There wouldn’t be any support for this since mixing releases (as you have found out) usually results in a failed system. There are strong dependencies. I will suggest the mixing of R28.x with R32.x kernels is unlikely to have a satisfactory result, and this is probably a “bad idea” (especially since boot content packages in R32.5.1 might update and you’d probably need to disable this update and test each update if you manage to get it to work). However, and I can’t make suggestions beyond what is below, here are some things to think about (this is more or less just because it is an interesting question, not because I think this would succeed, but answering these questions would greatly improve understanding how boot works/fails when mixing releases)…
You might consider that the failure is perhaps in an initrd
(if used) rather than the main rootfs. Don’t know, just suggesting initrd
is something to consider. Examine initrd
of the R28.1 system and compare to the R32.5.1 system. For example, make sure it is able to find the modules for the correct kernel, both for what it loads in the initrd
, and for the rootfs at “/lib/modules/$(uname -r)/kernel
Also note that the kernel itself is PID 0, and the first thing the kernel runs (once it finishes loading) is init
(PID 1). I suspect that the content of init
also changes between R28.1 and R32.5.1 (probably by a lot), and if the kernel works, but init
is wrong, then it would simply stop where it is at.
Parts of init
have to be considered within any initrd
as a way of passing a working environment to the actual rootfs (for example, if the ext4
filesystem driver is in the form of a module, then the module must exist in the initrd
before the full rootfs can ever load). Then the init
which is part of the rootfs (and not initrd
“miniature” init
) would also have to work with that version of init
(R28.1 and R32.5.1 have very different init
If you are not using an initrd
in the newer release with older kernel, then you might be able to write an initrd
“adapter” should you find some incompatibility between the two versions of init
Very likely you will want to disable any “quiet” argument for logging, add printk
statements to say when various init
stages have been reached (especially the very first line of init
), and figure out if it is really init
which is failing. I recommend practicing on a working R32.5.1 system and seeing if you can get serial console to echo log lines to the console at various stages of the init
software (distinguishing between initrd
init
lines and rootfs init
). You probably must entirely use all of the R32.5.1 boot content up until kernel load and init
(except perhaps some edits to device tree or environment variables).
Another thing to check is what you see in “/proc/cmdline
” for a purely R28.1 system versus the R32.5.1 system. If you look at “/boot/extlinux/extlinux.conf
”, then you’ll see that kernel arguments start by inheriting from the bootloader via the “${cbootargs}
”. Read up on boot chains and see if you can find the entire origin of what ends up in cbootargs
and any differences to what you see.
Remember that an argument to the kernel is visible to any kernel module or driver, and that the arguments which work for an R32.5.1 kernel might differ from what works for an R28.1 kernel.
Note that the sources of what is inherited in cbootargs
(how loaded and from where) may differ in older boot content versus newer boot content. You’ll probably need to go through docs for both releases to understand how this is cbootargs
variable derived. Also, realize that earlier boot stages can edit what the source of cbootargs
is prior to passing it to the kernel (so for example, if you know values in this variable start in a partition, you don’t know if that content will still be an exact match when it reaches cbootargs
for the kernel to inherit). I don’t know if that content would have an effect stopping an older kernel from working, but if you were to use R28.1 boot content to reach the kernel cmdline, then boot probably would fail or behave oddly.
