Bounding box confidence filtering at NvDsInferParseCustomEfficientNMS and after
Hello everybody!
I am running a deepstream pipeline for inference with yolov7 and i am using NvDsInferParseCustomEfficientNMS to parse the output of the NMS plug in to deepstream format. I want to ask
  1. Where the NvDsInferParseCustomEfficientNMS takes the confidence from to filter (because for a reason it is 0.2 while the .trt is builded with 0 confidence)?
  2. Also i hardcoded the confidence there to be less than 0.2 and the bounding boxes seems to pass from this parser function, but i am not able to get them at at the tiler_sink_pad_buffer_prob where i extract the metadata.
    Can someone explain me how is this possible and if there are additional steps in between?
Thank you very much
• DeepStream Version
• TensorRT Version
• Hardware Platform (Jetson / GPU) Jetson Xavier
• DeepStream Version DS 6.0
• JetPack Version (valid for Jetson only) 4.6 (L4T 32.6.1)
• TensorRT Version 8.0.1
**• Issue Type This is a question to better understand the inference pipeline pre and post processing and when the custom efficient nms parser is called (before the post process?) and which threshold it uses?
please refer to this code. the configuration “pre-cluster-threshold” will become that perClassThreshold.
