New log
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 1
[0000.153] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x607ad
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.204] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.210] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.216] Resize the SecureOs Carveout to 0x00100000
[0000.221] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.227] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.232] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.238] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.244] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.250] Platform-DebugCarveout: 0
[0000.253] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.259] Non secure mode, and RB not enabled.
[0000.263] BoardID = 3448, SKU = 0x3
[0000.266] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.270] Nano-SD: checking PT table on QSPI …
[0000.275] Read PT from (2:0)
[0000.290] Using BFS PT to query partitions
[0000.296] Loading Tboot-CPU binary
[0000.324] Verifying TBC in OdmNonSecureSBK mode
[0000.334] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.341] Bootloader downloaded successfully.
[0000.345] Downloaded Tboot-CPU binary to 0xa0000258
[0000.350] MAX77620_GPIO5 configured
[0000.353] CPU power rail is up
[0000.356] CPU clock enabled
[0000.360] Performing RAM repair
[0000.363] Updating A64 Warmreset Address to 0xa00002e9
[0000.368] BoardID = 3448, SKU = 0x3
[0000.371] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.375] Nano-SD: checking PT table on QSPI …
[0000.380] Loading NvTbootBootloaderDTB
[0000.446] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.526] Bootloader DTB Load Address: 0x83000000
[0000.530] BoardID = 3448, SKU = 0x3
[0000.534] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.537] Nano-SD: checking PT table on QSPI …
[0000.542] Loading NvTbootKernelDTB
[0000.608] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.687] Kernel DTB Load Address: 0x83100000
[0000.692] BoardID = 3448, SKU = 0x3
[0000.695] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.699] Nano-SD: checking PT table on QSPI …
[0000.705] Loading cboot binary
[0000.821] Verifying EBT in OdmNonSecureSBK mode
[0000.862] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.869] Bootloader downloaded successfully.
[0000.873] BoardID = 3448, SKU = 0x3
[0000.877] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.881] Nano-SD: checking PT table on QSPI …
[0000.885] PT: Partition NCT NOT found !
[0000.889] Warning: Find Partition via PT Failed
[0000.893] Next binary entry address: 0x92c00258
[0000.898] BoardId: 3448
[0000.902] Overriding pmu board id with proc board id
[0000.907] Display board id is not available
[0000.911] No Bpmp FW loaded
[0000.914] Not loading WB0 as no bpmp/sc7entry fw
[0000.918] Set NvDecSticky Bits
[0000.922] GSC2 address ff93fffc value c0edbbcc
[0000.928] GSC MC Settings done
[0000.931] BoardID = 3448, SKU = 0x3
[0000.934] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.938] Nano-SD: checking PT table on QSPI …
[0000.943] TOS Image length 53680
[0000.946] Monitor size 53680
[0000.949] OS size 0
[0000.964] Secure Os AES-CMAC Verification Success!
[0000.969] TOS image cipher info: plaintext
[0000.973] Loading and Validation of Secure OS Successful
[0000.989] NvTbootPackSdramParams: start.
[0000.994] NvTbootPackSdramParams: done.
[0000.998] Tegraboot started after 52030 us
[0001.002] Basic modules init took 922527 us
[0001.006] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.011] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.017] Next stage binary read took 11286 us
[0001.021] Carveout took -63804 us
[0001.024] CPU initialization took 99958 us
[0001.028] Total time taken by TegraBoot 969967 us
[0001.033] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 08:37:40, Feb 19 2021
ERROR: Error initializing runtime service trusty_fast
[0001.154] RamCode = 1
[0001.159] LPDDR4 Training: Read DT: Number of tables = 2
[0001.164] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.176] EMC Training Successful
[0001.180] 408000 not found in DVFS table
[0001.186] RamCode = 1
[0001.189] DT Write: emc-table@204000 succeeded
[0001.195] DT Write: emc-table@1600000 succeeded
[0001.199] LPDDR4 Training: Write DT: Number of tables = 2
[0001.237]
[0001.238] Debug Init done
[0001.240] Marked DTB cacheable
[0001.243] Bootloader DTB loaded at 0x83000000
[0001.248] Marked DTB cacheable
[0001.251] Kernel DTB loaded at 0x83100000
[0001.255] DeviceTree Init done
[0001.268] Pinmux applied successfully
[0001.272] gicd_base: 0x50041000
[0001.276] gicc_base: 0x50042000
[0001.279] Interrupts Init done
[0001.283] Using base:0x60005090 & irq:208 for tick-timer
[0001.288] Using base:0x60005098 for delay-timer
[0001.293] platform_init_timer: DONE
[0001.296] Timer(tick) Init done
[0001.300] osc freq = 38400 khz
[0001.304]
[0001.305] Welcome to L4T Cboot
[0001.308]
[0001.309] Cboot Version: 00.00.2018.01-t210-39562017
[0001.314] calling constructors
[0001.317] initializing heap
[0001.319] initializing threads
[0001.322] initializing timers
[0001.325] creating bootstrap completion thread
[0001.330] top of bootstrap2()
[0001.333] CPU: ARM Cortex A57
[0001.335] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.340] initializing platform
[0001.348] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.352] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.357] Macronix QSPI chip present
[0001.360] SPI device register
[0001.363] init boot device
[0001.366] allocating memory for boot device(SPI)
[0001.370] registering boot device
[0001.379] QSPI bdev is already initialized
[0001.383] Enable APE clock
[0001.385] Un-powergate APE partition
[0001.389] of_register: registering tegra_udc to of_hal
[0001.394] of_register: registering inv20628-driver to of_hal
[0001.399] of_register: registering ads1015-driver to of_hal
[0001.405] of_register: registering lp8557-bl-driver to of_hal
[0001.411] of_register: registering bq2419x_charger to of_hal
[0001.416] of_register: registering bq27441_fuel_gauge to of_hal
[0001.428] gpio framework initialized
[0001.431] of_register: registering tca9539_gpio to of_hal
[0001.437] of_register: registering tca9539_gpio to of_hal
[0001.442] of_register: registering i2c_bus_driver to of_hal
[0001.448] of_register: registering i2c_bus_driver to of_hal
[0001.453] of_register: registering i2c_bus_driver to of_hal
[0001.459] pmic framework initialized
[0001.462] of_register: registering max77620_pmic to of_hal
[0001.468] regulator framework initialized
[0001.472] of_register: registering tps65132_bl_driver to of_hal
[0001.478] initializing target
[0001.483] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.491] board ID = D78, board SKU = 3
[0001.495] Skipping Z3!
