 05.00V : 05.00V : { 04.75V to 05.25V}\cf1\highlight2
ADCJ1I19 - USS_VSUP_SNS : 00.01V : 03.12V : { 02.96V to 03.27V}\cf1\highlight2
ADCJ1I2 - VDD_12V_CVB_1 : 12.04V : 12.00V : { 11.40V to 12.60V}\cf1\highlight2
ADCJ1I8 - SMCU_3V3_2 : 03.33V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I9 - FAKE_TO_2_5V : 03.32V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I11 - FAKE_TO_1V : 03.33V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I13 - SOC1_CVM_PG : 01.25V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I14 - SMCU_3V3_3 : 03.33V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I15 - SMCU_3V3_4 : 03.33V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ1I16 - SMCU_3V3_5 : 03.32V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ2I0 - SMCU_3V3WITH_DIVIDER : 03.32V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ2I1 - WUP_OUT_ADC : 00.77V : 04.50V : { 04.27V to 04.72V}\cf1\highlight2
ADCJ2I2 - USS_VSUP_FAULT : 03.30V : 03.30V : { 03.13V to 03.46V}\cf1\highlight2
ADCJ2I3 - SMCU_WSH_SNS : 05.00V : 02.17V : { 02.06V to 02.28V}\cf1\highlight2
ADCJ2I4 - PSW_MV_C : 00.56V : 04.04V : { 03.84V to 04.24V}\cf1\highlight2
So it seems there are some problem with the power up. As you can see some voltages like kL30 are not good. The developer Kit is new but do you think it is necesary to flash?
Dear @marc.blanch ,
Could you access tegra console using minicom? The default port is ‘/dev/ttyACM0’. Do you notice login option or EULA, OEM config screen like mentioned at Finalizing the Installation — NVIDIA DriveOS 7.0 Linux Installation Guide ?
Hi Sivia,
Thank you for the quick information.
The previous report was from the sMCU console, but I have also access to the Tegra console as well. I have attached the log from this console for your reference.
As you can see at the end of the log, the console repeatedly outputs the following message: "mgbe0: UPHY RX lane bring-up failed".
Regarding the power rails, my concern is not limited to KL30. Other critical lines are also running well below specifications. Specifically, both SMCU_5V and FR1_5V are measuring at 3.85 V, which is significantly undervoltage.
MobaXterm_COM13DispositivoserieUSBCOM13_20260703_182852.txt (352.3 KB)
Dear @marc.blanch ,
I also notice similar voltage values for power rails on my target. I don’t think it is an issue.
May I know if your target is SKU10/SKU 12?
You can ignore this.
Dear @marc.blanch ,
Do you have any further questions or can we close the topic?
