I generated the BUP using your command above
sudo FAB=100 BOARDID=3668 FUSELEVEL=fuselev
el_production BOARDSKU=0001 ./build_l4t_bup.sh -u $ROOT_DIR/keys/sd/jetson.pem -v $ROOT_DIR/keys/sd/sbk_key.txt jetson-xavier-nx-devkit-emmc mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 6.0
# User release: 0.0
Board ID(3668) version(100) sku(0001) revision()
lz4c installed at /usr/bin/lz4c
Compressing /home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb ...
NVDISP+UEFI in bootloader/nvdisp-init.bin ..
copying bctfile(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying minratchet_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
copying device_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi-l4t.cfg)... done.
copying dev_params_b(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct_b-qspi-l4t.cfg)... done.
Existing bootloader(/home/adit/jetson/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/adit/jetson/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Existing sosfile(/home/adit/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/adit/jetson/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/adit/jetson/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/adit/jetson/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/adit/jetson/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/adit/jetson/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/adit/jetson/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/adit/jetson/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/adit/jetson/Linux_for_Tegra/bootloader/bpmp-2_t194.bin) reused.
Existing bpfdtbfile(/home/adit/jetson/Linux_for_Tegra/bootloader/tegra194-a02-bpmp-p3668-a00_lz4.dtb) reused.
Existing scefile(/home/adit/jetson/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/adit/jetson/Linux_for_Tegra/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing apefile(/home/adit/jetson/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/adit/jetson/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/adit/jetson/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/adit/jetson/Linux_for_Tegra/bootloader/tos-optee_t194.img) reused.
Existing eksfile(/home/adit/jetson/Linux_for_Tegra/bootloader/eks_t194.img) reused.
copying soft_fuses(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
copying dtbfile(/home/adit/jetson/Linux_for_Tegra/kernel/dtb/tegra194-p3668-0001-p3509-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/adit/jetson/Linux_for_Tegra/bootloader/nvdisp-init.bin) reused.
copying tbcdtbfile(/home/adit/jetson/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
copying cfgfile(/home/adit/jetson/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t194_spi_emmc_p3668.xml) to flash.xml... done.
done.
Existing flasher(/home/adit/jetson/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/adit/jetson/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/adit/jetson/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/adit/jetson/Linux_for_Tegra/kernel/dtb/tegra194-p3668-p3509-overlay.dtbo)... done.
/home/adit/jetson/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/adit/jetson/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0xB8190000 --overlay_dtb L4TConfiguration.dtbo,tegra194-p3668-p3509-overlay.dtbo, --bldtb tegra194-p3668-all-p3509-0000.dtb --applet mb1_t194_prod.bin --cmd "sign" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi-l4t.cfg,tegra194-br-bct_b-qspi-l4t.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_lz4.dtb; spe_fw spe_t194.bin; tos tos-optee_t194.img; eks eks_t194.img; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb" --bct_backup --key /home/adit/jetson/keys/sd/jetson.pem --encrypt_key /home/adit/jetson/keys/sd/sbk_key.txt
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0237 ] Using default ramcode: 0
[ 0.0237 ] Disable BPMP dtb trim, using default dtb
[ 0.0237 ]
[ 0.0272 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --getmode mode.txt
[ 0.0282 ] Key size is 384 bytes
[ 0.0275 ] Generating RCM messages
[ 0.0308 ] tegrasign_v3.py --file mb1_t194_prod.bin --key /home/adit/jetson/keys/sd/sbk_key.txt --offset 4096
[ 0.0310 ] Key is a SBK key
[ 0.0310 ] Key Size is 16 bytes
[ 0.0401 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod_encrypt.bin zerosbk
[ 0.0408 ] Header already present for mb1_t194_prod_encrypt.bin
[ 0.0464 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --getmode mode.txt
[ 0.0473 ] Key size is 384 bytes
[ 0.0497 ] tegrasign_v3.py --file mb1_t194_prod_encrypt_sigheader.bin --key /home/adit/jetson/keys/sd/jetson.pem --length 1136 --getmontgomeryvalues montgomery.bin --offset 2960 --pubkeyhash pub_key.key
[ 0.0506 ] Key size is 384 bytes
[ 0.0885 ] Saving pkc public key in pub_key.key
[ 0.0885 ] Saving Montgomery values in montgomery.bin
[ 0.0894 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader mb1_t194_prod_encrypt_sigheader.bin mb1_t194_prod_encrypt_sigheader.sig oem-rsa
[ 0.0944 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0973 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0981 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0984 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0985 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0985 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0985 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0985 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0985 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0985 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0985 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0985 ]
[ 0.1004 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_encrypt_sigheader.bin 0 0
[ 0.1011 ] RCM 0 is saved as rcm_0.rcm
[ 0.1034 ] RCM 1 is saved as rcm_1.rcm
[ 0.1035 ] RCM 2 is saved as rcm_2.rcm
[ 0.1036 ] List of rcm files are saved in rcm_list.xml
[ 0.1036 ]
[ 0.1036 ] Signing RCM messages
[ 0.1070 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.1079 ] Key size is 384 bytes
[ 0.2193 ] Saving pkc public key in pub_key.key
[ 0.2193 ] Saving Montgomery values in montgomery.bin
[ 0.2180 ] Copying signature to RCM mesages
[ 0.2201 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 0.2215 ] odmdata (to decode) = 3088646144
[ 0.2215 ] Odmdata strings: PCIE_XBAR_8_1_1_0_1,UFS_DISABLED,NVHS_PCIE,enable-debug-console,enable-denver-wdt
[ 0.2215 ] Bpmp odmdata config: {'pcie-xbar-config': [0, 1, 'PCIE_XBAR_8_1_1_0_1'], 'pcie-c0-endpoint-enable': [1, 0, ''], 'pcie-c4-endpoint-enable': [1, 0, ''], 'ufs-config': [0, 1, 'UFS_DISABLED'], 'sata-enable': [1, 0, ''], 'nvhs-owner': [0, 1, 'PCIE'], 'pcie-c5-endpoint-enable': [1, 0, '']}
[ 0.2227 ] bpmp_dtb is compressed; decompressing...
