Hello all,
Is there a way to boot and then shut down the TX2 at a specific time every day assuming it is powered all the time?
Ray
Hello all,
Ray
The Jetson TX2 module technical reference manual does document “alarm” functions for the built-in real-time-clock.
However, it doesn’t document any APIs for setting or activating based on those alarms.
So, the answer is probably, “yes, it is technically possible, and no, it’s not currently easy because you’d need to get access to the internal NVIDIA driver development team, which means you need to have a solid business case.”
