Bounding box parser for retinanet
• Hardware Platform: Jetson Xavier NX
• DeepStream Version: 6.0
• Language: Python
I trained a Retinanet model with TAO toolkit using custom dataset, and would like to port it on Jetson Xavier and run video analytics with Deepstream. To implement that, I need to first compile the bounding box parser. I was referring to this webpage, and used the code nvdsparsebbox_retinanet.cpp under this repository.
To build the custom parser and generate libnvdsparsebbox_retinanet.so, I used the command
mkdir build && cd build
cmake -DCMAKE_CUDA_FLAGS="--expt-extended-lambda -std=c++11" ..
make
as in the technical blog.
It shows an error about missing file nvdsparsebbox_odtk.cpp, which I did not find under the repository.
-- Configuring done
CMake Error at /usr/local/share/cmake-3.19/Modules/FindCUDA.cmake:1842 (add_library):
  Cannot find source file:
  Tried extensions .c .C .c++ .cc .cpp .cxx .cu .m .M .mm .h .hh .h++ .hm
  .hpp .hxx .in .txx .f .F .for .f77 .f90 .f95 .f03 .ispc
Call Stack (most recent call first):
  CMakeLists.txt:24 (cuda_add_library)
  No SOURCES given to target: nvdsparsebbox_odtk
CMake Generate step failed.  Build files cannot be regenerated correctly.
Is this repository up to date and supposed to work with DeepStream 6.0? Any suggestion is appreciated.
Hi @zzww ,
This project GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream supports TAO Retinanet with its parser, could you refer to this project?
Thanks for your reply. I will refer to the project and test it.
Please let us know if you have more udpate, thanks.