[ 0.2227 ] lz4c -df tegra194-a02-bpmp-p3668-a00_lz4.dtb tegra194-a02-bpmp-p3668-a00_lz4_with_odm.dtb
[ 0.2248 ] tegra194-a02-bpmp-p3 : decoded 606912 bytes
[ 0.2248 ]
[ 0.3648 ] Re-compressing updated bpmp_dtb
[ 0.3649 ] lz4c -zf tegra194-a02-bpmp-p3668-a00_lz4_with_odm.dtb tegra194-a02-bpmp-p3668-a00_lz4.dtb
[ 0.3673 ] Compressed 606849 bytes into 38768 bytes ==> 6.39%
[ 0.3673 ]
[ 0.6893 ] Concatenating L4TConfiguration.dtbo,tegra194-p3668-p3509-overlay.dtbo to tegra194-p3668-all-p3509-0000_with_odm_overlay.dtb
[ 0.6897 ] Parsing partition layout
[ 0.6920 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.6935 ] Creating list of images to be signed
[ 0.6956 ] tegrahost_v2 --chip 0x19 --partitionlayout flash.xml.bin --list images_list.xml --ratchet_blob ratchet_blob.bin
[ 0.6965 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[ 0.6975 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[ 0.6978 ] MB1: Nvheader already present is mb1_b_t194_prod_aligned.bin
[ 0.6998 ] Header already present for mb1_b_t194_prod_aligned_sigheader.bin
[ 0.7002 ] adding BCH for spe_t194_aligned.bin
[ 0.7019 ] adding BCH for nvtboot_t194_aligned.bin
[ 0.7037 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 0.7070 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 0.7074 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 0.7145 ] Header already present for warmboot_t194_prod_aligned.bin
[ 0.7646 ] adding BCH for nvdisp-init_aligned.bin
[ 0.7708 ] adding BCH for tegra194-p3668-all-p3509-0000_aligned.dtb
[ 0.8206 ] adding BCH for tos-optee_t194_aligned.img
[ 0.8276 ] adding BCH for eks_t194_aligned.img
[ 0.8450 ] adding BCH for adsp-fw_aligned.bin
[ 0.8455 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 0.8525 ] adding BCH for bpmp-2_t194_aligned.bin
[ 0.8624 ] adding BCH for tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb
[ 0.8780 ] adding BCH for spe_t194_aligned.bin
[ 0.8786 ] adding BCH for nvtboot_t194_aligned.bin
[ 0.8803 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 0.8836 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 0.8841 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 0.8920 ] Header already present for warmboot_t194_prod_aligned.bin
[ 0.9452 ] adding BCH for nvdisp-init_aligned.bin
[ 0.9521 ] adding BCH for tegra194-p3668-all-p3509-0000_aligned.dtb
[ 1.0028 ] adding BCH for tos-optee_t194_aligned.img
[ 1.0103 ] adding BCH for eks_t194_aligned.img
[ 1.0282 ] adding BCH for adsp-fw_aligned.bin
[ 1.0290 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 1.0364 ] adding BCH for bpmp-2_t194_aligned.bin
[ 1.0465 ] adding BCH for tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb
[ 1.0666 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list images_list.xml --pubkeyhash pub_key.key
[ 1.0678 ] Key size is 384 bytes
[ 2.1095 ] Saving pkc public key in pub_key.key
[ 2.1082 ] Parsing dev params for multi chains
[ 2.1082 ] Generating br-bct
[ 2.1105 ] Performing cfg overlay
[ 2.1106 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 2.1108 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg
[ 2.1520 ] Updating dev and MSS params in BR BCT
[ 2.1521 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 2.2115 ] Updating bl info
[ 2.2139 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 2.2156 ] Generating br-bct
[ 2.2178 ] Performing cfg overlay
[ 2.2178 ] ['/home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg']
[ 2.2178 ] Updating dev and MSS params in BR BCT
[ 2.2178 ] tegrabct_v2 --dev_param tegra194-br-bct_b-qspi-l4t.cfg --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 2.2785 ] Updating bl info
[ 2.2808 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 2.2827 ] Generating BCT backup image
[ 2.2828 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 2.2839 ] 32768+0 records in
[ 2.3622 ] 32768+0 records out
[ 2.3622 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0778443 s, 421 kB/s
[ 2.3622 ]
[ 2.3622 ] Concatenating BCT for chain A to bct_backup.img
[ 2.3622 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 2.3635 ] 2888+0 records in
[ 2.3700 ] 2888+0 records out
[ 2.3700 ] 2888 bytes (2,9 kB, 2,8 KiB) copied, 0,0061559 s, 469 kB/s
[ 2.3700 ]
[ 2.3701 ] Concatenating BCT for chain B to bct_backup.img
[ 2.3701 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 2.3713 ] 2888+0 records in
[ 2.3778 ] 2888+0 records out
[ 2.3778 ] 2888 bytes (2,9 kB, 2,8 KiB) copied, 0,00618577 s, 467 kB/s
[ 2.3778 ]
[ 2.3810 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_aligned_sigheader_aligned.bin
[ 2.3821 ] header_magic: 4e564441
[ 2.3858 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mb1_t194_prod_aligned_sigheader_aligned.bin_list.xml
[ 2.3860 ] Key is a SBK key
[ 2.3860 ] Key Size is 16 bytes
[ 2.3962 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_aligned_sigheader_aligned.bin.encrypt mb1_t194_prod_aligned_sigheader_aligned.bin.hash zerosbk
[ 2.4026 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin_aligned.encrypt
[ 2.4039 ] header_magic: 4e564441
[ 2.4078 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mb1_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.4092 ] Key size is 384 bytes
[ 2.4461 ] Saving pkc public key in pub_key.key
[ 2.4474 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin_aligned.encrypt.signed mb1_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.4539 ] tegrahost_v2 --chip 0x19 --align mb1_b_t194_prod_aligned_sigheader_aligned.bin
[ 2.4550 ] header_magic: 4e564441
[ 2.4588 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mb1_b_t194_prod_aligned_sigheader_aligned.bin_list.xml
[ 2.4591 ] Key is a SBK key
[ 2.4591 ] Key Size is 16 bytes
[ 2.4688 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_b_t194_prod_aligned_sigheader_aligned.bin.encrypt mb1_b_t194_prod_aligned_sigheader_aligned.bin.hash zerosbk
[ 2.4749 ] tegrahost_v2 --chip 0x19 --align mb1_b_t194_prod_sigheader.bin_aligned.encrypt
[ 2.4760 ] header_magic: 4e564441
[ 2.4798 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mb1_b_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.4810 ] Key size is 384 bytes
[ 2.5181 ] Saving pkc public key in pub_key.key
[ 2.5194 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_b_t194_prod_sigheader.bin_aligned.encrypt.signed mb1_b_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.5259 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader_aligned.bin
[ 2.5269 ] header_magic: 4e564441
[ 2.5307 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list spe_t194_sigheader_aligned.bin_list.xml
[ 2.5310 ] Key is a SBK key
[ 2.5310 ] Key Size is 16 bytes
[ 2.5371 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader_aligned.bin.encrypt spe_t194_sigheader_aligned.bin.hash zerosbk
[ 2.5416 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin_aligned.encrypt
[ 2.5427 ] header_magic: 4e564441
[ 2.5464 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list spe_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.5476 ] Key size is 384 bytes
[ 2.5839 ] Saving pkc public key in pub_key.key
[ 2.5851 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin_aligned.encrypt.signed spe_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.5899 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader_aligned.bin
[ 2.5910 ] header_magic: 4e564441
[ 2.5948 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list nvtboot_t194_sigheader_aligned.bin_list.xml
[ 2.5950 ] Key is a SBK key
[ 2.5950 ] Key Size is 16 bytes
[ 2.6037 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader_aligned.bin.encrypt nvtboot_t194_sigheader_aligned.bin.hash zerosbk
[ 2.6093 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin_aligned.encrypt
[ 2.6105 ] header_magic: 4e564441
[ 2.6143 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list nvtboot_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.6155 ] Key size is 384 bytes
[ 2.6517 ] Saving pkc public key in pub_key.key
[ 2.6530 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin_aligned.encrypt.signed nvtboot_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.6589 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader_aligned.bin
[ 2.6600 ] header_magic: 4e564441
[ 2.6638 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list preboot_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 2.6640 ] Key is a SBK key
[ 2.6640 ] Key Size is 16 bytes
[ 2.6688 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader_aligned.bin.encrypt preboot_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 2.6726 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 2.6737 ] header_magic: 4e564441
[ 2.6774 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list preboot_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.6786 ] Key size is 384 bytes