[0001.500] fixed regulator driver initialized
[0001.519] initializing OF layer
[0001.522] NCK carveout not present
[0001.525] Skipping dts_overrides
[0001.529] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.547] I2C Bus Init done
[0001.549] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.559] I2C Bus Init done
[0001.562] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.572] I2C Bus Init done
[0001.575] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.586] I2C Bus Init done
[0001.588] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.599] I2C Bus Init done
[0001.601] of_children_init: Ops found for compatible string maxim,max77620
[0001.612] max77620_init using irq 118
[0001.616] register ‘maxim,max77620’ pmic
[0001.621] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.627] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.638] I2C Bus Init done
[0001.641] NCK carveout not present
[0001.651] Find /i2c@7000c000’s alias i2c0
[0001.655] get eeprom at 1-a0, size 256, type 0
[0001.664] Find /i2c@7000c500’s alias i2c2
[0001.668] get eeprom at 3-a0, size 256, type 0
[0001.672] get eeprom at 3-ae, size 256, type 0
[0001.677] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.682] I2C slave not started
[0001.685] I2C write failed
[0001.687] Writing offset failed
[0001.690] eeprom_init: EEPROM read failed
[0001.694] pm_ids_update: eeprom init failed
[0001.699] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.729] pm_ids_update: The pm board id is 3448-0003-400
[0001.736] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.744] pm_ids_update: pm id update successful
[0001.749] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.779] pm_ids_update: The pm board id is 3542-0000-201
[0001.785] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0001.793] pm_ids_update: pm id update successful
[0001.823] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.829] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.837] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.843] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.851] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:db:33
[0001.858] Plugin Manager: Parse ODM data 0x000a4000
[0001.871] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0001.886] Find /i2c@7000c000’s alias i2c0
[0001.890] get eeprom at 1-a0, size 256, type 0
[0001.899] Find /i2c@7000c500’s alias i2c2
[0001.903] get eeprom at 3-a0, size 256, type 0
[0001.907] get eeprom at 3-ae, size 256, type 0
[0001.911] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.917] I2C slave not started
[0001.920] I2C write failed
[0001.922] Writing offset failed
[0001.925] eeprom_init: EEPROM read failed
[0001.929] pm_ids_update: eeprom init failed
[0001.933] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.963] pm_ids_update: The pm board id is 3448-0003-400
[0001.970] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.977] pm_ids_update: pm id update successful
[0001.981] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.011] pm_ids_update: The pm board id is 3542-0000-201
[0002.018] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.024] pm_ids_update: pm id update successful
[0002.055] Add serial number:1424320033604 as DT property
[0002.063] Applying platform configs
[0002.069] platform-init is not present. Skipping
[0002.074] calling apps_init()
[0002.080] Couldn’t find GPT header
[0002.084] Proceeding to Cold Boot
[0002.088] starting app android_boot_app
[0002.091] Device state: unlocked
[0002.094] display console init
[0002.103] could not find regulator
[0002.126] hdmi cable not connected
[0002.129] is_hdmi_needed: HDMI not connected, returning false
[0[0002.139] DT entry for leds-pwm not found
002.135] hdmi is not connected
[0002.145] sor0 is not supported
[0002.148] display_console_init: no valid display out_type
[0002.157] subnode volume_up is not found !
[0002.161] subnode back is not found !
[0002.164] subnode volume_down is not found !
[0002.168] subnode menu is not found !
[0002.172] Gpio keyboard init success
[0002.252] found decompressor handler: lz4-legacy
[0002.267] decompressing blob (type 1)…
[0002.332] display_resolution: No display init
[0002.336] Failed to retrieve display resolution
[0002.341] Could not load/initialize BMP blob…ignoring
[0002.416] decompressor handler not found
[0002.419] load_firmware_blob: Firmware blob loaded, entries=2
[0002.425] XUSB blob version 0 size 124416 @ 0x92ca828c
[0002.431] -------> se_aes_verify_sbk_clear: 747
[0002.436] se_aes_verify_sbk_clear: Error
[0002.439] SE operation failed
[0002.442] bl_battery_charging: connected to external power supply
[0002.452] display_console_ioctl: No display init
[0002.456] switch_backlight failed
[0002.462] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.470] MSC Partition not found
[0002.476] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.483] USP partition read failed!
