Hello everyone.
I am currently using a Jetson Nano to recognize via camera if a label is correctly placed on top of a box, but things are not going well. Here is sme information about what I’m doing and what’s happening:
I have the jetson with the image which NVIDIA provides with the tutorial. It has some Jupyterlab libraries using pytorch and data entry widgets already created, which I modified slightly to my needs.
The actual approach to the problem is to use image recognition with 3 categories, to determine wheter the label is well placed or not. Categories are: a) well placed, b) wrong corner, c) askew right now.
The images are taken via usb-webcam and manually using the widget. I have a set of 6 boxes with 6 different “labels” (coloured post-its and folded paper sheets with random things written/drawn), which can be swapped beetween them to create 6^6 possible combinations of box/label.
The model in use to process the information is a resNet34.
I have a 7th box/label that are used to test the outputs of the network, and remains outside the training set.
As a final consideration, I have very little experience with Machine Learning (only the tutorial course and a few home made experiments with food recognition so far), which means that I might be doing elementary mistakes. Any suggestion/comment willl be appreciated