[ 2.7146 ] Saving pkc public key in pub_key.key
[ 2.7160 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin_aligned.encrypt.signed preboot_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.7201 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader_aligned.bin
[ 2.7213 ] header_magic: 4e564441
[ 2.7250 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mce_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 2.7253 ] Key is a SBK key
[ 2.7253 ] Key Size is 16 bytes
[ 2.7326 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader_aligned.bin.encrypt mce_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 2.7376 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 2.7386 ] header_magic: 4e564441
[ 2.7424 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mce_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.7437 ] Key size is 384 bytes
[ 2.7800 ] Saving pkc public key in pub_key.key
[ 2.7813 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin_aligned.encrypt.signed mce_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.7889 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader_aligned.bin
[ 2.7901 ] header_magic: 4e564441
[ 2.7939 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mts_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 2.7941 ] Key is a SBK key
[ 2.7941 ] Key Size is 16 bytes
[ 2.8737 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader_aligned.bin.encrypt mts_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 2.9116 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 2.9127 ] header_magic: 4e564441
[ 2.9165 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mts_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.9177 ] Key size is 384 bytes
[ 2.9569 ] Saving pkc public key in pub_key.key
[ 2.9581 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin_aligned.encrypt.signed mts_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.0065 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader_aligned.bin
[ 3.0076 ] header_magic: 4e564441
[ 3.0114 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list warmboot_t194_prod_sigheader_aligned.bin_list.xml
[ 3.0116 ] Key is a SBK key
[ 3.0116 ] Key Size is 16 bytes
[ 3.0166 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader_aligned.bin.encrypt warmboot_t194_prod_sigheader_aligned.bin.hash zerosbk
[ 3.0206 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin_aligned.encrypt
[ 3.0217 ] header_magic: 4e564441
[ 3.0254 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list warmboot_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.0266 ] Key size is 384 bytes
[ 3.0626 ] Saving pkc public key in pub_key.key
[ 3.0638 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin_aligned.encrypt.signed warmboot_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.0696 ] tegrahost_v2 --chip 0x19 --align nvdisp-init_sigheader_aligned.bin
[ 3.0707 ] header_magic: 4e564441
[ 3.0744 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list nvdisp-init_sigheader_aligned.bin_list.xml
[ 3.0747 ] Key is a SBK key
[ 3.0747 ] Key Size is 16 bytes
[ 3.1489 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvdisp-init_sigheader_aligned.bin.encrypt nvdisp-init_sigheader_aligned.bin.hash zerosbk
[ 3.1833 ] tegrahost_v2 --chip 0x19 --align nvdisp-init_sigheader.bin_aligned.encrypt
[ 3.1843 ] header_magic: 4e564441
[ 3.1881 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list nvdisp-init_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.1892 ] Key size is 384 bytes
[ 3.2277 ] Saving pkc public key in pub_key.key
[ 3.2288 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvdisp-init_sigheader.bin_aligned.encrypt.signed nvdisp-init_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.2642 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader_aligned.dtb
[ 3.2654 ] header_magic: 4e564441
[ 3.2691 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list tegra194-p3668-all-p3509-0000_sigheader_aligned.dtb_list.xml
[ 3.2693 ] Key is a SBK key
[ 3.2693 ] Key Size is 16 bytes
[ 3.2806 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader_aligned.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader_aligned.dtb.hash zerosbk
[ 3.2873 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb_aligned.encrypt
[ 3.2884 ] header_magic: 4e564441
[ 3.2921 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list tegra194-p3668-all-p3509-0000_sigheader.dtb_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.2933 ] Key size is 384 bytes
[ 3.3296 ] Saving pkc public key in pub_key.key
[ 3.3308 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb_aligned.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.3386 ] tegrahost_v2 --chip 0x19 --align tos-optee_t194_sigheader_aligned.img
[ 3.3397 ] header_magic: 4e564441
[ 3.3434 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list tos-optee_t194_sigheader_aligned.img_list.xml
[ 3.3436 ] Key is a SBK key
[ 3.3436 ] Key Size is 16 bytes
[ 3.3723 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-optee_t194_sigheader_aligned.img.encrypt tos-optee_t194_sigheader_aligned.img.hash zerosbk
[ 3.3870 ] tegrahost_v2 --chip 0x19 --align tos-optee_t194_sigheader.img_aligned.encrypt
[ 3.3881 ] header_magic: 4e564441
[ 3.3919 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list tos-optee_t194_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.3931 ] Key size is 384 bytes
[ 3.4300 ] Saving pkc public key in pub_key.key
[ 3.4313 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-optee_t194_sigheader.img_aligned.encrypt.signed tos-optee_t194_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.4464 ] tegrahost_v2 --chip 0x19 --align eks_t194_sigheader_aligned.img
[ 3.4476 ] header_magic: 4e564441
[ 3.4513 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list eks_t194_sigheader_aligned.img_list.xml
[ 3.4515 ] Key is a SBK key
[ 3.4515 ] Key Size is 16 bytes
[ 3.4554 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_t194_sigheader_aligned.img.encrypt eks_t194_sigheader_aligned.img.hash zerosbk
[ 3.4590 ] tegrahost_v2 --chip 0x19 --align eks_t194_sigheader.img_aligned.encrypt
[ 3.4601 ] header_magic: 4e564441
[ 3.4639 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list eks_t194_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.4651 ] Key size is 384 bytes
[ 3.5009 ] Saving pkc public key in pub_key.key
[ 3.5021 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_t194_sigheader.img_aligned.encrypt.signed eks_t194_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.5060 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader_aligned.bin
[ 3.5071 ] header_magic: 4e564441
[ 3.5108 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list adsp-fw_sigheader_aligned.bin_list.xml
[ 3.5110 ] Key is a SBK key
[ 3.5111 ] Key Size is 16 bytes
[ 3.5233 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader_aligned.bin.encrypt adsp-fw_sigheader_aligned.bin.hash zerosbk
[ 3.5307 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin_aligned.encrypt
[ 3.5318 ] header_magic: 4e564441
[ 3.5356 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list adsp-fw_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.5368 ] Key size is 384 bytes
[ 3.5729 ] Saving pkc public key in pub_key.key
[ 3.5741 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin_aligned.encrypt.signed adsp-fw_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.5821 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-t194-rce_sigheader_aligned.img
[ 3.5832 ] header_magic: 4e564441
[ 3.5869 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list camera-rtcpu-t194-rce_sigheader_aligned.img_list.xml
[ 3.5871 ] Key is a SBK key
[ 3.5871 ] Key Size is 16 bytes
[ 3.6026 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-t194-rce_sigheader_aligned.img.encrypt camera-rtcpu-t194-rce_sigheader_aligned.img.hash zerosbk
[ 3.6114 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt
[ 3.6126 ] header_magic: 4e564441
[ 3.6163 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.6175 ] Key size is 384 bytes
[ 3.6537 ] Saving pkc public key in pub_key.key
[ 3.6549 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt.signed camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.6658 ] tegrahost_v2 --chip 0x19 --align bpmp-2_t194_sigheader_aligned.bin
[ 3.6669 ] header_magic: 4e564441
[ 3.6707 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list bpmp-2_t194_sigheader_aligned.bin_list.xml
[ 3.6709 ] Key is a SBK key
[ 3.6709 ] Key Size is 16 bytes
[ 3.6965 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp-2_t194_sigheader_aligned.bin.encrypt bpmp-2_t194_sigheader_aligned.bin.hash zerosbk
