Do you have any suggestions on the best way to program calculations on an image set? I want to create a continuous buffer of 5 images (FIFO) and then do pixel-wise calculations continuously on this set of 5 Frames to visualize them, is it possible to do this with available visionworks functions or would it require a custom approach? Also, for custom convolution/box filter only U8 image types are accepted as inputs, can a U16 be used for any of these or do you have any alternate suggestions to use this for a U16 image and not U8?
Thanking you in advance for your reply