[0002.487] blob_init: blob-partition USP header read failed
[0002.492] android_boot Unable to update recovery partition
[0002.498] kfs_getpartname: name = LNX
[0002.501] Loading kernel from LNX
[0002.510] Found 19 BFS partitions in “spiflash0”
[0002.827] load kernel from storage
[0002.832] decompressor handler not found
[0003.095] Successfully loaded kernel and ramdisk images
[0003.100] board ID = D78, board SKU = 3
[0003.104] sdmmc node status = okay
[0003.108] sdcard instance = 0
[0003.110] sdcard gpio handle 0x5a
[0003.114] sdcard gpio pin 0xc9
[0003.117] sdcard gpio flags 0x0
[0003.120] vmmc-supply 0x9d
[0003.122] cd_gpio_pin = 201
[0003.125] pin_state = 0
[0003.127] Found sdcard
[0003.130] SD-card IS present …
[0003.133] load_and_boot_kernel: SD card detected OK
[0003.139] display_resolution: No display init
[0003.143] Failed to retrieve display resolution
[0003.147] bmp blob is not loaded and initialized
[0003.152] Failed to display boot-logo
[0003.155] NCK carveout not present
[0003.159] Skipping dts_overrides
[0003.162] NCK carveout not present
[0003.172] Find /i2c@7000c000’s alias i2c0
[0003.176] get eeprom at 1-a0, size 256, type 0
[0003.184] Find /i2c@7000c500’s alias i2c2
[0003.188] get eeprom at 3-a0, size 256, type 0
[0003.193] get eeprom at 3-ae, size 256, type 0
[0003.197] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.202] I2C slave not started
[0003.205] I2C write failed
[0003.208] Writing offset failed
[0003.211] eeprom_init: EEPROM read failed
[0003.215] pm_ids_update: eeprom init failed
[0003.219] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.249] pm_ids_update: The pm board id is 3448-0003-400
[0003.256] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0003.265] pm_ids_update: pm id update successful
[0003.269] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.299] pm_ids_update: The pm board id is 3542-0000-201
[0003.306] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0003.314] pm_ids_update: pm id update successful
[0003.344] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.350] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.358] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.364] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.372] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:db:33
[0003.378] Plugin Manager: Parse ODM data 0x000a4000
[0003.391] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0003.400] Add serial number:1424320033604 as DT property
[0003.408] Updated bpmp info to DTB
[0003.413] Updated initrd info to DTB
[0003.416] “proc-board” doesn’t exist, creating
[0003.422] Updated board info to DTB
[0003.426] “pmu-board” doesn’t exist, creating
[0003.432] Updated board info to DTB
[0003.435] “display-board” doesn’t exist, creating
[0003.441] Updated board info to DTB
[0003.445] “reset” doesn’t exist, creating
[0003.449] Updated reset info to DTB
[0003.453] display_console_ioctl: No display init
[0003.457] display_console_ioctl: No display init
[0003.462] display_console_ioctl: No display init
[0003.466] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 gpt
[0003.499] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0003.504] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0003.517] Updated bootarg info to DTB
[0003.521] Adding uuid 000000016450a5061400000015fb81c0 to DT
[0003.527] Adding eks info 0 to DT
[0003.532] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.538] Updated memory info to DTB
[0003.546] set vdd_core voltage to 1125 mv
[0003.550] setting ‘vdd-core’ regulator to 1125000 micro volts
[0003.556] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:37:45 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano 2GB Developer Kit
Board: NVIDIA P3541-0000
DRAM: 2 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
838 bytes read in 20 ms (40 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159841 bytes read in 326 ms (20.9 MiB/s)
Retrieving file: /boot/Image
34338824 bytes read in 1501 ms (21.8 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 00000000831843cf
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5294-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:40:32 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f800000
[ 0.000000] OF: fdt: - bfa00000 , 3fe00000
[ 0.000000] OF: fdt: - ffa00000 , 600000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fb800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 514560
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29564(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1946276K/2091008K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 79196K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf02000000 ( 32 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc080000000 ( 2048 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.010005] Console: colour dummy device 80x25
[ 0.014653] console [tty0] enabled
[ 0.018165] bootconsole [uart8250] disabled
[ 0.022491] kmemleak: Kernel memory leak detector disabled
[ 0.022516] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.022538] pid_max: default: 32768 minimum: 301
[ 0.022999] Security Framework initialized
[ 0.023223] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.023235] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.024313] ftrace: allocating 47208 entries in 185 pages
[ 0.192809] ASID allocator initialised with 65536 entries
[ 0.232171] tegra-id: chipid=22117.
[ 0.232203] tegra-id: opt_subrevision=0.
