Booting does not complete on Jetson Xavier NX & Quark Carrier - Please complete system configuration setup on the serial port provided by Jetson's
I filled the Support Form. When can you provide an answer? Thank you.
PROBLEM SOLVED!
I realized that the problem was being caused by the commands. The following commands didn’t work: “sudo ./l4t_create_default_user.sh -u nvidia -p nvidia” & “sudo ./l4t_create_default_user.sh -u nvidia -p nvidia -a”.
I changed it to “sudo ./l4t_create_default_user.sh -u ubuntu -a” and it worked! Thank you for the great support, WayneWWW!
You better still waiting for ConnectTeach team’s reply for it. As I said, the script is just for debug purpose.
The script worked well for debugging. Now I can access the board and use it properly. I haven’t had any problem. Thank you for your support again.
