We are designing a custom carrier board for the AGX Xavier, and the boot process fails very early with this error:
[0000.205] I> Boot-device: eMMC
[0000.208] I> Boot-device: eMMC
[0000.217] I> Sdmmc: HS400 mode enabled
[0000.222] I> ECC region[0]: Start:0x0, End:0x0
[0000.226] I> ECC region[1]: Start:0x0, End:0x0
[0000.230] I> ECC region[2]: Start:0x0, End:0x0
[0000.234] I> ECC region[3]: Start:0x0, End:0x0
[0000.238] I> ECC region[4]: Start:0x0, End:0x0
[0000.242] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.248] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.252] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.257] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.261] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.267] E> FAILED: Thermal config
[0000.274] E> FAILED: MEMIO rail config
[0000.287] I> Boot-device: eMMC
[0000.297] I> sdmmc bdev is already initialized
[0001.839] E> WP-1 ACK pending
[0001.842] E> Error: 0
[0001.844] E> Task 71 failed (err: 0x32320006)
[0001.848] E> Top caller module: CPUINIT, error module: CPUINIT, reason: 0x06, aux_info: 0x00
[0001.856] I> MB1(1.5.1.2-t194-41334769-9ec1833d) BIT boot status dump :
0000000000011111111110111111111111111111111001111111011100111111110110110000000000000000000000000000000000000000000000000000000011111011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0001.886] I> Reset to recovery mode
The module works fine on the dev board, and as far as we can tell all voltages are nominal. Is there something missing in our power sequencing?
Thank you.
