Boot timeout on ttyGS0 and getty
I am seeing a long timeout on dev-ttyGS0 and dev-getty. I don’t seem to be able to disable it with systemctl. Any ideas? I am using the latest jetpack 4.4.1 on both nx and nano platforms. The syslog from my nano:
Dec 23 00:52:39 nano-devX systemd[1]: sys-subsystem-net-devices-multi-user.device: Job sys-subsystem-net-devices-multi-user.device/start timed out.
Dec 23 00:52:39 nano-devX systemd[1]: Timed out waiting for device sys-subsystem-net-devices-multi-user.device.
Dec 23 00:52:39 nano-devX systemd[1]: Dependency failed for WPA supplicant daemon (interface-specific version).
Dec 23 00:52:39 nano-devX systemd[1]: wpa_supplicant@multi-user.service: Job wpa_supplicant@multi-user.service/start failed with result ‘dependency’.
Dec 23 00:52:39 nano-devX systemd[1]: Dependency failed for WPA supplicant daemon (interface- and wired driver-specific version).
Dec 23 00:52:39 nano-devX systemd[1]: wpa_supplicant-wired@multi-user.service: Job wpa_supplicant-wired@multi-user.service/start failed with result ‘dependency’.
Dec 23 00:52:39 nano-devX systemd[1]: sys-subsystem-net-devices-multi-user.device: Job sys-subsystem-net-devices-multi-user.device/start failed with result ‘timeout’.
Dec 23 00:52:39 nano-devX systemd[1]: dev-getty.device: Job dev-getty.device/start timed out.
Dec 23 00:52:39 nano-devX systemd[1]: Timed out waiting for device dev-getty.device.
Dec 23 00:52:39 nano-devX systemd[1]: Dependency failed for Serial Getty on getty.
Dec 23 00:52:39 nano-devX systemd[1]: serial-getty@getty.service: Job serial-getty@getty.service/start failed with result ‘dependency’.
Dec 23 00:52:39 nano-devX systemd[1]: dev-getty.device: Job dev-getty.device/start failed with result ‘timeout’.
Dec 23 00:52:39 nano-devX systemd[1]: Reached target Network.
Dec 23 00:52:39 nano-devX systemd[1]: Reached target Network is Online.
Dec 23 01:50:59 nano-devX systemd[1]: dev-ttyGS0.device: Job dev-ttyGS0.device/stop timed out.
Dec 23 01:50:59 nano-devX systemd[1]: Timed out stopping /dev/ttyGS0.
Dec 23 01:50:59 nano-devX systemd[1]: dev-ttyGS0.device: Job dev-ttyGS0.device/stop failed with result ‘timeout’.
Dec 23 02:12:14 nano-devX systemd[1]: dev-ttyGS0.device: Job dev-ttyGS0.device/stop timed out.
Dec 23 02:12:14 nano-devX systemd[1]: Timed out stopping /dev/ttyGS0.
Dec 23 02:12:14 nano-devX systemd[1]: dev-ttyGS0.device: Job dev-ttyGS0.device/stop failed with result ‘timeout’.