[ 3.7099 ] tegrahost_v2 --chip 0x19 --align bpmp-2_t194_sigheader.bin_aligned.encrypt
[ 3.7111 ] header_magic: 4e564441
[ 3.7148 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list bpmp-2_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.7160 ] Key size is 384 bytes
[ 3.7526 ] Saving pkc public key in pub_key.key
[ 3.7538 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp-2_t194_sigheader.bin_aligned.encrypt.signed bpmp-2_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.7703 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_lz4_sigheader_aligned.dtb
[ 3.7714 ] header_magic: 4e564441
[ 3.7751 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list tegra194-a02-bpmp-p3668-a00_lz4_sigheader_aligned.dtb_list.xml
[ 3.7753 ] Key is a SBK key
[ 3.7753 ] Key Size is 16 bytes
[ 3.7800 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_lz4_sigheader_aligned.dtb.encrypt tegra194-a02-bpmp-p3668-a00_lz4_sigheader_aligned.dtb.hash zerosbk
[ 3.7840 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_aligned.encrypt
[ 3.7851 ] header_magic: 4e564441
[ 3.7889 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.7901 ] Key size is 384 bytes
[ 3.8259 ] Saving pkc public key in pub_key.key
[ 3.8272 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_aligned.encrypt.signed tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.8313 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader_aligned.bin
[ 3.8324 ] header_magic: 4e564441
[ 3.8362 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list spe_t194_sigheader_aligned.bin_list.xml
[ 3.8365 ] Key is a SBK key
[ 3.8365 ] Key Size is 16 bytes
[ 3.8424 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader_aligned.bin.encrypt spe_t194_sigheader_aligned.bin.hash zerosbk
[ 3.8470 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin_aligned.encrypt
[ 3.8481 ] header_magic: 4e564441
[ 3.8519 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list spe_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.8531 ] Key size is 384 bytes
[ 3.8892 ] Saving pkc public key in pub_key.key
[ 3.8904 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin_aligned.encrypt.signed spe_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.8952 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader_aligned.bin
[ 3.8964 ] header_magic: 4e564441
[ 3.9002 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list nvtboot_t194_sigheader_aligned.bin_list.xml
[ 3.9004 ] Key is a SBK key
[ 3.9004 ] Key Size is 16 bytes
[ 3.9089 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader_aligned.bin.encrypt nvtboot_t194_sigheader_aligned.bin.hash zerosbk
[ 3.9147 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin_aligned.encrypt
[ 3.9159 ] header_magic: 4e564441
[ 3.9198 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list nvtboot_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.9211 ] Key size is 384 bytes
[ 3.9572 ] Saving pkc public key in pub_key.key
[ 3.9583 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin_aligned.encrypt.signed nvtboot_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.9642 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader_aligned.bin
[ 3.9654 ] header_magic: 4e564441
[ 3.9692 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list preboot_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 3.9694 ] Key is a SBK key
[ 3.9694 ] Key Size is 16 bytes
[ 3.9739 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader_aligned.bin.encrypt preboot_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 3.9776 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 3.9786 ] header_magic: 4e564441
[ 3.9824 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list preboot_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.9836 ] Key size is 384 bytes
[ 4.0196 ] Saving pkc public key in pub_key.key
[ 4.0208 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin_aligned.encrypt.signed preboot_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.0248 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader_aligned.bin
[ 4.0260 ] header_magic: 4e564441
[ 4.0298 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mce_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 4.0300 ] Key is a SBK key
[ 4.0300 ] Key Size is 16 bytes
[ 4.0371 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader_aligned.bin.encrypt mce_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 4.0428 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 4.0440 ] header_magic: 4e564441
[ 4.0479 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mce_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.0493 ] Key size is 384 bytes
[ 4.0853 ] Saving pkc public key in pub_key.key
[ 4.0865 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin_aligned.encrypt.signed mce_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.0950 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader_aligned.bin
[ 4.0962 ] header_magic: 4e564441
[ 4.0999 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mts_c10_prod_cr_sigheader_aligned.bin_list.xml
[ 4.1002 ] Key is a SBK key
[ 4.1002 ] Key Size is 16 bytes
[ 4.1799 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader_aligned.bin.encrypt mts_c10_prod_cr_sigheader_aligned.bin.hash zerosbk
[ 4.2307 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin_aligned.encrypt
[ 4.2318 ] header_magic: 4e564441
[ 4.2355 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mts_c10_prod_cr_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.2366 ] Key size is 384 bytes
[ 4.2755 ] Saving pkc public key in pub_key.key
[ 4.2768 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin_aligned.encrypt.signed mts_c10_prod_cr_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.3142 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader_aligned.bin
[ 4.3153 ] header_magic: 4e564441
[ 4.3191 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list warmboot_t194_prod_sigheader_aligned.bin_list.xml
[ 4.3193 ] Key is a SBK key
[ 4.3193 ] Key Size is 16 bytes
[ 4.3245 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader_aligned.bin.encrypt warmboot_t194_prod_sigheader_aligned.bin.hash zerosbk
[ 4.3294 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin_aligned.encrypt
[ 4.3305 ] header_magic: 4e564441
[ 4.3345 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list warmboot_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.3358 ] Key size is 384 bytes
[ 4.3722 ] Saving pkc public key in pub_key.key
[ 4.3735 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin_aligned.encrypt.signed warmboot_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.3803 ] tegrahost_v2 --chip 0x19 --align nvdisp-init_sigheader_aligned.bin
[ 4.3815 ] header_magic: 4e564441
[ 4.3852 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list nvdisp-init_sigheader_aligned.bin_list.xml
[ 4.3854 ] Key is a SBK key
[ 4.3854 ] Key Size is 16 bytes
[ 4.4610 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvdisp-init_sigheader_aligned.bin.encrypt nvdisp-init_sigheader_aligned.bin.hash zerosbk
[ 4.5097 ] tegrahost_v2 --chip 0x19 --align nvdisp-init_sigheader.bin_aligned.encrypt
[ 4.5108 ] header_magic: 4e564441
[ 4.5146 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list nvdisp-init_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.5158 ] Key size is 384 bytes
[ 4.5562 ] Saving pkc public key in pub_key.key
[ 4.5575 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvdisp-init_sigheader.bin_aligned.encrypt.signed nvdisp-init_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.5923 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader_aligned.dtb
[ 4.5937 ] header_magic: 4e564441
[ 4.5974 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list tegra194-p3668-all-p3509-0000_sigheader_aligned.dtb_list.xml
[ 4.5976 ] Key is a SBK key
[ 4.5976 ] Key Size is 16 bytes
[ 4.6092 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader_aligned.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader_aligned.dtb.hash zerosbk
[ 4.6167 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb_aligned.encrypt
[ 4.6178 ] header_magic: 4e564441
[ 4.6217 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list tegra194-p3668-all-p3509-0000_sigheader.dtb_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.6231 ] Key size is 384 bytes
[ 4.6595 ] Saving pkc public key in pub_key.key
[ 4.6607 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb_aligned.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.6697 ] tegrahost_v2 --chip 0x19 --align tos-optee_t194_sigheader_aligned.img
[ 4.6708 ] header_magic: 4e564441
[ 4.6746 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list tos-optee_t194_sigheader_aligned.img_list.xml