[ 0.232226] Tegra Speedo/IDDQ fuse revision 4
[ 0.232236] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.232246] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.232257] Tegra: CPU Speedo Value 1944, SoC Speedo Value 1890, GPU Speedo Value 1989
[ 0.232268] Tegra: CPU IDDQ Value 1288, SoC IDDQ Value 1648, GPU IDDQ Value 1950
[ 0.232293] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.232314] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
[ 0.232335] DTB Build time: Feb 19 2021 08:42:41
[ 0.281270] CPU1: Booted secondary processor [411fd071]
[ 0.313176] CPU2: Booted secondary processor [411fd071]
[ 0.345152] CPU3: Booted secondary processor [411fd071]
[ 0.345246] Brought up 4 CPUs
[ 0.345299] SMP: Total of 4 processors activated.
[ 0.345315] CPU features: detected feature: 32-bit EL0 Support
[ 0.345584] CPU: All CPU(s) started at EL2
[ 0.345612] alternatives: patching kernel code
[ 0.353037] devtmpfs: initialized
[ 0.393518] Initilizing CustomIPI irq domain
[ 0.393926] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.393970] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.395672] pinctrl core: initialized pinctrl subsystem
[ 0.396144] OS set in device tree is not L4T.
[ 0.396527] regulator-dummy: no parameters
[ 0.396802] Initializing plugin-manager
[ 0.396952] Plugin module not found
[ 0.397322] node /plugin-manager/fragment@1 match with board >=3448-0003-400
[ 0.398498] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.398723] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.399143] node /plugin-manager/fragement@9 match with board >=3448-0003-000
[ 0.400457] node /plugin-manager/fragment@12 match with board >=3448-0003-400
[ 0.400735] node /plugin-manager/fragement@13 match with board >=3448-0003-400
[ 0.404391] NET: Registered protocol family 16
[ 0.405773] pstore: using zlib compression
[ 0.406264] console [pstore-1] enabled
[ 0.406279] pstore: Registered ramoops as persistent store backend
[ 0.406296] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.421298] cpuidle: using governor menu
[ 0.424510] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.426384] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.426427] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.429681] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.432249] Serial: AMBA PL011 UART driver
[ 0.432777] tegra_powergate_init: DONE
[ 0.432808] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
[ 0.432843] DTB Build time: Feb 19 2021 08:42:41
[ 0.434978] Tegra reboot handler registered.
[ 0.439499] iommu: Adding device tegra-carveouts to group 0
[ 0.439640] platform tegra-carveouts: domain=ffffffc078bed018 allocates as[0]=ffffffc0784540a8
[ 0.440003] iommu: Adding device smmu_test to group 1
[ 0.440066] platform smmu_test: domain=ffffffc078bed258 allocates as[0]=ffffffc078454110
[ 0.440880] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.440954] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.441025] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.441046] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.441075] mc-err: mcerr ops are set to t21x
[ 0.451443] iommu: Adding device 70090000.xusb to group 2
[ 0.451744] iommu: Adding device 70006000.serial to group 3
[ 0.451819] platform 70006000.serial: domain=ffffffc078b27918 allocates as[0]=ffffffc078454178
[ 0.452259] iommu: Adding device 70006040.serial to group 4
[ 0.452536] iommu: Adding device 70006200.serial to group 5
[ 0.452749] iommu: Adding device sound to group 6
[ 0.452808] platform sound: domain=ffffffc078b27e58 allocates as[0]=ffffffc0784541e0
[ 0.453405] iommu: Adding device 7000d400.spi to group 7
[ 0.453678] iommu: Adding device 7000d600.spi to group 8
[ 0.453998] iommu: Adding device 70410000.spi to group 9
[ 0.454324] iommu: Adding device 50000000.host1x to group 10
[ 0.454610] iommu: Adding device 54080000.vi to group 11
[ 0.455002] iommu: Adding device 54600000.isp to group 12
[ 0.455275] iommu: Adding device 54680000.isp to group 13
[ 0.455580] iommu: Adding device tegradc.0 to group 14
[ 0.455642] platform tegradc.0: domain=ffffffc0784f2d98 allocates as[0]=ffffffc078454248
[ 0.456030] iommu: Adding device 54340000.vic to group 15
[ 0.456247] iommu: Adding device 544c0000.nvenc to group 16
[ 0.456492] iommu: Adding device 54500000.tsec to group 17
[ 0.456704] iommu: Adding device 54100000.tsecb to group 18
[ 0.456911] iommu: Adding device 54480000.nvdec to group 19
[ 0.457120] iommu: Adding device 54380000.nvjpg to group 20
[ 0.457863] iommu: Adding device 546c0000.i2c to group 21
[ 0.458207] iommu: Adding device 57000000.gpu to group 22
[ 0.458270] platform 57000000.gpu: domain=ffffffc078554c18 allocates as[0]=ffffffc0784542b0
[ 0.458330] platform 57000000.gpu: domain=ffffffc078554c18 allocates as[1]=ffffffc078454318
[ 0.458405] platform 57000000.gpu: domain=ffffffc078554c18 allocates as[2]=ffffffc078454380
[ 0.458458] platform 57000000.gpu: domain=ffffffc078554c18 allocates as[3]=ffffffc0784543e8
[ 0.459326] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.459364] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.459391] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.459409] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.459426] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.509337] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509371] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509406] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509490] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509784] iommu: Adding device 70012000.se to group 23
[ 0.510573] iommu: Adding device 7000c000.i2c to group 24
