Bootloader infomation missing (JetPack 6.0)
Hi all,
The issue persists with JetPack 6.0.
How can I fix it to display bootloader information correctly?
This does seems to be an issue as no impact for general use case.
I understand that this issue does not impact for general use case but I need to correct the UEFI information display.
Do you have any suggestions for resolving this issue?
Hi lrnxd9120,
We are still checking this issue with internal.
It doesn’t affect the function and you can get those information after boot up so that it’s the low priority for us.
I will update to you once we get any result.
Hi lrnxd9120,
This issue has been fixed.
Please apply the following patch to verify.
fix: fix cpufreq driver and processor version for jetson · NVIDIA/edk2-nvidia@80cc9d3 · GitHub