[ 4.6749 ] Key is a SBK key
[ 4.6749 ] Key Size is 16 bytes
[ 4.7037 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-optee_t194_sigheader_aligned.img.encrypt tos-optee_t194_sigheader_aligned.img.hash zerosbk
[ 4.7187 ] tegrahost_v2 --chip 0x19 --align tos-optee_t194_sigheader.img_aligned.encrypt
[ 4.7198 ] header_magic: 4e564441
[ 4.7236 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list tos-optee_t194_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.7248 ] Key size is 384 bytes
[ 4.7616 ] Saving pkc public key in pub_key.key
[ 4.7629 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-optee_t194_sigheader.img_aligned.encrypt.signed tos-optee_t194_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.7780 ] tegrahost_v2 --chip 0x19 --align eks_t194_sigheader_aligned.img
[ 4.7791 ] header_magic: 4e564441
[ 4.7828 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list eks_t194_sigheader_aligned.img_list.xml
[ 4.7830 ] Key is a SBK key
[ 4.7831 ] Key Size is 16 bytes
[ 4.7870 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_t194_sigheader_aligned.img.encrypt eks_t194_sigheader_aligned.img.hash zerosbk
[ 4.7906 ] tegrahost_v2 --chip 0x19 --align eks_t194_sigheader.img_aligned.encrypt
[ 4.7917 ] header_magic: 4e564441
[ 4.7955 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list eks_t194_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.7967 ] Key size is 384 bytes
[ 4.8325 ] Saving pkc public key in pub_key.key
[ 4.8337 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_t194_sigheader.img_aligned.encrypt.signed eks_t194_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.8377 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader_aligned.bin
[ 4.8388 ] header_magic: 4e564441
[ 4.8425 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list adsp-fw_sigheader_aligned.bin_list.xml
[ 4.8428 ] Key is a SBK key
[ 4.8428 ] Key Size is 16 bytes
[ 4.8554 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader_aligned.bin.encrypt adsp-fw_sigheader_aligned.bin.hash zerosbk
[ 4.8637 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin_aligned.encrypt
[ 4.8649 ] header_magic: 4e564441
[ 4.8687 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list adsp-fw_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.8699 ] Key size is 384 bytes
[ 4.9065 ] Saving pkc public key in pub_key.key
[ 4.9078 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin_aligned.encrypt.signed adsp-fw_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.9177 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-t194-rce_sigheader_aligned.img
[ 4.9189 ] header_magic: 4e564441
[ 4.9226 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list camera-rtcpu-t194-rce_sigheader_aligned.img_list.xml
[ 4.9228 ] Key is a SBK key
[ 4.9228 ] Key Size is 16 bytes
[ 4.9384 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-t194-rce_sigheader_aligned.img.encrypt camera-rtcpu-t194-rce_sigheader_aligned.img.hash zerosbk
[ 4.9475 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt
[ 4.9486 ] header_magic: 4e564441
[ 4.9524 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.9537 ] Key size is 384 bytes
[ 4.9903 ] Saving pkc public key in pub_key.key
[ 4.9916 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt.signed camera-rtcpu-t194-rce_sigheader.img_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.0014 ] tegrahost_v2 --chip 0x19 --align bpmp-2_t194_sigheader_aligned.bin
[ 5.0026 ] header_magic: 4e564441
[ 5.0064 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list bpmp-2_t194_sigheader_aligned.bin_list.xml
[ 5.0066 ] Key is a SBK key
[ 5.0067 ] Key Size is 16 bytes
[ 5.0325 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp-2_t194_sigheader_aligned.bin.encrypt bpmp-2_t194_sigheader_aligned.bin.hash zerosbk
[ 5.0474 ] tegrahost_v2 --chip 0x19 --align bpmp-2_t194_sigheader.bin_aligned.encrypt
[ 5.0485 ] header_magic: 4e564441
[ 5.0523 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list bpmp-2_t194_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.0536 ] Key size is 384 bytes
[ 5.0901 ] Saving pkc public key in pub_key.key
[ 5.0915 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp-2_t194_sigheader.bin_aligned.encrypt.signed bpmp-2_t194_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.1052 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_lz4_sigheader_aligned.dtb
[ 5.1064 ] header_magic: 4e564441
[ 5.1101 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list tegra194-a02-bpmp-p3668-a00_lz4_sigheader_aligned.dtb_list.xml
[ 5.1104 ] Key is a SBK key
[ 5.1104 ] Key Size is 16 bytes
[ 5.1154 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_lz4_sigheader_aligned.dtb.encrypt tegra194-a02-bpmp-p3668-a00_lz4_sigheader_aligned.dtb.hash zerosbk
[ 5.1194 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_aligned.encrypt
[ 5.1205 ] header_magic: 4e564441
[ 5.1243 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.1255 ] Key size is 384 bytes
[ 5.1614 ] Saving pkc public key in pub_key.key
[ 5.1626 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_aligned.encrypt.signed tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.1696 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194_aligned.bin
[ 5.1707 ] header_magic: 50000ea
[ 5.1745 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list nvtboot_recovery_t194_aligned.bin_list.xml
[ 5.1747 ] Key is a SBK key
[ 5.1747 ] Key Size is 16 bytes
[ 5.1830 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194_aligned.bin.encrypt nvtboot_recovery_t194_aligned.bin.hash zerosbk
[ 5.1870 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin_aligned.encrypt
[ 5.1881 ] header_magic: d07e13d7
[ 5.1903 ] tegrahost_v2 --appendsigheader nvtboot_recovery_t194.bin_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin
[ 5.1913 ] adding BCH for nvtboot_recovery_t194.bin_aligned.encrypt
[ 5.1985 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list nvtboot_recovery_t194.bin_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.1998 ] Key size is 384 bytes
[ 5.2358 ] Saving pkc public key in pub_key.key
[ 5.2371 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194.bin_aligned_sigheader.encrypt.signed nvtboot_recovery_t194.bin_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.2428 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194_aligned.bin
[ 5.2440 ] header_magic: 9000014
[ 5.2477 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list nvtboot_recovery_cpu_t194_aligned.bin_list.xml
[ 5.2480 ] Key is a SBK key
[ 5.2480 ] Key Size is 16 bytes
[ 5.2567 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194_aligned.bin.encrypt nvtboot_recovery_cpu_t194_aligned.bin.hash zerosbk
[ 5.2609 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin_aligned.encrypt
[ 5.2621 ] header_magic: c75315da
[ 5.2643 ] tegrahost_v2 --appendsigheader nvtboot_recovery_cpu_t194.bin_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin
[ 5.2653 ] adding BCH for nvtboot_recovery_cpu_t194.bin_aligned.encrypt
[ 5.2731 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list nvtboot_recovery_cpu_t194.bin_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.2744 ] Key size is 384 bytes
[ 5.3105 ] Saving pkc public key in pub_key.key
[ 5.3118 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194.bin_aligned_sigheader.encrypt.signed nvtboot_recovery_cpu_t194.bin_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.3153 ] Copying signed file in /home/adit/jetson/Linux_for_Tegra/bootloader/encrypted_signed_t19x
[ 5.3159 ] Parsing dev params for multi chains
[ 5.3159 ] Generating br-bct
[ 5.3183 ] Performing cfg overlay
[ 5.3183 ] ['/home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg']
[ 5.3183 ] Updating dev and MSS params in BR BCT
[ 5.3183 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.3768 ] Updating bl info
[ 5.3794 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 5.3813 ] Generating br-bct
[ 5.3835 ] Performing cfg overlay
[ 5.3836 ] ['/home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg']
[ 5.3836 ] Updating dev and MSS params in BR BCT
[ 5.3836 ] tegrabct_v2 --dev_param tegra194-br-bct_b-qspi-l4t.cfg --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.4423 ] Updating bl info
[ 5.4451 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 5.4473 ] Generating BCT backup image
[ 5.4474 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 5.4486 ] 32768+0 records in
[ 5.5264 ] 32768+0 records out
[ 5.5264 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0773589 s, 424 kB/s
[ 5.5264 ]
[ 5.5264 ] Concatenating BCT for chain A to bct_backup.img
[ 5.5264 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 5.5278 ] 2888+0 records in
[ 5.5342 ] 2888+0 records out
