I am running MY-DETECTION.PY , I would need to extract the bounding box as an image and store it on disk, is it possible to do it? thank you
Hi @cbenglenok, you can use the jetson.utils.cudaCrop()
function to extract the pixels in the bounding box from the image. Here is an example of using it that function:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/aux-image.md#cropping
The example above crops the image around the center, but you can replace the ROI with the (detection.Left, detection.Top, detection.Right, detection.Bottom)
. You would also want to disable the overlay in the initial processing so that what you are extracting doesn’t have the bounding boxes drawn over them.
Here is an example of how it could look - I haven’t tried this, but is hopefully somewhat close for you:
import jetson.inference
import jetson.utils
net = jetson.inference.detectNet("ssd-mobilenet-v2", threshold=0.5)
camera = jetson.utils.videoSource("csi://0") # '/dev/video0' for V4L2
display = jetson.utils.videoOutput("display://0") # 'my_video.mp4' for file
object_count = 0 # keep track of the number of detected objects for the filenames
while display.IsStreaming():
img = camera.Capture()
detections = net.Detect(img, overlay='none') # disable drawing of overlay
for detection in detections:
# allocate the output image, with the cropped size
imgCropped = jetson.utils.cudaAllocMapped(width=detection.Width,
height=detection.Height,
format=img.format)
# get the cropping ROI from the bounding box
crop_roi = (detection.Left, detection.Top, detection.Right, detection.Bottom)
# crop the image
jetson.utils.cudaCrop(img, imgCropped, crop_roi)
# save the image
jetson.utils.saveImage('object_{:d}.jpg'.format(object_count), imgCropped)
object_count += 1
del imgCropped
display.Render(img)
display.SetStatus("Object Detection | Network {:.0f} FPS".format(net.GetNetworkFPS()))
Note that saving the images of the detected objects to disk may slow down the application.