[ 0.510877] iommu: Adding device 7000c400.i2c to group 25
[ 0.511142] iommu: Adding device 7000c500.i2c to group 26
[ 0.511406] iommu: Adding device 7000c700.i2c to group 27
[ 0.511671] iommu: Adding device 7000d000.i2c to group 28
[ 0.511931] iommu: Adding device 7000d100.i2c to group 29
[ 0.512250] iommu: Adding device sdhci-tegra.0 to group 30
[ 0.512314] platform sdhci-tegra.0: domain=ffffffc07856be58 allocates as[0]=ffffffc078454450
[ 0.513144] iommu: Adding device 700d0000.xudc to group 31
[ 0.516288] vdd-ac-bat: 5000 mV
[ 0.516683] vdd-5v0-sys: 5000 mV
[ 0.517636] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.517694] vdd-5v0-hdmi: 5000 mV
[ 0.518085] vdd-1v8-sys: 1800 mV
[ 0.518512] vdd-fan: supplied by vdd-5v0-sys
[ 0.518585] vdd-fan: 5000 mV
[ 0.519000] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.519049] vdd-usb-vbus: 5000 mV
[ 0.519596] vdd-usb-vbus2: 5000 mV
[ 0.554261] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.556645] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.557842] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.557880] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.557929] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.558307] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.566207] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.566576] SCSI subsystem initialized
[ 0.567075] usbcore: registered new interface driver usbfs
[ 0.567145] usbcore: registered new interface driver hub
[ 0.567229] usbcore: registered new device driver usb
[ 0.571085] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.577293] vdd-core: 600 <–> 1162 mV at 1125 mV
[ 0.577466] random: fast init done
[ 0.578341] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.581184] vdd-ddr-1v1: 1150 mV
[ 0.585216] vdd-pre-reg-1v35: 1350 mV
[ 0.589170] vdd-1v8: 1800 mV
[ 0.593167] avdd-sys-1v2: 1200 mV
[ 0.597169] vdd-pex-1v0: 1050 mV
[ 0.597846] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.598394] max77620-ldo3: at 3100 mV
[ 0.601169] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.601741] max77620-ldo5: at 3100 mV
[ 0.602288] max77620-ldo6: at 2800 mV
[ 0.605168] avdd-1v05-pll: 1050 mV
[ 0.609168] avdd-io-hdmi-dp: 1050 mV
[ 0.611816] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.612105] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.612413] max77620 4-003c: max77620 probe successful
[ 0.615056] media: Linux media interface: v0.10
[ 0.615127] Linux video capture interface: v2.00
[ 0.616076] pps_core: LinuxPPS API ver. 1 registered
[ 0.616099] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.616143] PTP clock support registered
[ 0.619389] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.620252] Advanced Linux Sound Architecture Driver Initialized.
[ 0.620925] Bluetooth: Core ver 2.22
[ 0.620989] NET: Registered protocol family 31
[ 0.621008] Bluetooth: HCI device and connection manager initialized
[ 0.621038] Bluetooth: HCI socket layer initialized
[ 0.621059] Bluetooth: L2CAP socket layer initialized
[ 0.621095] Bluetooth: SCO socket layer initialized
[ 0.622879] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.622917] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.622979] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.623006] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.626596] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.627894] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.627982] vdd-3v3-sys: 3300 mV
[ 0.628278] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.633461] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.633956] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.634009] vdd-3v3-sd: 3300 mV
[ 0.635092] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.635144] avdd-io-edp-1v05: 1050 mV
[ 0.635607] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.635660] vdd-usb-hub-en: 5000 mV
[ 0.637088] camchar: rtcpu character device driver loaded
[ 0.637992] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.639321] clocksource: Switched to clocksource arch_sys_counter
[ 0.679150] VFS: Disk quotas dquot_6.6.0
[ 0.679365] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.679867] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.680274] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.680308] nvmap_page_pool_init: Total RAM pages: 502953
[ 0.680325] nvmap_page_pool_init: nvmap page pool size: 62869 pages (245 MB)
[ 0.680452] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.680701] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.680900] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.689943] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.690497] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.690902] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.691216] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.691467] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.691765] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.691786] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.692239] NET: Registered protocol family 2
[ 0.693223] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.693358] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.693620] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.693776] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.693837] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.694199] NET: Registered protocol family 1
[ 0.694911] RPC: Registered named UNIX socket transport module.
[ 0.694935] RPC: Registered udp transport module.
[ 0.694951] RPC: Registered tcp transport module.