[ 5.5342 ] 2888 bytes (2,9 kB, 2,8 KiB) copied, 0,00608302 s, 475 kB/s
[ 5.5343 ]
[ 5.5343 ] Concatenating BCT for chain B to bct_backup.img
[ 5.5343 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 5.5355 ] 2888+0 records in
[ 5.5420 ] 2888+0 records out
[ 5.5420 ] 2888 bytes (2,9 kB, 2,8 KiB) copied, 0,0060802 s, 475 kB/s
[ 5.5420 ]
[ 5.5420 ] Parsing dev params for multi chains
[ 5.5421 ] Generating br-bct
[ 5.5445 ] Performing cfg overlay
[ 5.5445 ] ['/home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg']
[ 5.5446 ] Updating dev and MSS params in BR BCT
[ 5.5446 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.6028 ] Updating bl info
[ 5.6053 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 5.6081 ] Updating smd info
[ 5.6104 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 5.6117 ] Updating Odmdata
[ 5.6139 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 5.6152 ] Get encrypted section of bct
[ 5.6174 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listencbct bct_list.xml
[ 5.6186 ] Signing BCT
[ 5.6186 ] Generating signatures with encryption
[ 5.6222 ] tegrasign_v3.py --file br_bct_BR.bct --key /home/adit/jetson/keys/sd/sbk_key.txt --offset 2328
[ 5.6224 ] Key is a SBK key
[ 5.6224 ] Key Size is 16 bytes
[ 5.6239 ] Updating BCT with signature
[ 5.6242 ] Get Signed section of bct
[ 5.6264 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 5.6313 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 5.6326 ] Key size is 384 bytes
[ 5.6703 ] Saving pkc public key in pub_key.key
[ 5.6704 ] Saving Montgomery values in montgomery.bin
[ 5.6690 ] Updating BCT with signature
[ 5.6715 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.6730 ] Generating br-bct
[ 5.6753 ] Performing cfg overlay
[ 5.6753 ] ['/home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg']
[ 5.6753 ] Updating dev and MSS params in BR BCT
[ 5.6753 ] tegrabct_v2 --dev_param tegra194-br-bct_b-qspi-l4t.cfg --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.7336 ] Updating bl info
[ 5.7361 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 5.7391 ] Updating smd info
[ 5.7413 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 5.7427 ] Updating Odmdata
[ 5.7449 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 5.7462 ] Get encrypted section of bct
[ 5.7484 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listencbct bct_list.xml
[ 5.7497 ] Signing BCT
[ 5.7497 ] Generating signatures with encryption
[ 5.7533 ] tegrasign_v3.py --file br_bct_BR.bct --key /home/adit/jetson/keys/sd/sbk_key.txt --offset 2328
[ 5.7535 ] Key is a SBK key
[ 5.7535 ] Key Size is 16 bytes
[ 5.7551 ] Updating BCT with signature
[ 5.7553 ] Get Signed section of bct
[ 5.7576 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 5.7625 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 5.7638 ] Key size is 384 bytes
[ 5.8019 ] Saving pkc public key in pub_key.key
[ 5.8020 ] Saving Montgomery values in montgomery.bin
[ 5.8006 ] Updating BCT with signature
[ 5.8031 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.8045 ] Generating BCT backup image
[ 5.8046 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 5.8059 ] 32768+0 records in
[ 5.8837 ] 32768+0 records out
[ 5.8837 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0773735 s, 424 kB/s
[ 5.8837 ]
[ 5.8837 ] Concatenating BCT for chain A to bct_backup.img
[ 5.8837 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 5.8853 ] 2888+0 records in
[ 5.8916 ] 2888+0 records out
[ 5.8917 ] 2888 bytes (2,9 kB, 2,8 KiB) copied, 0,00596753 s, 484 kB/s
[ 5.8917 ]
[ 5.8917 ] Concatenating BCT for chain B to bct_backup.img
[ 5.8917 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 5.8932 ] 2888+0 records in
[ 5.8996 ] 2888+0 records out
[ 5.8996 ] 2888 bytes (2,9 kB, 2,8 KiB) copied, 0,00603837 s, 478 kB/s
[ 5.8996 ]
[ 5.8997 ] Generating coldboot mb1-bct
[ 5.9022 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 5.9032 ] MB1-BCT version: 0x1
[ 5.9035 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 5.9036 ] Added Platform Config 0 data with size :- 2496
[ 5.9050 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 5.9053 ] Added Platform Config 1 data with size :- 19640
[ 5.9186 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 5.9190 ] Added Platform Config 2 data with size :- 24
[ 5.9192 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 5.9195 ] Added Platform Config 4 data with size :- 348
[ 5.9198 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 5.9201 ] Added Platform Config 3 data with size :- 92
[ 5.9201 ]
[ 5.9201 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 5.9201 ] Added Platform Config 5 data with size :- 140
[ 5.9201 ]
[ 5.9201 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 5.9201 ] Added Platform Config 7 data with size :- 392
[ 5.9201 ]
[ 5.9201 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 5.9201 ] Added Platform Config 9 data with size :- 40
[ 5.9201 ]
[ 5.9202 ] Updating mb1-bct with firmware information
[ 5.9229 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 5.9243 ] Updating mb1-bct with storage information
[ 5.9266 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 5.9279 ] Updating mb1-bct with ratchet information
[ 5.9301 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 5.9312 ] FwIndex: 1, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 2, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 3, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 4, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 5, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 6, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 7, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 11, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 12, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 13, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 14, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 15, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 16, MinRatchetLevel: 0
[ 5.9316 ] FwIndex: 17, MinRatchetLevel: 0
[ 5.9317 ] FwIndex: 18, MinRatchetLevel: 0
[ 5.9317 ] FwIndex: 19, MinRatchetLevel: 0
[ 5.9317 ] FwIndex: 30, MinRatchetLevel: 0
[ 5.9317 ] FwIndex: 31, MinRatchetLevel: 0
[ 5.9317 ]
[ 5.9341 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 5.9352 ] header_magic: d0660000
[ 5.9390 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mb1_cold_boot_bct_MB1_aligned.bct_list.xml
[ 5.9392 ] Key is a SBK key
[ 5.9392 ] Key Size is 16 bytes
[ 5.9439 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned.bct.encrypt mb1_cold_boot_bct_MB1_aligned.bct.hash zerosbk
[ 5.9476 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct_aligned.encrypt
[ 5.9488 ] header_magic: a4f7243c
[ 5.9510 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin
[ 5.9520 ] adding BCH for mb1_cold_boot_bct_MB1.bct_aligned.encrypt
[ 5.9564 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mb1_cold_boot_bct_MB1.bct_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.9577 ] Key size is 384 bytes
[ 5.9940 ] Saving pkc public key in pub_key.key
[ 5.9953 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1.bct_aligned_sigheader.encrypt.signed mb1_cold_boot_bct_MB1.bct_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.9970 ] Generating recovery mb1-bct
[ 5.9993 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 6.0004 ] MB1-BCT version: 0x1
[ 6.0006 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 6.0009 ] Added Platform Config 0 data with size :- 2496
[ 6.0022 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 6.0025 ] Added Platform Config 1 data with size :- 19640
[ 6.0159 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 6.0162 ] Added Platform Config 2 data with size :- 24
[ 6.0164 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 6.0167 ] Added Platform Config 4 data with size :- 348
[ 6.0170 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 6.0173 ] Added Platform Config 3 data with size :- 92
[ 6.0173 ]
[ 6.0173 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 6.0173 ] Added Platform Config 5 data with size :- 140
[ 6.0173 ]
[ 6.0174 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 6.0174 ] Added Platform Config 7 data with size :- 392
[ 6.0174 ]
[ 6.0174 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 6.0174 ] Added Platform Config 9 data with size :- 40
[ 6.0174 ]
[ 6.0174 ] Updating mb1-bct with firmware information
[ 6.0199 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 6.0213 ] Updating mb1-bct with storage information
[ 6.0236 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 6.0249 ] Updating mb1-bct with ratchet information
