Hello to everyone,
I have a bottle, but the color of the bottle is white and the cap color cannot be distinguished by the color detection method. I tried two different methods but without success. I am sharing the picture of the bottle and cap below. Here are the codes I use. Which method can I use? Thanks in advance for your help.
Photos;
METHOD 1
import cv2
import numpy as np
def gstreamer_pipeline(
capture_width=1280,
capture_height=720,
display_width=400,
display_height=400,
framerate=0,
flip_method=0,
return (
"nvarguscamerasrc ! "
"video/x-raw(memory:NVMM), "
"width=(int)%d, height=(int)%d, "
"format=(string)NV12, framerate=(fraction)%d/1 ! "
"nvvidconv flip-method=%d ! "
"video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
"videoconvert ! "
"video/x-raw, format=(string)BGR ! appsink"
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
cap = cv2.VideoCapture(gstreamer_pipeline(flip_method=0), cv2.CAP_GSTREAMER)
_, frame = cap.read()
rows, cols, _ = frame.shape
x_medium = int(cols/2)
y_medium = int(cols/2)
w_medium = int(cols/2)
h_medium = int(cols/2)
center = int(cols/2)
x_medium1 = int(cols/2)
y_medium1 = int(cols/2)
w_medium1 = int(cols/2)
h_medium1 = int(cols/2)
center1 = int(cols/2)
while True:
hsv_frame = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
low_abc = np.array([10, 20, 0])
high_abc = np.array([20, 255, 255])
abc_mask= cv2.inRange(hsv_frame, low_abc, high_abc)
(contours), _ = cv2.findContours(abc_mask, cv2.RETR_TREE, cv2.CHAIN_APPROX_SIMPLE)
contours = sorted(contours, key = lambda x:cv2.contourArea(x), reverse= True)
for cnt in contours:
(x, y, w, h) = cv2.boundingRect(cnt)
x_medium = int((x+x+w)/2)
break
low_white = np.array([0, 0, 0])
high_white= np.array([0, 0, 255])
white_mask = cv2.inRange(hsv_frame, low_white, high_white)
(contours1), _ = cv2.findContours(white_mask, cv2.RETR_TREE, cv2.CHAIN_APPROX_SIMPLE)
contours1 = sorted(contours1, key = lambda x1:cv2.contourArea(x1), reverse= True)
for cnt1 in contours1:
(x1, y1, w1, h1) = cv2.boundingRect(cnt1)
x_medium1 = int((x1+x1+w1)/2)
break
if x_medium1 < x_medium:
cv2.rectangle(frame, (x,y), (x+w,y+h), (0,255,0),2)
cv2.putText(frame,"CAP", (x,y), cv2.FONT_HERSHEY_SIMPLEX, 1.0, (0, 255, 0))
else:
cv2.rectangle(frame, (x1,y1), (x1+w1,y1+h1), (0,0,255),2)
cv2.putText(frame,"NO CAP", (x1,y1), cv2.FONT_HERSHEY_SIMPLEX, 1.0, (0, 0, 255))
cv2.imshow("Frame", frame)
key = cv2.waitKey(1)
if key == 27:
break
cap.release()
cv2.destroyAllWindows()
METHOD 2
import cv2
import numpy as np
capture_width=1280,
capture_height=720,
display_width=680,
display_height=500,
framerate=0,
flip_method=0,
return (
"videoconvert ! "
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
while True:
# Belt
belt = frame[209: 457, 137: 530]
gray_belt = cv2.cvtColor(belt, cv2.COLOR_BGR2GRAY)
_, threshold = cv2.threshold(gray_belt, 110, 255, cv2.THRESH_BINARY)
# Detect the Nuts
(contours), _ = cv2.findContours(threshold, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)
# Calculate area
area = cv2.contourArea(cnt)
# Distinguish small and big nuts
if area > 500:
# Big nut
cv2.rectangle(belt, (x, y), (x + w, y + h), (0, 0, 255), 2)
elif 100 < area < 500:
cv2.rectangle(belt, (x, y), (x + w, y + h), (255, 0, 0), 2)
cv2.putText(belt, str(area), (x, y), 1, 1, (0, 255, 0))
cv2.imshow("Belt", belt)
cv2.imshow("Threshold", threshold)
if key == 27:
break
cap.release()
