I have a tx2i jetson. It works on custom carrier board. I am flasing with sdk menager and jetpack 4.4 dp. Flashings successful but Jetson stops on cboot. My log is below. Thanks
boot log
NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:43:09, Dec 9 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea87ad58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
[0001.155] I> Welcome to Cboot
[0001.158] I> Cboot Version: t186-c3c778fb
[0001.161] I> CPU-BL Params @ 0x235800000
[0001.165] I> Dram Scrub in progress
[0001.511] E> cb_vic_scrub: VIC Scrub Failure, error 0x6, cmd = 0x1
[0001.517] E> Bug /dvs/git/dirty/git-master_linux/bootloader/partner/t18x/common/drivers/vic/tegrabl_vic.c:337 (cb_vic_scrub)
[0000.084] C> I2C command failed
[0000.087] C> block index = (4) and rail_id = (1)
[0000.092] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.097] C> I2C command failed
[0000.100] C> block index = (5) and rail_id = (1)
[0000.104] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.293] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-050b21a4)
[0000.302] I> bit @ 0xd480000
[0000.305] I> Boot-device: eMMC
[0000.312] I> sdmmc bdev is already initialized
[0000.317] I> pmic: reset reason (nverc) : 0x54
[0000.348] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0000.367] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.373] I> MB2 check ECC error: EMC_INTSTATUS_0: 0x10
[0000.378] I> MB2 check ECC error: EMC_INTSTATUS_0: 0x0
[0000.383] I> MB2 check ECC error: EMC_INTSTATUS_0: 0x10
[0000.388] I> MB2 check ECC error: EMC_INTSTATUS_0: 0x0
[0000.393] I> OEM carveouts init scrub in progress…
[0000.469] I> MB2 check ECC error: EMC_INTSTATUS_0: 0x10
[0000.474] I> MB2 check ECC error: EMC_INTSTATUS_0: 0x0
[0000.479] I> MB2 check ECC error: EMC_INTSTATUS_0: 0x10
[0000.484] I> MB2 check ECC error: EMC_INTSTATUS_0: 0x0
[0000.489] I> Mb2 SDRAM scrub successful
[0000.493] W> No valid slot number is found in scratch register
[0000.499] W> Return default slot: _a
[0000.502] I> A/B: bin_type (16) slot 0
[0000.506] I> Loading partition bpmp-fw at 0xd7800000
[0000.511] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.516] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.541] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.547] W> No valid slot number is found in scratch register
[0000.552] W> Return default slot: _a
[0000.556] I> A/B: bin_type (17) slot 0
[0000.559] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.565] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.570] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.589] I> Binary(17) of size 75760 is loaded @ 0xd79ed600
[0000.624] I> Loading SCE-FW …
[0000.627] W> No valid slot number is found in scratch register
[0000.633] W> Return default slot: _a
[0000.636] I> A/B: bin_type (12) slot 0
[0000.640] I> Loading partition sce-fw at 0xd7300000
[0000.645] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.650] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.669] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.675] I> Init SCE
[0000.677] I> Loading APE-FW …
[0000.680] W> No valid slot number is found in scratch register
[0000.686] W> Return default slot: _a
[0000.689] I> A/B: bin_type (11) slot 0
[0000.693] I> Loading partition adsp-fw at 0xd7400000
[0000.698] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.703] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.722] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.728] I> Copy BTCM section
[0000.731] W> No valid slot number is found in scratch register
[0000.737] W> Return default slot: _a
[0000.740] I> A/B: bin_type (13) slot 0
[0000.744] I> Loading partition cpu-bootloader at 0x96000000
[0000.749] I> Reading two headers - addr:0x96000000 blocks:1
[0000.755] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.776] I> Binary(13) of size 284288 is loaded @ 0x96000000
[0000.782] W> No valid slot number is found in scratch register
[0000.787] W> Return default slot: _a
[0000.791] I> A/B: bin_type (20) slot 0
[0000.794] I> Loading partition bootloader-dtb at 0x8520f400
[0000.800] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.805] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.828] I> Binary(20) of size 364432 is loaded @ 0x8520f400
[0000.833] W> No valid slot number is found in scratch register
[0000.839] W> Return default slot: _a
[0000.842] I> A/B: bin_type (14) slot 0
[0000.846] I> Loading partition secure-os at 0x8530f600
[0000.851] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.857] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.879] I> Binary(14) of size 366000 is loaded @ 0x8530f600
[0000.886] I> TOS boot-params @ 0x85000000
[0000.890] I> TOS params prepared
[0000.893] I> Loading EKS …
[0000.896] I> A/B: bin_type (15) slot 0
[0000.900] I> Loading partition eks at 0x8590f800
[0000.904] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.910] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.928] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.934] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.939] I> Copied encrypted keys
[0000.943] I> boot profiler @ 0x235844000
[0000.947] I> boot profiler for TOS @ 0x235844000
[0000.951] I> Unhalting SCE
[0000.954] I> Primary Memory Start:80000000 Size:70000000
[0000.959] I> Extended Memory Start:f0110000 Size:1456f0000
[0000.966] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):fe06da916
NOTICE: BL31: Built : 18:07:10, Apr 8 2020
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
[0001.156] I> Welcome to Cboot
[0001.159] I> Cboot Version: t186-da7af280
[0001.162] I> CPU-BL Params @ 0x235800000
[0001.166] I> Dram Scrub in progress
[0001.512] E> cb_vic_scrub: VIC Scrub Failure, error 0x6, cmd = 0x1
[0001.518] E> Bug /dvs/git/dirty/git-master_linux/bootloader/partner/t18x/common/drivers/vic/tegrabl_vic.c:337 (cb_vic_scrub)