[ 6.0272 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 6.0282 ] FwIndex: 1, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 2, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 3, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 4, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 5, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 6, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 7, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 11, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 12, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 13, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 14, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 15, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 16, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 17, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 18, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 19, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 30, MinRatchetLevel: 0
[ 6.0286 ] FwIndex: 31, MinRatchetLevel: 0
[ 6.0286 ]
[ 6.0311 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[ 6.0324 ] header_magic: d0660000
[ 6.0362 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mb1_bct_MB1_aligned.bct_list.xml
[ 6.0365 ] Key is a SBK key
[ 6.0365 ] Key Size is 16 bytes
[ 6.0411 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned.bct.encrypt mb1_bct_MB1_aligned.bct.hash zerosbk
[ 6.0447 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct_aligned.encrypt
[ 6.0459 ] header_magic: a4f7243c
[ 6.0481 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin
[ 6.0491 ] adding BCH for mb1_bct_MB1.bct_aligned.encrypt
[ 6.0537 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mb1_bct_MB1.bct_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.0551 ] Key size is 384 bytes
[ 6.0913 ] Saving pkc public key in pub_key.key
[ 6.0926 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1.bct_aligned_sigheader.encrypt.signed mb1_bct_MB1.bct_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.0943 ] Generating coldboot mem-bct
[ 6.0965 ] tegrabct_v2 --chip 0x19 0 --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --membct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_1.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_2.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_3.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_4.bct
[ 6.0976 ] Packing sdram param for instance[0]
[ 6.1563 ] Packing sdram param for instance[1]
[ 6.1565 ] Packing sdram param for instance[2]
[ 6.1567 ] Packing sdram param for instance[3]
[ 6.1567 ] Packing sdram param for instance[4]
[ 6.1567 ] Packing sdram param for instance[5]
[ 6.1567 ] Packing sdram param for instance[6]
[ 6.1567 ] Packing sdram param for instance[7]
[ 6.1567 ] Packing sdram param for instance[8]
[ 6.1567 ] Packing sdram param for instance[9]
[ 6.1567 ] Packing sdram param for instance[10]
[ 6.1567 ] Packing sdram param for instance[11]
[ 6.1568 ] Packing sdram param for instance[12]
[ 6.1568 ] Packing sdram param for instance[13]
[ 6.1568 ] Packing sdram param for instance[14]
[ 6.1568 ] Packing sdram param for instance[15]
[ 6.1568 ]
[ 6.1568 ] Getting sector size from pt
[ 6.1594 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 6.1606 ] BlockSize read from layout is 200
[ 6.1643 ] tegrasign_v3.py --file /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_1.bct --key /home/adit/jetson/keys/sd/sbk_key.txt
[ 6.1645 ] Key is a SBK key
[ 6.1645 ] Key Size is 16 bytes
[ 6.1708 ] tegrasign_v3.py --file /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_2.bct --key /home/adit/jetson/keys/sd/sbk_key.txt
[ 6.1711 ] Key is a SBK key
[ 6.1711 ] Key Size is 16 bytes
[ 6.1772 ] tegrasign_v3.py --file /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_3.bct --key /home/adit/jetson/keys/sd/sbk_key.txt
[ 6.1775 ] Key is a SBK key
[ 6.1775 ] Key Size is 16 bytes
[ 6.1836 ] tegrasign_v3.py --file /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_4.bct --key /home/adit/jetson/keys/sd/sbk_key.txt
[ 6.1839 ] Key is a SBK key
[ 6.1839 ] Key Size is 16 bytes
[ 6.1887 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_1_encrypt.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_2_encrypt.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_3_encrypt.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_4_encrypt.bct
[ 6.1898 ] adding BCH for /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_1_encrypt.bct
[ 6.1941 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[ 6.1952 ] header_magic: 4e564441
[ 6.1990 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mem_coldboot_aligned.bct_list.xml --pubkeyhash pub_key.key
[ 6.2003 ] Key size is 384 bytes
[ 6.2370 ] Saving pkc public key in pub_key.key
[ 6.2383 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned.bct.signed mem_coldboot_aligned.bct.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.2424 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[ 6.2458 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct oem-rsa
[ 6.2468 ] Header already present for mem_coldboot_aligned.bct
[ 6.2510 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mem_coldboot_aligned_sigheader.bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 6.2523 ] Key size is 384 bytes
[ 6.2898 ] Saving pkc public key in pub_key.key
[ 6.2898 ] Saving Montgomery values in montgomery.bin
[ 6.2911 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader mem_coldboot_aligned_sigheader.bct.signed mem_coldboot_aligned_sigheader.bct.sig oem-rsa
[ 6.2928 ] Generating recovery mem-bct
[ 6.2952 ] tegrabct_v2 --chip 0x19 0 --sdram /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1.cfg --membct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_1.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_2.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_3.bct /home/adit/jetson/Linux_for_Tegra/bootloader/3351144/tmpb6wv3gwi1_4.bct
[ 6.2963 ] Packing sdram param for instance[0]
[ 6.3534 ] Packing sdram param for instance[1]
[ 6.3536 ] Packing sdram param for instance[2]
[ 6.3538 ] Packing sdram param for instance[3]
[ 6.3541 ] Packing sdram param for instance[4]
[ 6.3541 ] Packing sdram param for instance[5]
[ 6.3541 ] Packing sdram param for instance[6]
[ 6.3541 ] Packing sdram param for instance[7]
[ 6.3541 ] Packing sdram param for instance[8]
[ 6.3541 ] Packing sdram param for instance[9]
[ 6.3541 ] Packing sdram param for instance[10]
[ 6.3541 ] Packing sdram param for instance[11]
[ 6.3541 ] Packing sdram param for instance[12]
[ 6.3541 ] Packing sdram param for instance[13]
[ 6.3541 ] Packing sdram param for instance[14]
[ 6.3541 ] Packing sdram param for instance[15]
[ 6.3541 ]
[ 6.3569 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[ 6.3581 ] header_magic: 3000000
[ 6.3619 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/sbk_key.txt --list mem_rcm_aligned.bct_list.xml
[ 6.3622 ] Key is a SBK key
[ 6.3622 ] Key Size is 16 bytes
[ 6.3675 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned.bct.encrypt mem_rcm_aligned.bct.hash zerosbk
[ 6.3715 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct_aligned.encrypt
[ 6.3727 ] header_magic: a29a2135
[ 6.3749 ] tegrahost_v2 --appendsigheader mem_rcm.bct_aligned.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin
[ 6.3760 ] adding BCH for mem_rcm.bct_aligned.encrypt
[ 6.3808 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mem_rcm.bct_aligned_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.3821 ] Key size is 384 bytes
[ 6.4182 ] Saving pkc public key in pub_key.key
[ 6.4195 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm.bct_aligned_sigheader.encrypt.signed mem_rcm.bct_aligned_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.4216 ] Copying br bct for multi chains
[ 6.4217 ] Signed BCT for boot chain A is copied to /home/adit/jetson/Linux_for_Tegra/bootloader/encrypted_signed_t19x/br_bct_BR.bct
[ 6.4218 ] Signed BCT for boot chain B is copied to /home/adit/jetson/Linux_for_Tegra/bootloader/encrypted_signed_t19x/br_bct_b_BR.bct
[ 6.4219 ] Copying BCT backup image bct_backup.img to /home/adit/jetson/Linux_for_Tegra/bootloader/encrypted_signed_t19x/bct_backup.img
[ 6.4226 ] nvtboot_recovery_t194.bin_sigheader.encrypt.signed
[ 6.4229 ] preboot_c10_prod_cr.bin
[ 6.4230 ] mce_c10_prod_cr.bin
[ 6.4232 ] mts_c10_prod_cr.bin
[ 6.4260 ] bpmp-2_t194.bin
[ 6.4268 ] tegra194-a02-bpmp-p3668-a00_lz4.dtb
[ 6.4269 ] spe_t194.bin
[ 6.4271 ] tos-optee_t194.img
[ 6.4281 ] eks_t194.img
[ 6.4282 ] tegra194-p3668-all-p3509-0000.dtb
[ 6.4286 ] nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed
[ 6.4408 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin_aligned.encrypt
[ 6.4420 ] header_magic: 4e564441