[ 0.694966] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.695250] Trying to unpack rootfs image as initramfs…
[ 0.997745] Freeing initrd memory: 6992K
[ 1.007792] host1x 50000000.host1x: initialized
[ 1.009589] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.012803] audit: initializing netlink subsys (disabled)
[ 1.012900] audit: type=2000 audit(0.855:1): initialized
[ 1.013628] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 1.023360] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.024850] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.025670] 9p: Installing v9fs 9p2000 file system support
[ 1.029027] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.029189] io scheduler noop registered
[ 1.029490] io scheduler cfq registered (default)
[ 1.032199] gic 702f9000.agic: GIC IRQ controller registered
[ 1.035163] iommu: Adding device 702ef000.adsp to group 32
[ 1.044458] iommu: Adding device aconnect@702c0000:adsp_audio to group 33
[ 1.044629] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.045247] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x91c8412
[ 1.045275] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.046928] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.047054] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.047165] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.047445] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.047575] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.047695] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.047807] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.047916] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.048024] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.048125] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.055139] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.056945] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.058855] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.058918] tegra-pcie 1003000.pcie: PHY get deferred: -517
[ 1.058937] tegra-pcie 1003000.pcie: failed to get PHYs: -517
[ 1.060370] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.060620] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 1.060863] Adding domain tsec-pd to PM domain host1x-pd
[ 1.063790] tsec 54500000.tsec: initialized
[ 1.065204] tsec 54100000.tsecb: initialized
[ 1.065915] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.069640] nvdec 54480000.nvdec: initialized
[ 1.070735] Adding domain vic03-pd to PM domain host1x-pd
[ 1.070933] Adding domain msenc-pd to PM domain host1x-pd
[ 1.071104] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.075308] falcon 54340000.vic: initialized
[ 1.076592] falcon 544c0000.nvenc: initialized
[ 1.077930] falcon 54380000.nvjpg: initialized
[ 1.082271] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=95
[ 1.082351] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.082390] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.082399] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.082515] display board info: id 0x0, fab 0x0
[ 1.082588] generic_infoframe_type: 0x87
[ 1.082681] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.082702] tegra_cec 70015000.tegra_cec: probed
[ 1.082746] tegradc tegradc.0: DT parsed successfully
[ 1.082812] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.090044] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.095300] tegradc tegradc.0: probed
[ 1.095384] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.096208] Console: switching to colour frame buffer device 80x30
[ 1.096221] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.096225] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.096275] tegradc tegradc.0: fb registered
[ 1.096693] kfuse 7000fc00.kfuse: initialized
[ 1.097686] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.098515] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.099493] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.099522] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.099905] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.101226] vdd-gpu: applied init 1000000uV constraint
[ 1.101245] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.101634] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.105269] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.105385] No Device Node present for smmu client: serial8250 !!
[ 1.105404] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.105453] iommu: Adding device serial8250 to group 34
[ 1.107782] console [ttyS0] disabled
[ 1.107869] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 2.110780] tegra_cec 70015000.tegra_cec: Can’t find physical addresse.
[ 2.110786] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 3.324910] console [ttyS0] enabled
[ 3.329463] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.338692] serial-tegra 70006200.serial: RX in PIO mode
[ 3.344124] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.354015] [drm] Initialized
[ 3.367398] brd: module loaded
[ 3.375895] loop: module loaded
[ 3.379163] tegra_profiler: version: 1.143, samples/io: 48/28
[ 3.385061] tegra_profiler: auth: init
[ 3.390182] THERMAL EST: found 2 subdevs
[ 3.394146] THERMAL EST num_resources: 0
[ 3.398081] [THERMAL EST subdev 0]
[ 3.401524] [THERMAL EST subdev 1]
[ 3.405389] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.414359] THERMAL EST: thz register success.
[ 3.418950] THERMAL EST: end of probe, return err: 0
[ 3.425085] sd: No Scsi addr parsed to reserve index
[ 3.430129] hisi_sas: driver version v1.6
[ 3.438755] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.446043] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.451475] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.466391] libphy: Fixed MDIO Bus: probed
[ 3.471692] tun: Universal TUN/TAP device driver, 1.6
[ 3.476766] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.483953] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.489808] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.495791] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.502757] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.508395] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.516230] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.522204] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.529172] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.535501] PPP generic driver version 2.4.2
[ 3.539976] PPP BSD Compression module registered
[ 3.544695] PPP Deflate Compression module registered
[ 3.549794] PPP MPPE Compression module registered
[ 3.554595] NET: Registered protocol family 24
[ 3.559118] usbcore: registered new interface driver r8152
[ 3.564655] usbcore: registered new interface driver asix
[ 3.570111] usbcore: registered new interface driver ax88179_178a
[ 3.576247] usbcore: registered new interface driver cdc_ether
[ 3.582126] usbcore: registered new interface driver net1080
[ 3.587824] usbcore: registered new interface driver cdc_subset
[ 3.593787] usbcore: registered new interface driver zaurus
[ 3.599422] usbcore: registered new interface driver cdc_ncm
[ 3.605243] VFIO - User Level meta-driver version: 0.3
[ 3.611566] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.618121] ehci-pci: EHCI PCI platform driver
[ 3.622618] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.628813] ohci-pci: OHCI PCI platform driver
[ 3.633307] ohci-platform: OHCI generic platform driver
[ 3.640206] usbcore: registered new interface driver uas
[ 3.645596] usbcore: registered new interface driver usb-storage
[ 3.651713] usbcore: registered new interface driver usbserial
[ 3.661153] mousedev: PS/2 mouse device common for all mice
[ 3.666825] usbcore: registered new interface driver xpad
[ 3.803308] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.813110] rtc rtc1: alarm rtc device
[ 3.816896] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.824068] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.830780] i2c /dev entries driver
[ 3.836166] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.865438] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.872051] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.879655] imx219 6-0010: board setup failed
[ 3.884091] imx219: probe of 6-0010 failed with error -121
[ 3.890771] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.900042] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.907133] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.914547] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.923886] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.932863] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.941894] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.951221] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.960188] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.969219] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.978537] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.987505] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.995555] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 4.003413] tegra_aotag tegra-aotag: Registering sensor 0
[ 4.008912] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 4.014157] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 4.020634] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.029974] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 4.038198] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 4.046954] parse_throttle_dt_data: Num cap clks = 6
[ 4.051935] parse_throttle_dt_data: clk=cclk_g type=2
[ 4.057012] parse_throttle_dt_data: clk=gpu type=4
[ 4.061836] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 4.067962] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 4.074085] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 4.080102] parse_throttle_dt_data: clk=emc type=3
[ 4.085288] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.094716] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.104174] tegra_throttle_probe: probe successful. #cdevs=4
[ 4.110567] FAN dev name: pwm-fan
[ 4.113972] FAN:gpio request success.
