Both PyTorch and TensorFlow cannot detect 3090Ti GPUs
I have tried to run neural network models on the 3090Ti GPUs but both PyTorch and TensorFlow cannot find my Cuda devices even though the devices and corresponding drivers are correctly installed. My system setup is Ubuntu 22.04.1 LTS and my ubuntu kernel version is 5.15.0-56-generic. Below are the outputs from PyTorch and TensorFlow. I have tried the PyTorch version from 1.6 to 1.13 and the python version from 3.7 to 3.10. Thanks a lot for your help!
For Pytorch Environment Test, I type the command python -m torch.utils.collect_env
Collecting environment information...
PyTorch version: 1.13.1
Is debug build: False
CUDA used to build PyTorch: 11.7
ROCM used to build PyTorch: N/A
OS: Ubuntu 22.04.1 LTS (x86_64)
GCC version: (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0
Clang version: Could not collect
CMake version: version 3.22.1
Libc version: glibc-2.35
Python version: 3.10.8 (main, Nov 24 2022, 14:13:03) [GCC 11.2.0] (64-bit runtime)
Python platform: Linux-5.15.0-56-generic-x86_64-with-glibc2.35
Is CUDA available: False
CUDA runtime version: 11.7.99
CUDA_MODULE_LOADING set to: N/A
GPU models and configuration:
GPU 0: NVIDIA GeForce RTX 3090 Ti
GPU 1: NVIDIA GeForce RTX 3090 Ti
Nvidia driver version: 525.60.11
cuDNN version: Could not collect
HIP runtime version: N/A
MIOpen runtime version: N/A
Is XNNPACK available: True
Versions of relevant libraries:
[pip3] numpy==1.23.4
[pip3] torch==1.13.1
[pip3] torchaudio==0.13.1
[pip3] torchvision==0.14.1
[conda] blas                      1.0                         mkl
[conda] ffmpeg                    4.3                  hf484d3e_0    pytorch
[conda] mkl                       2021.4.0           h06a4308_640
[conda] mkl-service               2.4.0           py310h7f8727e_0
[conda] mkl_fft                   1.3.1           py310hd6ae3a3_0
[conda] mkl_random                1.2.2           py310h00e6091_0
[conda] numpy                     1.23.4          py310hd5efca6_0
[conda] numpy-base                1.23.4          py310h8e6c178_0
[conda] pytorch                   1.13.1          py3.10_cuda11.7_cudnn8.5.0_0    pytorch
[conda] pytorch-cuda              11.7                 h67b0de4_1    pytorch
[conda] pytorch-mutex             1.0                        cuda    pytorch
[conda] torchaudio                0.13.1              py310_cu117    pytorch
[conda] torchvision               0.14.1              py310_cu117    pytorch
For Tensorflow CUDA check, I type the command python3 -c "import tensorflow as tf; print(tf.config.list_physical_devices('GPU'))"
2022-12-27 12:12:02.205401: I tensorflow/core/platform/cpu_feature_guard.cc:193] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations:  AVX2 AVX_VNNI FMA
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2022-12-27 12:12:02.270790: I tensorflow/core/util/port.cc:104] oneDNN custom operations are on. You may see slightly different numerical results due to floating-point round-off errors from different computation orders. To turn them off, set the environment variable `TF_ENABLE_ONEDNN_OPTS=0`.
2022-12-27 12:12:02.869572: E tensorflow/compiler/xla/stream_executor/cuda/cuda_driver.cc:267] failed call to cuInit: CUDA_ERROR_NO_DEVICE: no CUDA-capable device is detected
2022-12-27 12:12:02.869596: I tensorflow/compiler/xla/stream_executor/cuda/cuda_diagnostics.cc:169] retrieving CUDA diagnostic information for host: sijiawang-MS-7D30
2022-12-27 12:12:02.869599: I tensorflow/compiler/xla/stream_executor/cuda/cuda_diagnostics.cc:176] hostname: sijiawang-MS-7D30
2022-12-27 12:12:02.869648: I tensorflow/compiler/xla/stream_executor/cuda/cuda_diagnostics.cc:200] libcuda reported version is: NOT_FOUND: was unable to find libcuda.so DSO loaded into this program
2022-12-27 12:12:02.869664: I tensorflow/compiler/xla/stream_executor/cuda/cuda_diagnostics.cc:204] kernel reported version is: 525.60.11
Here is the output from nvidia-smi and nvcc --version Thanks
| NVIDIA-SMI 525.60.11    Driver Version: 525.60.11    CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0  On |                  Off |
|  0%   45C    P8     9W / 450W |    432MiB / 24564MiB |     10%      Default |
|                               |                      |                  N/A |
|   1  NVIDIA GeForce ...  Off  | 00000000:02:00.0 Off |                  Off |
|  0%   34C    P8    13W / 450W |      6MiB / 24564MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      2305      G   /usr/lib/xorg/Xorg                195MiB |
|    0   N/A  N/A      2442      G   /usr/bin/gnome-shell               64MiB |
|    0   N/A  N/A      3108    C+G   ...753587327527835605,131072      170MiB |
|    1   N/A  N/A      2305      G   /usr/lib/xorg/Xorg                  4MiB |
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Jun__8_16:49:14_PDT_2022
Cuda compilation tools, release 11.7, V11.7.99
Build cuda_11.7.r11.7/compiler.31442593_0
I have three versions of cudatoolkit (11.7, 11.6, and 12.0) and I have tried them all.
The problem is solved by reinstalling the ubuntu and install the newest nvidia driver. Thanks