[ 6.4459 ] tegrasign_v3.py --key /home/adit/jetson/keys/sd/jetson.pem --list mb1_t194_prod_sigheader.bin_aligned.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.4472 ] Key size is 384 bytes
[ 6.4837 ] Saving pkc public key in pub_key.key
[ 6.4850 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin_aligned.encrypt.signed mb1_t194_prod_sigheader.bin_aligned.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.4913 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 6.4924 ] gpt_secondary_3_0.bin:
[ 6.4926 ] partition_id partition_name StartingLba EndingLba
[ 6.4928 ] 1 BCT 0 255
[ 6.4930 ] 2 mb1 256 767
[ 6.4932 ] 3 mb1_b 768 1279
[ 6.4935 ] 4 MB1_BCT 1280 1407
[ 6.4937 ] 5 MEM_BCT 1408 1919
[ 6.4939 ] 6 spe-fw 1920 2431
[ 6.4941 ] 7 mb2 2432 2943
[ 6.4943 ] 8 mts-preboot 2944 3071
[ 6.4945 ] 9 mts-mce 3072 3455
[ 6.4947 ] 10 mts-proper 3456 11647
[ 6.4950 ] 11 sc7 11648 11903
[ 6.4952 ] 12 xusb-fw 11904 12287
[ 6.4955 ] 13 cpu-bootloader 12288 20479
[ 6.4957 ] 14 bootloader-dtb 20480 21375
[ 6.4959 ] 15 secure-os 21376 26495
[ 6.4962 ] 16 eks 26496 26623
[ 6.4962 ] 17 adsp-fw 26624 28671
[ 6.4962 ] 18 rce-fw 28672 30719
[ 6.4963 ] 19 sce-fw 30720 32767
[ 6.4963 ] 20 bpmp-fw 32768 35839
[ 6.4963 ] 21 bpmp-fw-dtb 35840 37887
[ 6.4963 ] 22 reserved_for_chain_A_boot 37888 41983
[ 6.4963 ] 23 MB1_BCT_b 41984 42111
[ 6.4963 ] 24 MEM_BCT_b 42112 42623
[ 6.4963 ] 25 spe-fw_b 42624 43135
[ 6.4963 ] 26 mb2_b 43136 43647
[ 6.4963 ] 27 mts-preboot_b 43648 43775
[ 6.4963 ] 28 mts-mce_b 43776 44159
[ 6.4963 ] 29 mts-proper_b 44160 52351
[ 6.4963 ] 30 sc7_b 52352 52607
[ 6.4963 ] 31 xusb-fw_b 52608 52991
[ 6.4963 ] 32 cpu-bootloader_b 52992 61183
[ 6.4963 ] 33 bootloader-dtb_b 61184 62079
[ 6.4963 ] 34 reserved_for_chain_B_boot 62080 63359
[ 6.4963 ] 35 uefi_variables 63360 63615
[ 6.4963 ] 36 uefi_ftw 63616 63999
[ 6.4963 ] 37 BCT-boot-chain_backup 64768 64895
[ 6.4963 ] 38 reserved_partition 64896 65023
[ 6.4963 ] 39 secondary_gpt_backup 65024 65151
[ 6.4963 ] 40 VER_b 65152 65279
[ 6.4963 ] 41 VER 65280 65407
[ 6.4963 ] gpt_primary_1_3.bin:
[ 6.4963 ] partition_id partition_name StartingLba EndingLba
[ 6.4963 ] 1 APP 40 29360167
[ 6.4963 ] 2 kernel 29360168 29491239
[ 6.4963 ] 3 kernel-dtb 29491240 29492135
[ 6.4963 ] 4 reserved_for_chain_A_user 29492136 29558783
[ 6.4963 ] 5 secure-os_b 29558784 29563903
[ 6.4963 ] 6 eks_b 29563904 29564031
[ 6.4963 ] 7 adsp-fw_b 29564032 29566079
[ 6.4963 ] 8 rce-fw_b 29566080 29568127
[ 6.4963 ] 9 sce-fw_b 29568128 29570175
[ 6.4963 ] 10 bpmp-fw_b 29570176 29573247
[ 6.4963 ] 11 bpmp-fw-dtb_b 29573248 29575295
[ 6.4964 ] 12 kernel_b 29575296 29706367
[ 6.4964 ] 13 kernel-dtb_b 29706368 29707263
[ 6.4964 ] 14 reserved_for_chain_B_user 29707264 29773823
[ 6.4964 ] 15 recovery 29773824 29937663
[ 6.4964 ] 16 recovery-dtb 29937664 29938687
[ 6.4964 ] 17 RECROOTFS 29938688 30143487
[ 6.4964 ] 18 esp 30143488 30274559
[ 6.4964 ] 19 recovery_alt 30274560 30438399
[ 6.4964 ] 20 recovery-dtb_alt 30438400 30439423
[ 6.4964 ] 21 esp_alt 30439424 30570495
[ 6.4964 ] 22 UDA 30570496 30777303
[ 6.4964 ] gpt_secondary_1_3.bin:
[ 6.4964 ] partition_id partition_name StartingLba EndingLba
[ 6.4964 ] 1 APP 40 29360167
[ 6.4964 ] 2 kernel 29360168 29491239
[ 6.4964 ] 3 kernel-dtb 29491240 29492135
[ 6.4964 ] 4 reserved_for_chain_A_user 29492136 29558783
[ 6.4964 ] 5 secure-os_b 29558784 29563903
[ 6.4964 ] 6 eks_b 29563904 29564031
[ 6.4964 ] 7 adsp-fw_b 29564032 29566079
[ 6.4964 ] 8 rce-fw_b 29566080 29568127
[ 6.4964 ] 9 sce-fw_b 29568128 29570175
[ 6.4964 ] 10 bpmp-fw_b 29570176 29573247
[ 6.4964 ] 11 bpmp-fw-dtb_b 29573248 29575295
[ 6.4964 ]
[ 6.5033 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/adit/jetson/Linux_for_Tegra/bootloader/encrypted_signed_t19x/flash.xml.tmp flash.idx
copying overlay_dtb(/home/adit/jetson/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/adit/jetson/Linux_for_Tegra/kernel/dtb/tegra194-p3668-p3509-overlay.dtbo)... done.
/home/adit/jetson/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/adit/jetson/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0xB8190000 --overlay_dtb L4TConfiguration.dtbo,tegra194-p3668-p3509-overlay.dtbo, --bldtb tegra194-p3668-all-p3509-0000.dtb --applet mb1_t194_prod.bin --cmd "sign" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi-l4t.cfg,tegra194-br-bct_b-qspi-l4t.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_lz4.dtb; spe_fw spe_t194.bin; tos tos-optee_t194.img; eks eks_t194.img; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb" --key "/home/adit/jetson/keys/sd/jetson.pem" --bct_backup --boot_chain A
saving flash command in /home/adit/jetson/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/adit/jetson/Linux_for_Tegra/bootloader/flash_win.bat
*** Sign and generate BUP... ***
Encrypting with /home/adit/jetson/keys/sd/sbk_key.txt ...
Signing with /home/adit/jetson/keys/sd/jetson.pem ...
rollback info is parsed and saved in rollback.bin
pad ZEROs to the end of rollback.bin
signing images succeeded
Creating update payloads for Jetson-3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc- board ...
creating bl payload
PARTITION INFO : multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/BCT/br_bct_BR.bct.prod BCT 3560 2 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/BCT_A/br_bct_BR.bct.prod BCT_A 3560 2 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/BCT_B/br_bct_b_BR.bct.prod BCT_B 3560 2 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/BCT-boot-chain_backup/bct_backup.img.prod BCT-boot-chain_backup 3560 2 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/mb1/mb1_t194_prod_sigheader.bin.encrypt.signed mb1 3560 2 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/mb1_b/mb1_b_t194_prod_sigheader.bin.encrypt.signed mb1_b 3560 2 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/MB1_BCT/mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed MB1_BCT 3560 0 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/MEM_BCT/mem_coldboot_sigheader.bct.signed MEM_BCT 3560 0 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; encrypted_signed_t19x/spe_t194_sigheader.bin.encrypt.signed spe-fw 3560 0 common; encrypted_signed_t19x/nvtboot_t194_sigheader.bin.encrypt.signed mb2 3560 0 common; multi_signed/mts-preboot_fuselevel_production/preboot_c10_prod_cr_sigheader.bin.encrypt.signed mts-preboot 3560 2 common; multi_signed/mts-mce_fuselevel_production/mce_c10_prod_cr_sigheader.bin.encrypt.signed mts-mce 3560 2 common; multi_signed/mts-proper_fuselevel_production/mts_c10_prod_cr_sigheader.bin.encrypt.signed mts-proper 3560 2 common; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/VER/qspi_bootblob_ver.txt VER 3560 0 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; encrypted_signed_t19x/nvdisp-init_sigheader.bin.encrypt.signed cpu-bootloader 3560 0 common; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/bootloader-dtb/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed bootloader-dtb 3560 0 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; encrypted_signed_t19x/tos-optee_t194_sigheader.img.encrypt.signed secure-os 3560 0 common; encrypted_signed_t19x/eks_t194_sigheader.img.encrypt.signed eks 3560 0 common; encrypted_signed_t19x/bpmp-2_t194_sigheader.bin.encrypt.signed bpmp-fw 3560 0 common; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/bpmp-fw-dtb/tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt.signed bpmp-fw-dtb 3560 0 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; encrypted_signed_t19x/camera-rtcpu-t194-rce_sigheader.img.encrypt.signed rce-fw 3560 0 common; encrypted_signed_t19x/adsp-fw_sigheader.bin.encrypt.signed adsp-fw 3560 0 common; multi_signed/sc7_fuselevel_production/warmboot_t194_prod_sigheader.bin.encrypt.signed sc7 3560 2 common; xusb_sil_rel_fw xusb-fw 3560 0 common; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/secondary_gpt/gpt_secondary_3_0.bin secondary_gpt 3560 0 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/secondary_gpt_backup/gpt_secondary_3_0.bin secondary_gpt_backup 3560 0 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-
SUCCESS: bl_only_payload created
creating kernel payload
PARTITION INFO : boot.img kernel 3560 0 common; multi_signed/3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-/kernel-dtb/kernel_tegra194-p3668-0001-p3509-0000.dtb kernel-dtb 3560 0 3668-100-0001--1-2-jetson-xavier-nx-devkit-emmc-
SUCCESS: kernel_only_payload created
Payloads saved to "/home/adit/jetson/Linux_for_Tegra/bootloader/payloads_t19x/"
and then capsule using command below and then copied it to ESP partition of NVME :
./generate_capsule/l4t_generate_soc_capsule.sh -i bootloader/payloads_t19x/bl_only_payload -o ./TEGRA_BL.Cap t194
Still, the FAB=100 board cannot trigger the Boootloader Update after reboot .
What can I do next ?