[ 4.117715] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.123673] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.130463] pwm_fan_driver pwm-fan: fan tach request irq success
[ 4.136485] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.141645] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.149221] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 4.156979] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.164814] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.172650] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.180483] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.188320] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.196154] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.203990] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.211912] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.222522] device-mapper: uevent: version 1.0.3
[ 4.227640] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.241705] tegra210-cpufreq cpufreq: probe()…completed
[ 4.247901] sdhci: Secure Digital Host Controller Interface driver
[ 4.254082] sdhci: Copyright(c) Pierre Ossman
[ 4.258436] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.264564] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 4.269734] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 4.276992] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 298
[ 4.287803] tegra-se 70012000.se: tegra_se_probe: complete
[ 4.293786] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.300495] usbcore: registered new interface driver usbhid
[ 4.306080] usbhid: USB HID core driver
[ 4.310873] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 4.317422] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 4.327637] nvpmodel: initialized successfully
[ 4.331583] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 4.342477] usbcore: registered new interface driver snd-usb-audio
[ 4.348735] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.355104] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.365854] iommu: Adding device snd-soc-dummy to group 35
[ 4.372771] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.393780] OPE platform probe
[ 4.396984] OPE platform probe successful
[ 4.401265] OPE platform probe
[ 4.404416] OPE platform probe successful
[ 4.433428] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.439376] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.445264] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.451155] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.457066] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.462950] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.468833] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.474716] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.480617] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.486498] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.504333] u32 classifier
[ 4.507040] Actions configured
[ 4.510516] Initializing XFRM netlink socket
[ 4.515509] NET: Registered protocol family 10
[ 4.520660] NET: Registered protocol family 17
[ 4.525147] NET: Registered protocol family 15
[ 4.529677] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.542783] Bluetooth: RFCOMM socket layer initialized
[ 4.547940] Bluetooth: RFCOMM ver 1.11
[ 4.551703] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.557658] Bluetooth: HIDP socket layer initialized
[ 4.562648] 9pnet: Installing 9P2000 support
[ 4.566959] Key type dns_resolver registered
[ 4.572297] Registered cp15_barrier emulation handler
[ 4.577434] Registered setend emulation handler
[ 4.583228] registered taskstats version 1
[ 4.587869] Adding domain ve2-pd to PM domain host1x-pd
[ 4.593363] Adding domain ve-pd to PM domain host1x-pd
[ 4.600801] isp 54600000.isp: initialized
[ 4.605851] isp 54680000.isp: initialized
[ 4.620200] last reset is due to power on reset
[ 4.624757] KERNEL: PMC reset status reg: 0x0
[ 4.629179] BL: PMC reset status reg: 0x0
[ 4.633200] BL: PMIC poweroff Event Recorder: 0x40
[ 4.638666] vdd-usb-vbus-en: supplied by vdd-5v0-sys
[ 4.643669] vdd-usb-vbus-en: 5000 mV
[ 4.648560] clk_cbus_recalc_rate: no gbus parent
[ 4.653199] clk_cbus_round_rate: no gbus parent
[ 4.657758] clk_cbus_round_rate: no gbus parent
[ 4.662301] clk_cbus_recalc_rate: no gbus parent
[ 4.667030] clk_cbus_recalc_rate: no gbus parent
[ 4.671665] clk_cbus_round_rate: no gbus parent
[ 4.676213] clk_cbus_round_rate: no gbus parent
[ 4.680772] clk_cbus_recalc_rate: no gbus parent
[ 4.685422] tegra_dvfs: GPU-cap: registered
[ 4.689674] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.698398] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.707186] tegra dvfs: vdd-gpu: nominal 1088mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.717380] tegra_dvfs: vdd-gpu-vts: registered
[ 4.722070] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x91c8412
[ 4.729996] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 4.738494] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 4.747694] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 4.756924] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 4.766162] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 4.775617] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 4.785097] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 4.794550] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 4.804027] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 4.813478] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 4.822697] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 4.823677] mmc0: hw tuning done …
[ 4.823726] mmc0: new ultra high speed SDR104 SDHC card at address e624
[ 4.828200] mmcblk0: mmc0:e624 SD32G 29.7 GiB
[ 4.848021] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 4.854935] mmcblk0: p1
[ 4.855712] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 4.855841] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 4.856482] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 4.856497] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 4.857522] tegra-xusb 70090000.xusb: extcon 0: ffffffc07867b400 id
[ 4.858556] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 4.859056] tegra-xudc-new 700d0000.xudc: device count: 1
[ 4.859835] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 4.859841] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 4.860331] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.860729] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.860909] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 4.860934] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 4.860946] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 4.861662] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 4.861688] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 4.861787] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.861791] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.861794] usb usb1: Product: xHCI Host Controller
[ 4.861796] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 4.861799] usb usb1: SerialNumber: 70090000.xusb
[ 4.861921] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 4.862583] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 4.862750] hub 1-0:1.0: USB hub found
[ 4.862774] hub 1-0:1.0: 5 ports detected
[ 4.863085] input: gpio-keys as /devices/gpio-keys/input/input1
[ 4.863115] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 4.863125] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 4.863175] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.863236] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.863239] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.863242] usb usb2: Product: xHCI Host Controller
[ 4.863245] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 4.863247] usb usb2: SerialNumber: 70090000.xusb
[ 4.863668] hub 2-0:1.0: USB hub found
[ 4.863690] hub 2-0:1.0: 4 ports detected
[ 4.864200] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 4.864204] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 4.900155] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:14 UTC (946688414)
[ 4.901256] vi 54080000.vi: vi_probe: ++
[ 4.904458] vi 54080000.vi: initialized
[ 4.906487] vi 54080000.vi: subdev nvcsi–1 bound
[ 4.906731] mmcblk mmc0:e624: Card claimed for testing.
