Hi There, my company is designing a product which uses Xavier NX SOM on our custom carrier board. I went through the bootloader code, and feel that the bootloader code should be used unchanged, since bootloader is dealing with the SOM. Not sure if my understanding is correct on this. Please suggest.
Is this NX issue or AGX issue? You filed topic on AGX forum.
Sorry. This is for NX module
Generally you don’t need to change bootloader code.
Thanks a lot for the confirmation.