[ 4.907388] Disable partitions left on by BL
[ 4.907390] disb
[ 4.907430] bwmgr: missing cdev-type property
[ 4.907522] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.907528] DRAM derating cdev registered.
[ 4.908494] ALSA device list:
[ 4.908497] #0: tegra-hda at 0x70038000 irq 81
[ 4.908499] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.967378] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 4.975502] usb usb2: usb_suspend_both: status 0
[ 5.168812] Freeing unused kernel memory: 8576K
[ 5.187354] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[ 5.197451] Root device found: mmcblk0p1
[ 5.202837] Found dev node: /dev/mmcblk0p1
[ 5.211741] usb 1-3: New USB device found, idVendor=1a40, idProduct=0801
[ 5.218534] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.225703] usb 1-3: Product: USB 2.0 Hub
[ 5.230535] hub 1-3:1.0: USB hub found
[ 5.234397] hub 1-3:1.0: 4 ports detected
[ 5.312970] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 5.543345] usb 1-3.2: new low-speed USB device number 3 using tegra-xusb
[ 5.570347] EXT4-fs (mmcblk0p1): recovery complete
[ 5.575996] usb 1-3.2: New USB device found, idVendor=093a, idProduct=2521
[ 5.582946] usb 1-3.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 5.590312] usb 1-3.2: Product: USB OPTICAL MOUSE
[ 5.590420] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.592465] Rootfs mounted over mmcblk0p1
[ 5.611943] input: USB OPTICAL MOUSE as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2:1.0/0003:093A:2521.0001/input/input2
[ 5.623181] hid-generic 0003:093A:2521.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE] on usb-70090000.xusb-3.2/input0
[ 5.635841] Switching from initrd to actual rootfs
[ 5.773348] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 5.797063] systemd[1]: System time before build time, advancing clock.
[ 5.831704] cgroup: cgroup2: unknown option “nsdelegate”
[ 5.852439] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.865985] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.871327] usb 1-3.1: new low-speed USB device number 4 using tegra-xusb
[ 5.888317] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.909986] usb 1-3.1: New USB device found, idVendor=1a2c, idProduct=0c21
[ 5.910457] systemd[1]: Detected architecture arm64.
[ 5.921854] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.929169] usb 1-3.1: Product: USB Keyboard
[ 5.933452] usb 1-3.1: Manufacturer: USB
[ 5.941166] input: USB USB Keyboard as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.0/0003:1A2C:0C21.0002/input/input3
[ 5.956116] systemd[1]: Set hostname to <localhost.localdomain>.
[ 6.011748] hid-generic 0003:1A2C:0C21.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keyboard] on usb-70090000.xusb-3.1/input0
[ 6.028143] input: USB USB Keyboard as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.1/0003:1A2C:0C21.0003/input/input4
[ 6.077940] systemd[1]: Configuration file /lib/systemd/system/system.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.092141] systemd[1]: Configuration file /lib/systemd/system/system.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.108899] hid-generic 0003:1A2C:0C21.0003: input,hidraw2: USB HID v1.10 Mouse [USB USB Keyboard] on usb-70090000.xusb-3.1/input1
[ 6.120974] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.135235] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.151231] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.165664] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.182019] systemd[1]: Configuration file /lib/systemd/system/graphical.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.273569] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 6.281098] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 6.330552] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.339230] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.348114] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.391684] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 6.398093] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 6.404346] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 6.404351] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 6.404356] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 6.404614] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 6.414087] systemd-journald[1971]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.414099] systemd-journald[1971]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.415454] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 6.415458] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.415464] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 6.415481] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 6.415497] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.415504] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 6.415507] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 6.415512] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 6.415798] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 6.415801] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 6.416095] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 6.416111] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 6.430823] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 6.430887] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:2e:db:33 from device tree
[ 6.431386] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 6.431401] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
[ 6.431401] This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
[ 6.431401] This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
Ubuntu 18.04.5 LTS localhost.localdomain ttyS0
localhost login:
